RV.Net Open Roads Forum: Full-time RVing: Maintenance Reminder for Full-Timers
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Maintenance Reminder for Full-Timers
Page of 7
ken burke
usa
Posted: 04/28/10 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Oh yea . . . . check the plug on your hot water heater. Replace it if it looks corroded. I don't know why, but they put these cheap plastic plugs in the hot water heater and they fail after 2 or 3 years.
Mine was so bad I had to take it out in pieces. Then I screwed up the tank's pipe threads and had to use a tap. This would be a good time to flush out the hot water tank.
2011 Ford F-350 6.7 diesel, Crew Cab, LB, SRW, 4X4, White
Cedar Creek 34SB, 37 feet 5th wheel, Reese 20K Hitch
"So many questions, so little time."
ENGR55
Las Vegas, Nevada
Posted: 09/18/10 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Firedude,
Thanks for the pointers. Fellow fireguy here. I appreciate the effort you put out for fellow RV folks. I will check my water heater today =)
fetch13712
US
Posted: 03/14/11 12:29am Link  |  Quote  |  Print  |  Notify Moderator
Great Stuff, thx...-Mike
YaYa and G
Odessa TX
Posted: 04/30/11 06:51am Link  |  Quote  |  Print  |  Notify Moderator
What a wealth of helpful information. I copied and pasted fireguy's Maintenance Reminder and added in many of the other contributions. We now have some great guidelines thanks to you all. We are newbie full timers and need all the help we can get.
Thanks!!
Glen & Sue
Glen & Sue
Sparky the Schnauzer
2011 Heartland Big Horn
2011 GMC 3500HD SLT DRW 4x4
Full Time Livin'& Lovin' It
Bigger Dog
all over
Posted: 05/02/11 08:23am Link  |  Quote  |  Print  |  Notify Moderator
On the subject of water heater wear and tear: does anyone turn the water heater off when not in use? Ours seems to heat very quickly. Corrosion is a chemical reaction, which goes faster at a higher temperature. I don't have a textbook to look up the q10 of rusting, but if it were 2: 140 F - 70 f= 70 degree hotter. 70 / 1.8 = 40 C.So 2 to the fourth power is 16. corrosion goes 16 times faster if heater on. If water heater on 4 hours/day, it would corrode about 5/24 as fast as 24h/d. plus less heat to fight w ac if used.
64thunderbolt
Az
Posted: 03/26/13 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
speaking of wh, mine has a metal plug I assume is an anode. Can't break it loose. Really don't want to mess the threads up But want to get it out and clean up the heater. Any suggestions?
Glen
04 Tail gator XT 34' 5th wheel garage model
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" turbo back exh sys
trucool trans cooler added
08 Arctic Cat Prowler 700XTX
Page of 7
