RV.Net Open Roads Forum: looking for owners of 2004-2005 Pace Arrows
 > looking for owners of 2004-2005 Pace Arrows
Page of 118
Jim Bakker
Carmichael, CA, USA
Posted: 05/23/08 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Rich & Cheri' wrote:
glewis wrote:
Took lightning hit thru plug in oxford,Ms week ago. Took out plug, coffee pot,back tv,microwave(still checking),poped fuse on fridge(Found and fixed)I now have no charging system for my batteries. Is my converter in the fuse panel under the sink? Is there a fuse somewhere I can check?Charging batteries with plugin charger for now. also my generator is still putting out voltage but not converting to 12 volts hope it is same fuse or problem. In Jackson, Ms. on a job right now. Thanks GREG Email hgcjlewis@gmail.com
Converter is located under the washer/dryer. You can see it if you take out the grill at floor level unjder the hutch in galley area, (under fold-up table in center). The converter is very difficult to get to and probably requires removing washer/dryer and lifting w/d floor. Can also get to part of the converter by removing the propane detector, although this may be difficult. My detector was "cemented" in with foam insulation. I was checking my propane detector, not converter so I can't tell you any more.
I think the converter location varies, depending on the floor plan. On my 2004 36B it's below the cabinet under the vanity sink.
Jim and Suzi Bakker
Carmichael, CA
2004 Pace Arrow 36B, Workhorse W22
Ultrapower upgrade
2006 Honda CR-V
Paul Turpin
Surprise,Arizona / Cincinnati,Ohio
Posted: 05/25/08 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
GREG, If your converter is under the washer/dryer like mine and you have to replace it, let us know how you had to do it. I looked at my converter and was wondering how hard it would be to replace and if you had to remove the washer/dryer.
Good luck
Paul
Paul and Sue
2004 Pace Arrow 37C
Workhorse
2006 Saturn Ion
dkingdoe
Knoxville, TN
Posted: 05/27/08 06:17am Link  |  Quote  |  Print  |  Notify Moderator
On our 2006 36B it's located below the bottom drawer in the middle section of drawers under the clothes closet.
'06 Fleetwood Pace Arrow 36B / W22
'05 Jeep Liberty-Toad
Bird Freak
Calhoun, Ga.
Posted: 05/27/08 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
My 37C has it under the washer. I had it replaced and the washer had to be removed.
Eddie
2004 Pace Arrow ,Slate 37C
2005 Ford Sport Track, Toad
1999 VW Cabrio Toad
Owner- The Toy Shop-
Auto Restoration and Customs-22years
Ltcspec
plymouth, mn
Posted: 07/03/08 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
It has been over a month since the last post. Hope everyone is out enjoying the summer and the comforts our Pace Arrows offer!!
Bob and Karrie
2004 Pace Arrow 37A
2000 Honda Accord EX
Brakepro Aux Brake!
Rich & Cheri'
Huddleston, Va
Posted: 07/09/08 04:32am Link  |  Quote  |  Print  |  Notify Moderator
Based on seeing high end RV's with drain holes in their awnings, I put a 1/2" brass grommet in the center of my "new correct length" awning approximately 3" in from the roller seam. Finally had the chance, (by accident), to give it a good test to see if it would prevent pooling of water in the open awning. Went out for the day and left awning open. While out, a heavy downpour came through. Awning was fine and no pooling at all.
Bird Freak
Calhoun, Ga.
Posted: 07/22/08 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Brake problems, again. Brakes went out again. I called WH rep. and he told me we should flush our systems with fresh fluid every 2 yrs. I did and it was contaminated. This solve my over heating problems for now. I did have to replace both rear abs sensors in the rear.
Just a heads up to flush the brakes with fresh fluid.
Eddie
Paul Turpin
Posted: 07/31/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Just having a great time traveling and enjoying our P/A.
saber
Indian Harbour Beach, Florida
Posted: 08/25/08 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone switched to the Alcoa Aluminum Wheels that are shown on the Workhorse site? We are sitting around 26,000 miles and I have about had it with the steel wheels from Brazil that standard.
saber
2006 37C
2007 Malibu Maxx SS
Fyr guy
Lancaster, CA
Posted: 08/25/08 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Have not switched mine out to the new wheels but my buddy has a new Southwind with them and they look beautiful! Anyone have a price on them?
Here's something new. Same buddy had his slides become inoperable recently when we arrived at a campground and after several calls, they had hime check the ignition fuse (3 amp in the upper right side of the large black fuse box) it was blown and was replaced now everything worked until he went to his next destination so their appears to be a short somewhere. At least we now know where to check in the event slides fail to open or close.
"Patriotism is not a short and frenzied outburst of emotion but the tranquil and steady dedication of a lifetime."
-Adlai E. Stevenson, Jr.
2005 Pace Arrow 37C "Bronze" Workhorse 8.1 "Ultrapower" upgrade
2004 Honda CRV
Page of 118
