RV.Net Open Roads Forum: scraping off old caulking around windows and replacing w/ new
RV.net
 > scraping off old caulking around windows and replacing w/ new
mco1314
granada hills, ca usa
Posted: 10/22/04 11:49pm Link  |  Print  |  Notify Moderator
Does anyone know if they have caulking removal liquid? Am i opening up a can of worms by doing this due to probably not sealing the window properly with the new caulking. what is the cost to have someone remove the windows and replace the caulking?
thanks
mike
98 jayco 28' class c
BobsYourUncle
Surrey, BC Canada
Posted: 10/22/04 11:55pm Link  |  Print  |  Notify Moderator
IMO, the best and only caulking removal liquid is a blunt putty knife and a ton of elbow grease. Blunt so you don't dig in and damge the surface. Thats what I used when I peeled my roof off. Any liquid that is strong enough to disolve caulking, is strong enough to ruin a lot of other things.
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Check Out My Rebuild Project (Updated June 15, 2006)
Project Feedback
Dick_B
Palos Heights, IL USA
Posted: 10/23/04 08:45am Link  |  Print  |  Notify Moderator
RV Today had a segment where they showed how to replace a window in an RV and it didn't look too bad. There is a flange on the inside that you have to take off; it holds the window in place, remove the window from the outside, scrape off the old sealant, replace the window and reseal. Bill Gerr made it look easy!
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Joy
Henderson KY 42420
Posted: 10/23/04 10:02am Link  |  Print  |  Notify Moderator
I watched the repairmen replace a window in our coach and that is exactly what they did - unscrewed the screws on the inside, removed the inside frame, removed the window, cleaned off the old caulking around the opening, applied new caulk, placed the new window in the opening, replaced and screwed the inside frame in. Took them about 20 mins, tops. It was a two man job, tho, to be sure the window stayed in place until it was attached.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Katie-Mini Aussie
Sam-Calico Fat Cat
Maggie-Chihuahua
2003 38'Phaeton DP
2006 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
