RV.Net Open Roads Forum: Class A Motorhomes: Neglected Maintenence Items
 > Neglected Maintenence Items
Page of 7
JohnnyT
Goshen New York
Posted: 05/16/04 03:39pm Link  |  Print  |  Notify Moderator
Wolfe10( Brett) Just posted an excellent post.... Greasing DP Steering Column about greasing steering columns ... What I am wondering is if there are any other canidates for maintenence items that are overlooked...
JohnnyT
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
J Walker
Oakton, Va
Posted: 05/16/04 04:10pm Link  |  Print  |  Notify Moderator
This is very low tech but it bears noting. The caulk on the outside of the MH will last at most three years before needing to be redone. I hope the new caulk lasts longer than the old. You need to get on the roof and recaulk. Also check around the windows for cracked caulk. Neglecting the caulk on the roof could lead to very expensive repairs in the wood underlayment of roofs.
Jim Walker
2000 34' Damon Ultrasport DP
2009 Malibu
Brake Buddy
JohnnyT
Goshen New York
Posted: 05/16/04 04:29pm Link  |  Print  |  Notify Moderator
It may be low tech but not doing it will result in a high headache if neglected.. Often leaks will not become evident until substancial damage has occured... Thanks for the input
JohnnyT
Colette and Joe
Cashiers, NC
Posted: 05/16/04 04:54pm Link  |  Print  |  Notify Moderator
My Dometic New Dimensions frig just quit working. There is yearly maintinence on them. I never thought to read the book that came with the coach. I didn't know it had to be level if I wasn't using it.
2001 Travel Supreme 36' DP - "Smoky's Den"
2001 Automatic PT Cruiser, Blue Ox tow and break system and Remco trans. pump.
wolfe10
Posted: 05/16/04 05:24pm Link  |  Print  |  Notify Moderator
Annual refrigerator burner tuneup. It is important enough, that if you are under warranty and you do not do it, warranty is up in ONE YEAR INSTEAD OF TWO.
Drain and flush water heater and use PROPER DRAIN PLUG: ATWOOD PLASTIC PLUG. SUBURBAN ANODE ROD.
Lube exhaust brake.
Check battery water.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
steve781
New England
Posted: 05/16/04 07:17pm Link  |  Print  |  Notify Moderator
Does anyone know why Atwood requires you NOT to use an Anode rod? Will it damage the tank?
Steve
2001 31' Four Winds Hurricane Class A 30Q / Ford V-10
Toad: 2004 Honda Element EX 4WD
Aventa II tow bar
Brake Buddy
wolfe10
Posted: 05/16/04 08:11pm Link  |  Print  |  Notify Moderator
Steve,
Unlike Suburban who uses a steel tank, the tank in an Atwood water heater is made of aluminum. No anode is needed to protect aluminum. In fact, aluminum is one of the "least noble" metals and many anodes are actually more noble. So the aluminum tank would actually be the anode and sacrifice itself to protect the anode.
Also, aluminum is a soft metal. Most anodes have iron threads. Dissimilar metal, galvanic reaction and threads on the throw away piece that are likely to harm the tank's threads are reasons that ATWOOD WILL VOID THE WARRANTY OF A WATER HEATER HARMED BY THE USE OF AN ANODE ROD.
The Atwood plastic drain plug available at all RV stores is the right answer.
sparker1
St Petersburg, Fl, USA
Posted: 05/16/04 09:35pm Link  |  Print  |  Notify Moderator
There's been so much discussion here recently regarding AquaHot systems, I went back and re-read the manual. I had forgotten, but a yearly maintenance is called for on the diesel burner of the AquaHot.
I have a man coming tomorrow to do the Norcold refrigerator maintenance required to extend the 2 year warranty for a 3rd year. Only recently learned this when I thought I had a warranty item, so re-read the manual. The problem went away, but now I know the maintenance is required.
Stan
2002 Monaco Windsor DP
2003 Honda Pilot
Travel photos at Photo Gallery
W5IT
Greenwell Springs, LA
Posted: 05/16/04 09:41pm Link  |  Print  |  Notify Moderator
Don't forget to lube the U-joints and splined coupler in the driveshaft.
Don Fauntleroy (W5IT) 99 F-350 PSD w/ a Herrin Hauler bed. Towin a 2006 3612 DS Raptor.
My "Little Red Truck"
Karl in Olathe
Olathe, Kansas, USA
Posted: 05/16/04 09:56pm Link  |  Print  |  Notify Moderator
Any particular caulk you recommend?
Karl in Olathe
2002 GMC Sierra, 2500, 6.0L, 3/4 ton
Keystone Sprindale 255FWBHLS
Page of 7
