ken burke
usa
Oh yea . . . . check the plug on your hot water heater. Replace it if it looks corroded. I don't know why, but they put these cheap plastic plugs in the hot water heater and they fail after 2 or 3 years.
Mine was so bad I had to take it out in pieces. Then I screwed up the tank's pipe threads and had to use a tap. This would be a good time to flush out the hot water tank.
2011 Ford F-350 6.7 diesel, Crew Cab, LB, SRW, 4X4, White
Cedar Creek 34SB, 37 feet 5th wheel, Reese 20K Hitch
"So many questions, so little time."
ENGR55
Las Vegas, Nevada
Firedude,
Thanks for the pointers. Fellow fireguy here. I appreciate the effort you put out for fellow RV folks. I will check my water heater today =)
fetch13712
US
Great Stuff, thx...-Mike
YaYa and G
Odessa TX
What a wealth of helpful information. I copied and pasted fireguy's Maintenance Reminder and added in many of the other contributions. We now have some great guidelines thanks to you all. We are newbie full timers and need all the help we can get.
Thanks!!
Glen & Sue
Glen & Sue
Sparky the Schnauzer
2011 Heartland Big Horn
2011 GMC 3500HD SLT DRW 4x4
Full Time Livin'& Lovin' It
Bigger Dog
all over
On the subject of water heater wear and tear: does anyone turn the water heater off when not in use? Ours seems to heat very quickly. Corrosion is a chemical reaction, which goes faster at a higher temperature. I don't have a textbook to look up the q10 of rusting, but if it were 2: 140 F - 70 f= 70 degree hotter. 70 / 1.8 = 40 C.So 2 to the fourth power is 16. corrosion goes 16 times faster if heater on. If water heater on 4 hours/day, it would corrode about 5/24 as fast as 24h/d. plus less heat to fight w ac if used.
64thunderbolt
Az
speaking of wh, mine has a metal plug I assume is an anode. Can't break it loose. Really don't want to mess the threads up But want to get it out and clean up the heater. Any suggestions?
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
stamppeddler
British Columbia
Thanks for the to do list. We're still newbies at full timing in our 5er. We will be leaving Yuma in a couple of weeks for the coast. I'll be sure to go over the points mentioned before we head out. Thanks for taking the time to post. Cheers
Laszlo & Gail Soltesz
Kamloops British Columbia
2010 Ram 3500 HD Mega Cab 6.7 Cummins SRW
2013 Mountaineer 295 RKD
Anbrusten
Portland, Oregon
Great list and info..., were going full time in about a month and continue working for six more years before we hit the road
Andy & Becky Rusten
W7ATR & N7SYC
Opal & Pretzel (The wiener dogs)
1998 Mountain Aire 40' DP
2007 Jeep Grand Cherokee Laredo
CabinetmakerII
Idaho
My wife and I are making our first trip to Alaska this summer. In preparation for the trip I wanted to make sure the coach was ready for the road. Unable to do the work myself, I took our 43' Toyhauler into a local tire shop to have the wheel bearings inspected and repacked. During the process, the technician discovered one of the brake auto-adjusters had broken and was in need of replacement. Also, while the tires were off, I had them inspect the shackles and spring mounts. After only 5 years, they were shot. The dry-bolt system installed at the factory had failed. I had them install a wet-bolt system from Dexter Axel. Although it was a very expensive day, the frustration of having a catastrophic failure in the middle of Canada or the out-back of Alaska hopefully has been avoided. Long way around to add Spring Shackles to the list.
Cabinetmaker
2011 F-450 4X4, Companion 18K Hitch, Air Bags
2012 Cyclone 3800, 5th Airborne Kingpin
2006 700 Arctic Cat ATV (X2)(Retired)
2014 Kawasaki Tyrex 4LE Side by Side
TheWanderingRV
Maine
Awesome tips! My girlfriend Kayla and I (Bill) just started fulltiming this past month.
How often would you recommend doing all these things?
