RV.Net Open Roads Forum: Travel Trailers: Awning Cleaning
 > Awning Cleaning
WayneNJoyce
Olathe, KS/USA
Posted: 02/25/05 05:49am Link  |  Print  |  Notify Moderator
I heard about a way to clean an awning and was wondering if anyone has tried it. I guess you take Clorox and dilute it (I’m not sure how much). Then wet the awning with the solution and without letting it dry roll it back up. Then after about an hour unroll the awning and rinse it off. Anyone heard of this? Will it fade the color in the awning?
WayneNJoyce
2003 Chevy 2500HD Duramax/Allison
1999 30' American Star Fifth Wheel
heavyputer
Ontario, Canada
Posted: 02/25/05 06:51am Link  |  Print  |  Notify Moderator
[/quote]Will it fade the color in the awning? For sure. Clorox will fade anything if left on long enough. My GW washed a set of snooker balls with household bleach thinking she was doing me a favor. They are now pink.:o
Note: Due to invalid formatting, all formatting has been ignored.
If at first you don't succeed, skydiving is not for you!!!
bldrbuck
one or the other
Posted: 02/25/05 06:57am Link  |  Print  |  Notify Moderator
There are awning cleaners on the market that are much better than bleach. Check with your local RV Store, Wal*Mart or Camping World. If you do decide to use the bleach be very careful when walking under the awning or you will have spotted clothing.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 35' King of the Road 5er, 192 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 2 Trogan T105 Batteries, Me, my wife and 2 maltize furkids.
MealsOnWheels
NE Ohio
Posted: 02/25/05 06:59am Link  |  Print  |  Notify Moderator
I've had good results with the spray on awning black streak cleaner (pick it up at Wally World). Just spray it on,wait awhile, scrub it with one of those long handled scrub brushes, and spray it off with hose. A cheaper alternative, and just as good, I think, is to pick up a bottle of Simple Green or Mean Green from the Dollar Store. Costs alot less, and is also effective. The job can get kind of sloppy.....especially when you are under the awning and get on the wrong side of the water roll off! I usually save it for a sunny day and just get prepared to get wet! Good Luck.
Steph (the one who's always on here!) and Randy (the one who has to listen all about it!)
Alex (15) Duke & Dixie (The Terrier Terrors)
Canadian Camper
Iroquois, Ontario, Canada
Posted: 02/25/05 07:53am Link  |  Print  |  Notify Moderator
Here's what I do . I take a 5 gal pail, fill it with water, add i cup of bleach and ad a couple ounces of dish washing liquid to the mixture. I then apply the mixture to the awning fabric using a automotive soft scrub brush with an extending handle. I then rinse off the awning with a hose. The awning fabric comes completely clean with little effort. Works for me.
VE3COK
2009 Jayco 30G Greyhawk Class 'C' Motorhome
Wife, 3 Kids ,2 Shelties and 1 Pug
campincandice
Metro Chicago
Posted: 02/25/05 08:37am Link  |  Print  |  Notify Moderator
We apply a Simple Green solution, roll it back up before rinsing, move on to washing the rest of the camper. When we're done we open up the awning and rinse. Clean as a whistle!
Candice
Molly - black lab
Sabbath - chocolate lab/weimaraner
No RV at the moment
Formerly:
2004 Trail Lite 8306S
2001 Suburban 2500/8.1
jeannie_rdh
Mi
Posted: 02/25/05 11:16am Link  |  Print  |  Notify Moderator
We use Simple Green too. Spray and roll up for a bit. Unroll and run a Mr Clean Magic Eraser over it and PRESTO! Good as new!
NCHornet1
Mt. Airy, NC.
Posted: 02/25/05 11:28am Link  |  Print  |  Notify Moderator
I also use the Simple green, you can buy it in the concentrate and it goes a long way. To protect the finish I use protect-all.
Kevin L.
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
Cmpnfsh
Wisconsin
Posted: 02/25/05 11:39am Link  |  Print  |  Notify Moderator
We, too, use Simple Green. It goes a long way and is much less expensive than the rv awning cleaners. Bleach will discolor the mold, but it doesn't kill it so keep that in mind when using it. I found out the hard way. Best of luck.
ib516
Up here!
Posted: 02/25/05 12:45pm Link  |  Print  |  Notify Moderator
Check your owners manual for instructions on cleaning the awning. Mine is a Dometic (A&E). It says to use a little bleach, and dishsoap mixed with water in a bucket. You fully unroll awning, wash the bottom 3', roll it up a bit, wash the next 3', and so on. Once you have it washed, leave it rolled up for a bit, then unroll and rinse. I used a carwash broom type brush to do it, worked fine.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY
Scangauge2 for Boost, Coolant temp, rail press & Trans Temp
PICS
Collision Reconstructionist, CDR (automotive "black box") download technician/analyst
 > Awning Cleaning
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
