RV.Net Open Roads Forum: Truck Campers: Truck Campers- Truck Bed Liners
 > Truck Campers- Truck Bed Liners
BradW
Mayor of Flat Rock
Posted: 11/26/04 07:36am Link  |  Print  |  Notify Moderator
Plastic Drop-In Liner Pros:
- Better distributes the force of impacts, better at protecting the bed from dents
- Less expensive than sprayed-in liner
- Easily removable
- Can be installed by owner
Plastic Drop-In Liner Cons:
- Slick surface allowing camper movement
- Not repairable
- Water tight which can let plywood camper bottom sit in 1” – 3” of standing water
- Very difficult to use with the HappiJac style front anchors
- Water, salt, sand, grit, etc still get under bed liner and cause damage
- Liner vibration will damage truck bed paint
- Liner reduces distance between wheel wells by 1” to 2”
- Too easily removable, with tailgate down, some can blow out
Sprayed-In Liner Pros:
- Can be repaired
- Rough surface helps limit camper movement
- Works well with the HappiJac style front anchors
- Seals the bed surface, water, salt, sand, grit, etc cannot get under bed liner and cause damage
- Bed drain holes are left open so rain drains from the truck bed
- Works well with heavy-duty rubber bed mat
Sprayed-In Liner Cons:
- Less affective at distributing the force of impacts and protecting the bed from dents
- More expensive than drop-in liners
- Not removable
- Cannot be installed by owner
Note: Apparently some drop-in plastic bed liners now come with a sprayed on non-skid surface on the top side of the liner to reduce sliding. Not sure if this is also on the underside of the liner to prevent the liner from sliding in the truck bed surface.
* This post was last edited 02/26/05 11:37am by BradW *   View edit history
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
Ponderosa
Western US
Posted: 11/26/04 08:09am Link  |  Print  |  Notify Moderator
I think you missed the main "pro" of plastic liners. They distribute the force of impacts protecting the bed from dents and scratches. I have never had a spray in liner so I don't know if they are effective at stopping the dings and dents from shifting loads or objects. I have seen plenty of them all scratched and gouged, though.
My factory plastic liner is coated with a rubbery compound that makes it much more resistant to slip than a regular drop in liner is. It is still slick enough that I can slide and drag heavy stuff around without a lot of difficulty and I don't scratch the bed either. And, with a rubber mat on top, the camper goes nowhere.
I think a coated plastic liner works great for the truck camper owner.
2011 Coachmen Freelander 27QB
2013 Jeep Wrangler Unlimited Sahara
BradW
Mayor of Flat Rock
Posted: 11/26/04 08:20am Link  |  Print  |  Notify Moderator
Excellent point. I went back and added it to the original post above.
Thanks,
BradW
Pook
NYC, NY, USA
Posted: 11/26/04 08:25am Link  |  Print  |  Notify Moderator
My plastic liner has problems fitting the camper. Doh.
joemyers
Houston, Tx, USA
Posted: 11/26/04 09:00am Link  |  Print  |  Notify Moderator
Main con for drop in liners is that they vibrate and will wear the paint off your bed.
Second con is they are slick.
Joe, Retired & on the road whenever I want, KeepMov'n
2000 Dodge/CTD 3500 DRW SLT+ 6 speed 4x4, 3.54 rear, Exhaust Brake
2003 Lance 1121 with all the options plus
1999 Toyota Taco V-6 5 speed 4x4 Toad, SMI wireless power brake control
BradW
Mayor of Flat Rock
Posted: 11/26/04 09:22am Link  |  Print  |  Notify Moderator
Another good point.
mathewsw
Jacksonville, Florida
Posted: 11/26/04 09:23am Link  |  Print  |  Notify Moderator
I HAVE THE "BED RUG" LINER IN MINE, AND I THINK IT IS GREAT.
2000 Lance 1130 Loaded
1993 Chevy 3500 TD, 4X4, Reg. Cab, SRW, Rancho 9000X, Air Bags, Rickson 19.5X7.5 W/Dunlop 245X70X19.5 H, Happijac's, Lance cab over struts.
kehale
Arizona 2011
Posted: 11/26/04 09:29am Link  |  Print  |  Notify Moderator
Spray in liner and heavy duty rubber mat gets my vote.
I have that on two trucks.
I did the plastic liner in the past...I think it's the worlds largest piece of sandpaper. (taking the paint off my bed)
-T
06 Lance 1181
Little Kopit
TheMaritimes.ca
Posted: 11/26/04 09:31am Link  |  Print  |  Notify Moderator
- More expensive than sprayed in liner
- Not removable
Brad, Note a need to edit line 3 here. I think you mean plastic drop in liner.
Another con to drop in bed liner. They eat up more room than a spray in liner, which can be very significant, especially at the wheel wells.
& I, I took the road less travelled by.
My Photo Album, featuring Labrador 2006
BradW
Mayor of Flat Rock
Posted: 11/26/04 09:46am Link  |  Print  |  Notify Moderator
Yes, that is what I meant to say!
Thanks,
BradW
