RV.Net Open Roads Forum: looking for owners of 2004-2005 Pace Arrows
 > looking for owners of 2004-2005 Pace Arrows
Page of 188
Jim Bakker
Carmichael, CA, USA
Posted: 01/23/12 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Lobstah wrote:
One of the areas that Fleetwood/Pace seriously fell down on.
Jim
Lobstah,
It's not just Fleetwood and Pace Arrow. At the recent FMCA rally in Indio I attended a seminar about the issue of fogged windows. Many of those attending owned high-end diesel rigs from highly respected manufacturers. The take-away lesson for me was that dual pane windows are not a good choice for use on a motorhome—too much flexing that will cause the seals to fail prematurely.
Jim and Suzi Bakker
Carmichael, CA
2004 Pace Arrow 36B, Workhorse W22
Ultrapower upgrade
2006 Honda CR-V
Lobstah
Northeast
Posted: 01/24/12 04:40am Link  |  Quote  |  Print  |  Notify Moderator
@roln...yes, there are. But they're in Oregon, or Florida, or someplace a long long ways from me. With fuel costs what they are, makes more sense for me to do mine in the driveway.
Jim
2005 Pace Arrow 36D
Very Understanding Wife
2 Boxers
4 Cats
rolnhome
Casa Grande, Az
Posted: 01/24/12 07:13am Link  |  Quote  |  Print  |  Notify Moderator
I think the guy from Oregon is in quartzite. See if he will stop buy your place on the way back to Oregon. He made me that offer a couple of years ago. Sorry I forget his name.
We're in Arizona
Jim Bakker
Carmichael, CA, USA
Posted: 01/24/12 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Subject: replacement Propane Detector
I get false alarms from my propane detector. If vacuuming it doesn't stop them I guess replacement will be necessary. CCI Controls is apparently out of business. If you have replaced your detector, what did you replace it with and where did you purchase it?
Paul Turpin
Surprise,Arizona / Cincinnati,Ohio
Posted: 01/24/12 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I just took my old detector to the RV parts store and they matched up the wires to the old one. Don't remember the name of the detector.
Paul and Sue
2004 Pace Arrow 37C
Workhorse
2006 Saturn Ion
Lobstah
Northeast
Posted: 01/24/12 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
ROln,
I'm near Boston. I don't think the guy from Oregon is going to stop by Boston on his way home.
Helluva trip if he does.
Jim
rolnhome
Casa Grande, Az
Posted: 01/24/12 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
Oops thought you were in CA. Nevermind
Lobstah
Northeast
Posted: 01/25/12 05:16am Link  |  Quote  |  Print  |  Notify Moderator
No worries Hard to keep track of where everyone on these forums are
Jim
seatec
Clearwater, FL
Posted: 02/11/12 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry for the probable repost but the search fucntion on this board has me baffled.
I have 2006 Pace arrow 37c. For some time i have had issues wiht the main and coach battery staying charged while on shore power. recently all my batteries are completely dead and now i dont even show power on the smart power panerl. i reset the breakers under the batchroom synch and checked the fuses thear are in the outside compartment next to the main entanbce door. i am certain i have power going to the coach. what else can i check? thank you
* This post was edited 02/12/12 01:04pm by seatec *
Anthony
06' Pace Arrow 37C
2 Shepherds
2 Pugs
Lobstah
Northeast
Posted: 02/12/12 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds as if at least part of your problem is with your converter. Mine (36D) is located under the drawers in the kitchen, mounted to the floor.
The charging of house batteries and chassis batteries is handled by the converter, which passes power to the battery control unit, which charges both battery functions, house and coach.
Sounds like there may be a couple of things going on. Are you certain you have power coming into the system? My breaker panel under my bathroom sink has a 50amp main breaker in the center. Should have 3 connections...2 black and 1 white. You should be able to measure with a voltmeter set to AC, 120v from either black wire to the center white wire.
The converter is also on a GFI-protected plug/circuit in my 36D, so if the GFI gets tripped, it will shut the converted down and all of your batteries will eventually drain.
The only time I've seen "no power" on my Energy System control panel was when I had a loose neutral connection in that same breaker panel under the bathroom sink that the main 50amp breaker is in.
Let me know what you find...or if you have any questions about anything I've posted here in the reply.
Jimb
Page of 188
