RV.Net Open Roads Forum: You probably should get a new Carbon Monoxide Detector!
 > You probably should get a new Carbon Monoxide Detector!
ARcruiser
Benton, AR USA
Posted: 01/08/05 11:59pm Link  |  Print  |  Notify Moderator
If your rig is more than 2 or 3 years old, you probably should....
Get a new Carbon Monoxide Detector! --- errr... ALARM
That's right. Did ya'll know they have very short life-spans?
....as in 3 years for some models? And my research says 5 at best.
I had read this before (in other forums)... but, until tonite, never thought about not seeing it in this forum.
It's a very small investment for your safety and peace-of-mind.
Carbon monoxide (CO) is the leading cause of fatal poisonings in North America.
Now someone else can tell us if the LP and Smoke detectors should be changed regularly.
Unintentional Deaths from Carbon Monoxide Poisoning in the United States, 1988-1996. (based on CDC data)
* This post was last edited 01/09/05 02:55am by ARcruiser *   View edit history
2 Big Cruisers, The Little Man, and Bailey / ARcruiser's Class B's (the first 8)
Rig #8 Under Construction! / Here's the Project Thread - I'm actually working on it again!
RVJohn
Posted: 01/09/05 01:41am Link  |  Print  |  Notify Moderator
My question is when do you know when to replace it?Does it just stop working?
tow vehicle-2004.5 Dodge 3500 SLT Quad Cab 4x4-600 Cummins Turbo Diesel-4-speed automatic,48RE,short bed-SRW
Prodigy brake controllar
2001 3280RL Montana
reese 16K slider,roll&lock bed cover
Yahama EF300iSEB
Garmin 7200 GPS
5th Air Borne/sidewinder
ARcruiser
Benton, AR USA
Posted: 01/09/05 02:48am Link  |  Print  |  Notify Moderator
From what I have read most are good for 3 to 5 years.
A quote from
this guy's website on CO Alarms.
CO alarms have a maximum 5 year life and should be replaced every five years at a minimum.
The paperwork for your detector should tell for sure, or go to the manufacturers site.... which may or may not help. I know (well, I'm pretty sure) that our last van had an Atwood. Their site doesn't say.
The Safe-T-Alert Website has an article listed under Press Release titled TIME TO REPLACE YOUR CO DETECTOR FOR A CO ALARM
Here's an excerpt:
The industry agrees that the service life of an alarm or detector is 5 years.
....but info in other forums indicate that paperwork for some detectors say they should be replaced after as little as 2 years.
Sounds like UL Standards were revised in '98, and they quit calling 'em "detectors" and started calling them "alarms". Looks like newer "alarms" should be good for 5 years? But older "detectors" often had shorter lifespans?
Kidde's website has an article titled Replace CO Alarms Every 5 Years.
Heck, I dunno. It just seemed like an important subject that oughta get mentioned...
* This post was edited 01/09/05 02:59am by ARcruiser *
ARKY2
AR
Posted: 01/09/05 10:31am Link  |  Print  |  Notify Moderator
delete
* This post was edited 01/20/05 01:38pm by ARKY2 *
Gene in NE
Omaha
Posted: 01/10/05 10:34am Link  |  Print  |  Notify Moderator
harleyrider - You asked a good question. Here is what you can do if you have a CO detector in your house or in your RV and it is powered by 110V. Plug in an extension cord, then plug in the detector, and carry it to a tailpipe of a running vehicle. It should alarm. If it is battery operated, merely take it to the tailpipe and again it should alarm. If ever you have a CO problem while sleeping, this is the alarm you would want to hear.
2002 Trail-Lite Model 211-S w/5.7 Chevy (click View Profile)
Gene
carringb
Corvallis, OR
Posted: 01/10/05 01:27pm Link  |  Print  |  Notify Moderator
No!
Yes, it will alarm. It will also make it permanently non-effective at 15 ppm, where it should alarm. After doing that just 1 time, it will no longer alarm at a level that is still safe to breath.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
carringb
Corvallis, OR
Posted: 01/10/05 05:28pm Link  |  Print  |  Notify Moderator
I should mention my warning applies to biomimetic and metal-oxide detectors. The ones with a digital readout are electrochemical (usually, but can be metal oxide). Electrochemical ones proabbly will not be damaged by the exhaust of a well running car, and if it is damaged, teh display should warn that the sensor is no longer any good.
