RV.Net Open Roads Forum: Travel Trailers: My newly restored 1968 Trotwood
 > My newly restored 1968 Trotwood
Page of 5
Kamakiri
Buffalo, New York
Posted: 06/13/05 05:09am Link  |  Print  |  Notify Moderator
Being new, I thought I'd share pics of my newly completed "restoration".
After almost four months of constant work, she's all done and complete! Replaced the ceiling, repaired the roof trusses, sealed the top roof, repainted the whole thing, new tile floor, new propane lines, new tires, wheel bearings done, new clearance lights, propane tank holder, new water pump, restitched every single cushion cover, new table, plus a lot of miscellaneous wiring and vacuuming of mouse poop, this former derelict trailer is NY state inspected and had it's first new adventure at jellystone Park in Western New York on Memorial Day weekend
Here's a before shot:
1985 Chevy Conversion van
1969 Coachmen 24' (the new project dynamic)
1970? Cox Commander 515 Popup
A wife, two small boys, and adventures ahead
Kamakiri
Buffalo, New York
Posted: 06/13/05 05:11am Link  |  Print  |  Notify Moderator
After
snowshoe
NH.
Posted: 06/13/05 05:13am Link  |  Print  |  Notify Moderator
That is beautiful!!! Would like to see the inside, too. Good job.
Nancy
Tom & Nancy
2001 Rockwood Lite 2104
2002 Silverado LS 1500 Z-71 Extended Cab, 5300, 3.73 rear
Kamakiri
Buffalo, New York
Before:
Kamakiri
Buffalo, New York
Posted: 06/13/05 05:16am Link  |  Print  |  Notify Moderator
I don't have any interior shots unfortunately.....yet. The optical block on my camera is shot (it was dropped onto a concrete basement floor), so now it will only focus on wide angles.......until I get it replaced.
Here's another after shot
robinandbob
Rossville, GA
Posted: 06/13/05 05:19am Link  |  Print  |  Notify Moderator
If you ever make it to the south I'll be watching for it. I love to see the vintage RV's brought back from the brink.
S. Mid. TN
98 Fleetwood Discovery 36T
4 big dogs 2 cats, Silkies and Guineas
orchids & epis
Kamakiri
Buffalo, New York
I do have a couple of shots for the inside, just of the roof damage area. When I purchased it, the owner had said that it wasn't level and leaked around the skylight. The truth of the matter was that the roof seam at the side had split slightly and let everything drain in, and the skylight was just the lowest point. Once the ceiling was out and the trusses repaired, it was a matter of resealing that section inside and out, and then reinsulating and recovering.
Here's the before:
Kamakiri
Buffalo, New York
Posted: 06/13/05 05:22am Link  |  Print  |  Notify Moderator
This is the ceiling repaired. I used 1/4" laminate board. Looks pretty nice, the only irritating thing is that the roof is perfectly straight but the mouldings make it look just a bit wavy.
Spindeepster
Third Stone From An Insignificant Star
Posted: 06/13/05 05:27am Link  |  Print  |  Notify Moderator
You've done a great job!!
Click here to see pictures of my 1963 Shasta!
"I didn't plan on getting old, it just happened, and it will happen to you too, if you're lucky".
---Andy Rooney
Kamakiri
Buffalo, New York
Now after our camping experience, I'll share with you two lessons I learned from a first timer:
Two lessons learned whilst camping:
1. Never assume that you'll have electricity all night long and depend on an electric heater.....hadn't had chance to run the propane one before our trip and the pilot light door was frozen shut! Now thankfully corrected
2. When flushing the toilet, don't just do it to make sure the materials exit.....let it run for a little bit, or you're going to end up with a nasty job when you disconnect your septic hose. This camper doesn't have any black or gray water tanks, just a pipe out the bottom.
Lessons learned
Page of 5
