RV.Net Open Roads Forum: looking for owners of 2004-2005 Pace Arrows
 > looking for owners of 2004-2005 Pace Arrows
Page of 136
Papa Mel
Glendale, AZ
Posted: 10/19/09 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced the water line to the ice maker on a 2004, Pace Arrow, 37C? Mine disintegrated. Does it require removing the ice maker? Any information would be appreciated.
Mel
alfa38user
Fl
Posted: 10/19/09 10:17am Link  |  Quote  |  Print  |  Notify Moderator
You did not say if it is part of the refrigerator or not and which make of refrigerator you are talking about.
That said, on my Dometic it was necessary to remove the fridge to gain access to the top fitting where the water enters the icemaker. The icemaker itself did not have to be removed. In my case the fridge is not in a slideout but the top end was not otherwise accessible. YMMV.
Alfa38User
Montréal, Canada
Alfa Gold 38 (253 RLTES - 2000)
(SW Florida)
Papa Mel
Glendale, AZ
Posted: 10/19/09 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
The refrigerator (NDR1292) is located in the slideout on the 37C.
Rich & Cheri'
Huddleston, Va
Good Sam RV Club
Posted: 10/20/09 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the water line to the icemaker on my refrigerator, located in the slideout in my 37C. The upper nipple is located behind the upper vent on the outside of the coach. The lower nipple is at the solenoid behind the lower vent in the right hand side. I used a length of clear plastic tubing I bought at Lowe's. There is a knitted fiberglas sleeve on the tube with an electrical heater strip inside which needs to go over the tubing. There was no need to do anything inside the refrigerator.
BRAVE
Maine
Posted: 10/20/09 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.irv2.com/forums/ has a special forum for Fleetwood owners. It's a great place to get the kind of information you're looking for.
Jack
Jack and Julee Meltzer
The RV Makeover Bible
Papa Mel
Glendale, AZ
Posted: 10/21/09 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Rich & Cheri,
Thanks for the info. When I get home it will be fixed.
Mel
rolnhome
Pacific Northwest / Mexico
Posted: 10/24/09 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
Looking for a loud squeak near the floor under the drivers feet. I looked in the front wheel wells in front of the tires. The "bumber/frame" has a "Y" shaped brace going up to a cross support under the floor. I found that "Y" support was busted in half just below the "Y". Being cautious I checked under the passenger side .... same thing. Just wanted to give a heads up. The noise on the drivers side just started. The passenger side looks like it has been that way for sometime but no noise.
Welding shop here we come. I'll try for structural warranty but doubt I'll have much luck.
2005 37C W24 chassis.
We're in Arizona
offshore
Cajun Palms RV Resort, Henderson, LA
Good Sam RV Club
Posted: 11/03/09 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Well hello boys. We full time in our 07 38P Pace Arrow. Talk about slide leaks!!!! My curb side slide was leaking like a water fall. I had to remove all of the wood facing, it was beginning to rot. Then I had to remove the top aluminum rail and reseal it. I am now in the process of replacing the wood facing. My DW says its a rolling piece of S#$%. But it'll be put back together better than when we got it.
2007, Pace Arrow 38P, W-24
Still fulltiming!!!
Jim Bakker
Carmichael, CA, USA
Good Sam RV Club
Posted: 11/15/09 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Subject: replacing toilet seal
The toilet in my 2004 doesn't hold water. I've cleaned the ball and the seal and tightened the clamp; at least one of those things helped, but didn't entirely stop the leak. So I guess it's time to replace the seal. Can someone who has done that on a SeaLand 110 toilet tell me what's involved, how difficult it is, etc?
Jim and Suzi Bakker
Carmichael, CA
2004 Pace Arrow 36B, Workhorse W22
Ultrapower upgrade
2006 Honda CR-V
rolnhome
Posted: 11/15/09 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Did you clean the "inside" of the seal Jim? Mine came with a plastic stick with one end like sandpaper and a cream. You stick this behind the seal with a "cream" that comes with the stick and it cleans the hard deposits from between the bowl and the seal, I was amazed at the gunk in there. You need to clean both sides of the seal. mine is as good as new after doing this, just cleaning the seal on the ball side didn't do much.
Page of 136
