RV.Net Open Roads Forum: Forum Technical Support: Tips to reduce signature pictures
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Tips to reduce signature pictures
Forum Technical Support Related Tips
RVSnowbird
OR-NV-AZ-OR
Good Sam RV Club
Posted: 03/30/05 03:02pm Link  |  Print  |  Notify Moderator
I've reconstructed my signature to conform to the new standard and it's not that hard to do. I will miss the link in the license plate that showed a member how to get their own as well as the link in the rv picture to the enlargement. Those I can do without. The link in the logo however is necessary and it is still there.
There are two ways to put pictures into signatures and I used both of them. The upper box in "My Preferences" is what we had before in "My Profile" and is used for the text script of URL's.
My license plate URL was to a thumbnail and adding "Height=70" to the end of it, enlarged it to the maximum allowable height.
The logo was actually 75 pixel height so adding "Height=70" to it reduced it to the same as the license plate. The link was created by entering it as a Link to the website and entering the URL of the picture as the description.
The picture was a little different as it must be within the 20kb, 500x70 pixel size before being uploaded to RV.Net. I found this very easy to do using a freebie download from www.IrfanView.com. Under Image, click on Resize/Resample and you will get this:
Under "Set new size", enter "70" at Height and the width will automatically adjust to correct proportions. Save the change to your computer, Confirm the file size is 20kb or below and upload it in your preferences!
I'm sure there are other graphic programs capable of doing this so feel free to add them.
Added in edit: For those using IrfanView and concerned with reducing the kb's, doing a second save or "save as" will get you this:
As you can see, it has a slider to increase or decrease the overall density and I just leave it in the middle as shown.
Here's an added benefit of using IrfanView that many other programs can do too - custom frames. I pasted the license plate to MS Paint, drew a wide box around it to save it, pasted it in IrfanView, cilcked on Effects and then 3-D Button and the one in my signature is the result.
* This post was last edited 04/30/05 03:10pm by RVSnowbird *   View edit history
have you checked out the new RV.net Blogs yet?
Deceased 2/28/08 RIP
JUrban
Delaware
Posted: 03/30/05 04:56pm Link  |  Print  |  Notify Moderator
Sorry Guy, but I think you'll agree the picture quality is terrible. Not your fault, obviously. I tried for two days to get something you could see and allow folks to get a bit of information from it, but I finally gave up.
A suggestion for the powers--- Expand the picture height and only restrict file size. I know you're trying to limit total height of the signature blocks, but this is what you're going to get, and I think it really detracts from the forum quality.
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
tcsmith
Centennial, Colorado, and Charlottesville, VA USA
Good Sam RV Club
Posted: 03/30/05 05:03pm Link  |  Print  |  Notify Moderator
Some other programs can help with the quality issues, but they'll cost some too. I design websites for Nonprofit orgs on the 'side' and use a low-cost photo program called Paint Shop Pro by Jasc software (owned by the big boys at Corel Corporation). Less than $100... a great price when compared to the $500-600 programs like PageMaker, PhotoShop, etc.
It's an economical "professional" photo editor and can retain a lot of the quality while keeping size/dpi way down.
Surely there are others without having to use a $600 program like PageMaker.... In any case, just a tip that there exists a reasonable program with excellent capabilities in this area.
Thanks for the tip RVSnowbird!
PS: Paint Shop Pro made the sig below. Set it to 100x500 and told the 'size optimizer' to make it no bigger than 30k. There you go!
* This post was edited 05/05/05 10:59pm by tcsmith *
Tracy & Jennifer Smith + 5 Boys (no room for a dog!)
1999 Dodge Ram Maxi-Wagon 3500 and 1999 8300 Trail-Lite TT
DavidG
near Seattle, Washington, USA
Good Sam RV Club
Posted: 03/30/05 05:16pm Link  |  Print  |  Notify Moderator
There is a free online tool at www.giftools.com that you can use to compress an image by reducing the redundant data bits that make up the image. Sort of like taking a picture with a 5 megapixel digital camera set at 1 megapixel. Only catch is that the image must be hosted on the web and have its own URL. Might need to play with it some to figure out if it’s better to compress an already small picture, or to compress a large picture and then compress it. I’ll see if I can play with this later and report back.
* This post was edited 03/31/05 10:52am by DavidG *
David and Laura G
Click here for my RV Tips
2003 Suburban K2500LT 4WD, 8.1L, 3.73, Autoride 14-16 mpg hwy, 10-12 city, 8 towing
2008 Adirondack 31RK-DSL
Prodigy brake controller, Surge Guard
RVForever
Posted: 03/30/05 05:21pm Link  |  Print  |  Notify Moderator
RVSnowbird,
Unfortunately the new rules call for one picture 500x70 at less than 20kb.
I used the same program as you and created one picture in a panorama of three pictures resized 70px high and total equal to less than 500px.
It came out fairly decent, as far as linking from a signature photo, I may be wrong but I do not think the new rules permit it.
You can link externally from the signature text box, to your singles site. I tested that feature and it works. Look at the rvnet link in my sig.
Admin tell me there is a thirty days grace period to get the signatures into the new form.
robsouth
Too Near Atlanta, GA
Good Sam RV Club
Posted: 03/30/05 05:50pm Link  |  Print  |  Notify Moderator
I also used IrFanview and I think it came out ok. Whatcha think?
* This post was edited 03/31/05 12:16pm by robsouth *
Dodge Ram 3500 Cummins Turbo Diesel Dually
Terry 22U
Regal 1900LSR
"Great minds like a think"
RVForever
Posted: 03/30/05 05:58pm Link  |  Print  |  Notify Moderator
Robsouth,
Your picture looks good, even the text in the pictures is readable.
Musicman
Wenatchee, WA
Posted: 03/30/05 06:27pm Link  |  Print  |  Notify Moderator
I'm not having any trouble with the size, but I'm not sure that my Signature Picture is going to appear in my Signature. It does not appear when I "preview" my signature. It is indicated as the default signature picture in My Preferences. How do I get it to appear in the actual signature?
On Edit: What do you know? there we are. Forget my inquiry.
Musicman
FMCA #F333309
'97 Winnebago Vectra
'01 Blazer LT
RVSnowbird
OR-NV-AZ-OR
Good Sam RV Club
Posted: 03/30/05 07:07pm Link  |  Print  |  Notify Moderator
all good feedback, thank you. I will still be working on mine a little more as I think I can clear up some of the fuzziness.
I checked out the www.giftools.com DavidG recommends but IrfanView has it beat too as after making changes, a second window opens to easily change the compression to reduce the kb's when saving it. Actually, that is what I am going to do as only the license and logo need correction.
As RVForever says, "Unfortunately the new rules call for one picture 500x70 at less than 20kb." which is very true but pictures can be put in as a urls as well, which is what I did. That is how I came up with the first two pictures including one with an embedded link. It maxed out at the allowable 255 character limit so it should be ok. As for the new rules allowing a link in a picture, I would think that as long as it does not go over the 255 limit, it will pass. I'll confirm this with Admin myself just to be sure.
skipnchar
Google Kansas USA
Posted: 03/30/05 07:21pm Link  |  Print  |  Notify Moderator
I resized mine just using MS Paint which is free on most OS installs. Ain't pretty but????
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
