RV.Net Open Roads Forum: Class A Motorhomes: Replacement Tires - 245/70R/19.5
 > Replacement Tires - 245/70R/19.5
2chiefsRus
USA Somewhere
Posted: 12/12/04 05:23am Link  |  Print  |  Notify Moderator
We are considering replacing our tires on our 1999 Monaco LaPalma. We only have 18,000 miles on the coach but the age of the tires concern us. The coach sat for over a year on a dealer lot in Ohio before we bought it. We stored it inside for the next 3 years but it has been sitting in the Florida sun for the last 18 months. The tread is still good and there are no obvious signs of cracking or other damage. Any suggestions as to whether we should replace them and if so, with what brand. Thanks for any thoughts.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
jy
south east mich.
Posted: 12/12/04 06:52am Link  |  Print  |  Notify Moderator
What kind of chassis,and what kind of tire?
99 Coachmen 322QB, Ford V10,18 foot Load King open trailer, 2007 Mustang GT Toad, Gibson exhaust,Royal Purple lubricants.Recently retired and planning on doing more RV'ing.
Sully2
Cincinnati
Posted: 12/12/04 06:55am Link  |  Print  |  Notify Moderator
You have exactly the right idea. My only suggestion is that if you are NOT gong to use the coach this winter...put them on in the spring before you start traveling. That direct hot sun "eats" tires.
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
dutch_man
Southwest Florida
Posted: 12/12/04 06:59am Link  |  Print  |  Notify Moderator
Is there some treatment you can put on the tires to slow down the cracking?
What about covering the tires to keep the sun off while parked for extended periods?
dutch_man
States we have camped in:
2chiefsRus
USA Somewhere
Posted: 12/12/04 11:04am Link  |  Print  |  Notify Moderator
Ford V-10 and Goodyear G159's.
Sully2
Cincinnati
Posted: 12/12/04 07:03am Link  |  Print  |  Notify Moderator
BOTH! Use 303 Protectant ..AND use tires covers while parked for any more than a few days
Road Dog
Waukesha,WI
Posted: 12/12/04 09:18am Link  |  Print  |  Notify Moderator
I replaced the tires on my 99 Bounder cuz of age and also the very hard ride I got from the Goodyears. I went with Toyos and after 6000 miles I can't believe how much nicer the ride is. Doesn't bang hard when you hit tar strips and joints in the road. I would definitely change the tires on your rig, too much sitt'n time is not good for tires. They can dry rot from the inside. Its not worth the risk. Road Dog
Tireman1
Springfield,Oregon- Lane
Posted: 12/12/04 10:02am Link  |  Print  |  Notify Moderator
Suggestion: with you having stored inside for 3 yrs and if it is not showing any signs of cracking (and check the inside also) if I owned the coach I would put 2 new tires on the front and run the ones you have now on the rear... Tires do not rot from the inside but the tubless linner can get a little setup and not stop a nail hole leak as good as it should... damage comes from the sun rays... and nothing I have heard of that will help, other than covering with wheel covers... (retired 49 yrs of auto and motorcoach service)
I agree with Road Dog that Toyo tires are good...
1992 F-250 4x2, 7.3 Banks Wastegate Turbo & Exhaust, Airbags, Raybestos Super Stop Pads, RS 5000 Rancho Shocks, 35 gal aux tank
(4)Michelin XPS Rib/siped. - 30' Knight,King of Road, Slide 5th Wheel, 18K Reese Swivel,
Earthmate GPS/2004, HP zv5000 AMD64
TireGuy
Ohio
Posted: 12/14/04 07:29am Link  |  Print  |  Notify Moderator
Goodyear now makes their RV specific tire, the G670 RV , in this size. From all I have talked to and read from others, this is an awesome tire. Runs cooler than the typical truck tire and rides smoother than the typical truck tire.
havin fun
we are home due to illness
Posted: 12/14/04 10:41am Link  |  Print  |  Notify Moderator
we put the goodyear rv -670 on ours like them a whole lot . the ride might be alittle harder .had the 159's before was afread of them because they were 5 yrs old .
retired
havin fun with 1999 georgie boy 3515
and the wife too .
V-10 ford ">">">">">">
SLOW DOWN AND SMELL THE FLOWERS
