Open Roads Forum
Print  |  Close
Topic: 120/240 volt 30-amp generator outlet question
Posted By: jestes on 05/16/05 08:49am
I have a generator that has a NEMA 120/240v 30 amp plug with 4 prongs. My RV has a 30-amp 3 prong plug. I have been unable to locate an adapter that would allow me to plug my trailer into the 30-amp outlet.
Is there something I can do to convert this outlet to a usable power source?
Jennifer
Posted By: sandygirl on 05/16/05 09:56am
Yes, buy the parts at home depot and make your own adapter.
Sam
[/purple][b]Kari & Sam Hurricane, Utah[/b] 2004 34' Damon Challenger 315
Note: Due to invalid formatting, all formatting has been ignored.
Posted By: Momma on 05/16/05 11:24am
I went to ACE hardware and made my own.
Posted By: Mach1 on 05/16/05 11:34am
Lowes had everything I needed. I got a single outlet box with a angle bracket to secure it to the generator. A female 30 Amp RV receptacle, metal wall plate, and a foot or so of 10/3. It's really just a pigtail but I used the box method so it wouldn't dangle. My generator has a three prong locking plug for the 110 and 4 prong for the 220 so I used the 3 prong. Lowes even had the large rubber insulation boot for the plug.
Posted By: sandygirl on 05/16/05 01:10pm
You can buy the three prong twist lock adapter but you can't get a 4 prong 120/240 30 amp.
Sam
Posted By: Capt-Ron on 05/16/05 01:32pm
My generator came with the 4 prong 120/140V 30 amp plug to that fits the receptacle. They are also used for boat shore power cords and available at a marine store if you have one in your area.
Capt Ron
2001 F-250 SC, SB, 5.4L, Auto
2008 30' Salem LE Bunkhouse
Honda Eu2000i's Paralleled W/extended Fuel System
2008, No Longer Full Timing After 5 Years!!!
2010, On the road again SOLO.
Posted By: Kenneth on 05/16/05 02:27pm
NEMA 14-30R receptacle on the generator?...125/250 volt, 3-wire, 4-pole, locking? You need the mating NEMA 14-30P plug, a short length of #10/3 portable cable (extension cord wire), and a NEMA TT-30 connector for the RV receptacle. These are available as a 30 Amp Female Connector with stripped ends for about $6-$7. Of course, you wire to one hot leg, ground, and neutral on the generator. Can the generator handle that much imbalance on the legs?
Ken
Posted By: Deen on 05/16/05 07:50pm
Ken
That could cause a problem all right! Too many years since electrical theory for me!!
Print  |  Close
