RV.Net Open Roads Forum: Dinghy Towing: Geo Tracker
RV.net
Search only in Dinghy Towing
 > Geo Tracker
UKTN
Chattanooga, TN, USA
Posted: 09/07/05 11:47am Link  |  Print  |  Notify Moderator
I'm receiving conflicting info regarding which Geo Tracker can be towed 4 wheels down... I'm looking at a 2 wheel drive automatic which they say is the best one to tow but others say I need a 4x4 standard. I called a GM Dealer and they say the 2 wheel drive is the best.... ANY HELP will be appreciated...
grizzlygiant
Coeur d'Alene, North Idaho, USA
Posted: 09/07/05 12:00pm Link  |  Print  |  Notify Moderator
I have towed my Geo 4x4, manual hubs, over 50,000 miles without any problems. That is "good" to me. And I like the 4x4 feature in our snows here -- the thing would climb a tree if I wanted it to.
North Idaho
2008 Heartland Big Horn 3400RL fifth wheel
2007 Dodge Ram 2500 4x4 5.9 Cummins
lluttrell
Longmont, CO
Posted: 09/07/05 12:53pm Link  |  Print  |  Notify Moderator
We have Sidekick 4x4, which is essentially the same vehicle. Right in the owners manual it tells you what you need and how to tow 4-down. There are some differences in method with newer models, but all are OK for towing.
Not sure about 2WD.
Lyle & Marilyn
2001 Seabreeze 34' V-10 & Banks
94 Suzuki toad
Eagles Nest
Diamond Point, NY, USA
Posted: 09/07/05 02:30pm Link  |  Print  |  Notify Moderator
We tow a 2000 Tracker, with auto, and 4X4. No problems at all. All four down.
Ron & Patti Eaglestone
"Casey" the pup,
2003 Southwind 32VS, V-10
2007 HHR
FMCA F357488, Good Sams.
enblethen
Moses Lake, WA USA
Posted: 09/07/05 03:00pm Link  |  Print  |  Notify Moderator
My memory is that two wheel drives are not able to be towed four down.
I had a Suzzuki Sidekick and my memory says no four down.
One of you with your owners manual could look in your book.
My new XL7 says NO for either auto or manual shift.
Bud
Suzuki XL7 pushing Pace Arrow
dicknellen
Northern Nevada, USA
Posted: 09/07/05 04:53pm Link  |  Print  |  Notify Moderator
I had a Tracker, sold it now have Jeep. You need a 4X4 either auto or manual to tow 4 down with out modifictions. Maybe the dealer is trying to unload 2 wheel drive unit. I would only go with 4X4.
Regards,
Dick
gusfd
Boynton Beach, Fl.
Posted: 09/07/05 06:47pm Link  |  Print  |  Notify Moderator
I have a 1997 sidekick which is the same as a tracker.
It 2 WD BUT its 5 speed manual tranny. I have towed it
everywhere. Put it in neutal, emerg. brake off, key to the first
position, shut radio off. If you do not want the miles counted.
Disconnect the speedo at the tranny, very easy.
Ed
2002 National Sea Breeze
Ford F-53 V-10
2005 Saturn Vue
regrus
Edmonton Alberta Canada
Posted: 09/07/05 07:25pm Link  |  Print  |  Notify Moderator
Two wheel drive 5-speed standard CAN be towed. Two wheel drive automatic transmission CAN NOT be towed.
2007 Jayco Seneca 34SS with Tracker Toad
Wild Rose
Calgary, Alberta
Posted: 09/07/05 09:51pm Link  |  Print  |  Notify Moderator
Buy a 4 wheeler. Take out the propeller shaft. tow with tracker in 2 wheel and drive around in 4 wheel.
2003 GMC HD2500 8.1
2004 HitchhikerII UKTG 32.5
robatthelake
Vancouver Island
Posted: 09/07/05 10:51pm Link  |  Print  |  Notify Moderator
The 2WD Manual(5 Speed) Tows fine! But do not try towing a 2WD Automatic!
The 4X4's have no problem with either the Auto or Standard because you can Freewheel the Transfer case!
Rob & Jean
Presently Looking for "The Perfect Rig"
 > Geo Tracker
