weinturv
Columbus, Oh USA
Just upgraded from a TT to a MH. I want to get some splash guards/stop across the undercarriage rear and I ask the veteran
MH ers: should we get the solid one or the other one that looks like a grass skirt? WE will be towing a CRV next year...
thanks
Cindy
2006 Hurricane 31D
toad 2004 CRV
Cindy and Company (Na, and constant pals - Lady and Jodie)
2013 Winnebago Vista 27N
Blue Ox Aventa II, Brake Buddy
toad 2011 CRV
tom_kat
way upstate new york/lake george area
think you will hear the solid one more then the other,i have the other type,the grass skirt,i also have wide flaps behind all the wheels and dont have a problem,if you were not planing of flaps for all the wheels think the solid one would work better for you,
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
Catdave
North Carolina
A solid one works better than the hula skirt.
The Protect-A-Tow works better than both and is cheaper- www.protectatow.com
2006 Fleetwood Excursion 39L
pigman1
Delaware
Both solid and grass are available at Camping World. Take a ride on the interstate and see how high the grass one "flies" at highway speed. We found the solid slirt installed rigidly between 2 inch-and-a-half angles works much better and keeps the toad much cleaner.
Good luck with the new rig.
John
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
RAMBLER38
NEBRASKA
I have the factory installed solid rubber across the back of a Holiday Rambler Endeavor. Problem is that gravel still gets around the ends of the splashguard and chips the toad. No one answer I'm sure on how to eliminate some road chips. Happy Camping.
2004 Holiday Rambler Endeavor 38' PBDD
2006 GMC Envoy Denail
Brake Buddy
Remco Tow Bar (Blue OX AVENTA II)
Florida Jim
South Florida
I "had" the solid one behind my DP and thought that was the best solution. However, one day, while traveling on the highway, happy as can be, I discovered a piece of rubber in my lane. I tried to shift lanes to avoid running over this piece of retread, but being almost 60' long and in a little bit of traffic, that was not a safe option. So, I managed to scoot a little and just run over a small corner. I heard a little thunk, but was proud of myself for avoiding a big thunk and then a scraping noise. An hour later, I pulled into the drive way, and on my way into the house, I noticed half my rear-end had separated from the RV. ![eek [emoticon]](http://www.rv.net/sharedcontent/cfb/images/eek.gif)
I dunno, if I had the grass skirt maybe that little piece of rubber would not have had the strength to rip off half my bumper. Or, if I had discovered the rubber sooner, perhaps I could have avoided the whole ordeal.
Current.......1999 Renegade 37' DP
Before that...2002 Four Winds Diesel 34' Class C on F-650 Chassis
Before that...2000 Coachman Catalina 34' Class A V-10 Ford Gas Engine
dons2346
Sioux Falls, SD, formerly of So. CA
Put a mud flap behind the rear tires. Then install the solid flap across the rear of the coach. Just make sure that it is not to close to the ground so that it will create turbulence and cause little stones to be picked up. 4 to 6 inches at ride height should be about right.
Catdave
North Carolina
I drove from AK to FL last month (lots of gravel on the ALCAN this year!) using the Protect-A-Tow and got zero dings and scratches on the toad- a full size Chevy 4WD pickup. It also keeps the backup camera clean in the rain.
If your rig has side exhaust (gassers and some DP's) the Protect-A-Tow will work great. For rigs with rear exiting exhausts it will require some modification around the pipe to make it work.
My new DP has rear exiting exhaust so I had to buy a solid type Ultraguard deflector till I can get home & modify the Protect-A-Tow to work properly. Ultraguard works good so far, but doesn't keep the backup camera as clean in the rain.
wilanddij
CA Desert
I have the stock mud flaps behind the rear wheels and the "Rock Solid" product from CW across the rear bumper. It hangs about 6" off the ground. Have not had any damage to the Wrangler yet, but its running on 31" tires, so it may ride above the fray.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Ford C-Max/Blue Ox
"We have met the enemy, and he is us" Pogo
NevadaJim
Minden Nevada U.S.A.
I would also look into Protect-A-Tow light easy to install Have fun
JimandJerry@charter.net
