RV.Net Open Roads Forum: Looking for a good recipe for BBQ Ribs!!
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > Looking for a good recipe for BBQ Ribs!!
Camp Cooks and Connoisseurs Related Tips
Spooner46
Oscoda MI
Posted: 04/29/04 02:30am Link  |  Print  |  Notify Moderator
Is there anyone out there that have a killer recipe for ribs? We love to grill with charcoal using a Weber and I am looking for something that just makes your mouth water for more.
Thanks
Ron
2004-2500HD,LT,CC,SB,D/A WOW
2000 Travel Supreme 34' 5er
6 year old Cocker
daddysgirl
winston salem,nc/usa
Good Sam RV Club
Posted: 04/29/04 05:18am Link  |  Print  |  Notify Moderator
Spooner, go to a website called Holtville.net/recipes.htm
they have all kind of bbq and marinade recipes for ribs ect
DaddysGirl
2003 Dodge Dually
2004 Newmar Kounrty Star:
areeves
Northern AZ
Good Sam RV Club
Posted: 04/29/04 09:31am Link  |  Print  |  Notify Moderator
Are you grilling or BBQ?
To make killer ribs, BBQ style..
Take a rack of ribs, cover then in aluminum foil. Place in the over for about 1 hour to 1 1/2 hours at 325 degrees.
Get your grill ready, then after the ribs have cooked for the hour or so remove them and place them on the grill. Cook each side about 7 mins. then cover each side with your favorite bbq sauce and cook on each side for about 1 or 2 mins. Be sure to not let the bbq sauce cook, that is don't let it blacken.
Remove and eat.
2000 Bounder 31M
N7SF
rvman02
Oklahoma City, OK
Posted: 04/29/04 12:49pm Link  |  Print  |  Notify Moderator
PREPARATION
Use a good "rib rub" (Emeril's, Stubb's, etc.) on the ribs, cover and refigerate from a couple of hours to overnight depending on how much time you have available.
COOKIN
(You need to be able to cook over open flame and then be able to use indirect heat, ie off to the side)
Get a good size fire going and when its ready, put ribs directly over flame for a few minutes (until you get grill marks on the meat) and flip over to the other side and do the same. Then get the ribs off the direct heat, smother in favorite bbq sauce; let cook for about 10 min or until the sauce thickens, repeat this process several times; this gives you several layers of flavor (hint: change sauces during this process for additional flavor)
When you're satisfied with the amount of sauce, wrap 'em up in aluminum foil and place back on grill (indirect heat) until ready.
Pork Ribs go good with Shiner Bock
Beef Ribs go good with Sam Adams
ENJOY
Spooner46
Oscoda MI
Posted: 04/30/04 02:20am Link  |  Print  |  Notify Moderator
Thanks All! My mouth is watering already
BAD
Los Gatos, CA
Posted: 04/30/04 01:09pm Link  |  Print  |  Notify Moderator
Ron, A couple of years ago I started trying to learn to make good BBQ ribs. I'm pretty happy with my current recipe. I use good baby back ribs with the membrane removed. Cover them with a BBQ rub and refrigerate for an hour or so. I make a rub, but any one will work. Bring the ribs to room temp then put in a 250 degree oven for about 3 hours. I take them out and cover with BBQ sauce. I use Bull's Eye regular commercial sauce. I read an article in Bon Appetite and they recommended the Bulls Eye. Then they go on a hot BBQ grill for about half an hour. They fall off the bone.
I sometimes take them with us in our Roadtrek. I pre-cook in the oven let cool and refrigerate. When we get to our campsite I put on the sauce and BBQ. Works great.
Enjoy!
Barbara
2005 Chevy Roadtrek 210Popular
Los Gatos, CA
HuckleCat
Posted: 04/30/04 09:53pm Link  |  Print  |  Notify Moderator
Use a dry rub on the ribs. You can experiment making your own dry rub using 1/2 cup paprika and then about 1 tablespoon each of chili powder, ground black pepper, ground white pepper, salt, dry mustard, red cayenne pepper, garlic powder and onion powder. I do not have a recipe for it as I just make the stuff! Take this stuff and rub all over the ribs then refrig. the ribs overnight. Take them out of the fridge an hour before sticking on the smoker. I reserve a bit of the dry spice to make a mopping solution. For the basting solution, I get a couple tablespoons of the dry spice and add to a cup and a half of apple cider vinegar.
Get the charcoal hot and add some wood that has been soaked in water (hickory, oak, cherry, apple, pecan are my favs.) to produce a lot of smoke. Place ribs over medium hot coals. It should be about 220-230 degrees, you should be able to hold your hand over where the ribs are without burning your hand, but still hot. I use a smoker which puts the meat a foot-18inches from the coals. If using my regular weber grill, I really have to attend them to keep from burning. Every 30 minutes or so, mop or spray on the ribs that basting solution. Make sure they do not cook fast! Takes a good 6 hours for the ribs. I like the cheap spare ribs....baby backs are good but the price is just to high. Can also be used for pork shoulder using same method but takes a good 10 hours to do.
If you like BBQ sauce, apply no more than 20 minutes before removing from grill. That sauce will burn and turn ribs black. Can't give out the sauce recipe exactly, but I use ketchup, brown sugar (sometimes honey), part of the above dry mix and a bit of apple cider vinegar.
Got to add, BAD is right, that regular Bullseye is good stuff if you have not tried it. My 2nd fav for prepared sauce is just regular Hunts BBQ sauce.
Basically have fun, experiment and remember great ribs are a labor of love and take a lots of time. Give it a try and adjust the flavors to your own taste.
Brett
Since the divorce, camping will be in either:
A tent from wal-mart.
The back of the 1998 Mercury Villager
The back of my new loves Honda Element
or...
On the ground with a $14.95 tarp from Pepboys over us.
Either way, we love the outdoors.
or
CubDaddy
Columbus, Ohio
Posted: 05/01/04 05:42am Link  |  Print  |  Notify Moderator
Killer Ribs:
Add the following to boiling water:
5 Cloves of Garlic
Salt
Tbs. Peppercorn
Tbs. Powder Hickory Smoke
Tsp. Oregano
Tsp. Basil
Ribs
Slow boil the ribs for about an hour to hour and a half.
Once done boiling, place ribs on grill.
Mix the following and brush on ribs:
Favorite BBQ Sauce (I like Masterpeice)
Olive Oil
Soy Sauce (not too much)
You won't have to leave the ribs on the grill to long because they are already cooked. Just long enough to crisp each side a bit.
Your ribs will fall off the bone. I don't like my ribs real sweet so that is why I created the sauce mixture.
Enjoy!
CubDaddy
2003 Aerolite Cub C214
2000 Lincoln Navigator 5.4 V8 32 Valve
"Let Freedom Ring"
I'dratherbecamping
MN
Posted: 05/01/04 08:14am Link  |  Print  |  Notify Moderator
We love this Bar-b-que sauce. I always double the recipe and bottle extra and keep it in fridge.
1 Tbsp Liquid smoke
1 tsp. Garlic Salt
1 tsp. Pepper
1 Tbsp Worchester sauce
1 Cup Brown Sugar
1 14 oz Bottle of Ketchup
add a few dashes of Soy Sauce
Happy Grillin
Mary
My Hubby & Me
3 boys, 23 Army specialist,19 college student
and 15 high school boy
2 English Setters
2004-Cherokee 29DD
2004 2500 Dodge HEMI
all4camping
St. Cloud MN
Posted: 05/01/04 08:41am Link  |  Print  |  Notify Moderator
ribs gotta love em first off go directly to you local bookstore and get how to grill by steven raichelen [workman pub ny.]. this book has everything you need to know. many recipes for dry rubs,lots of pictures and step by step instructions. this book covers all aspects of grilling and barbequeing BIG DIFFERENCE!!!! i use a weber and an offset firebox barbeque barrel type best for ribs and brisket. to cook ribs in the weber get a rib rack and charcoal holders to keep charcoal to the sides very important. but seriously go get teh how to grill book it is the source for all your questions . got mine for fathers day few years back went from burning to looked at as some kind of bbq god .good luck and happy eating!!!!!
Note: Due to invalid formatting, all formatting has been ignored.
Chad Carman SR
04 f-350 6.0 PSD crew LB
79 28' Prowler tt
as of 9/22 04 prowler 32ODBHS
