RV.Net Open Roads Forum: Toy Haulers: Garage Floor Paint
Search only in Toy Haulers
 > Garage Floor Paint
MULETRAIN
Apache Junction , Az.
Posted: 09/17/05 04:34pm Link  |  Print  |  Notify Moderator
Any suggestions on what kind of paint to use on the floor in the garage area of TH. Don't really want to use bed liner material, just some sort of paint to match the existing gray I have now. Thought about paint they use on concrete garage floors but don't know how it would work on wood. Home Depot recommended just an exterior house paint, but don't thank that would be very durable. Thanks
Bart & Karen
2004 Rampage 260 TH
2004 Dodge QC 4x4 CTD
1999 GMC Z71
2004 Warrior 350
2001 Lakota 300
3 Grown Boys-
2003 KFX 400
2003 Prairie 360
2001 Lakota 300
Want-a-Be's
Arizona
Posted: 09/17/05 05:04pm Link  |  Print  |  Notify Moderator
MULETRAIN,
The paint they use on concrete floors will work.. but a GOOD quality of "Oil" based paint it what I've seen used.
What ever you use.. the surface must be really clean. Scrub it down with TSP and rinse it well.. make sure it's dry. Roll on two coats, allowing it to dry between coats.
Take the time to redo it every year after that and you should have no problems. It will resist oil spills and can be wiped right up..gas spills MUST be wiped off immediately.
You can wet mop it to keep it clean as you go along.
You can add #10 silica sand to the paint and stir well to improve traction and reduce the chance of falls due to a slick surface.
Check with Ace.. their Oil based paint is high quality and is often on sale this time of the year.. the last I bought was $49 for 5 gal on sale.
DON'T USE LATEX house paint! Good Luck!
ktmrfs
Portland, Oregon
Posted: 09/17/05 06:06pm Link  |  Print  |  Notify Moderator
instead of paint, go to a spray in bedliner place and have them do the floor. I did that on my cargo trailer (Rhinoliner) and it is great. They added garnet to the mix when they did the drop down ramp, it isn't slippery, gas, oil solvents to bother it, it is easy to clean. They even when up 6" on the sides to completely seal it.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
robsouth
Covington, GA
Posted: 09/17/05 06:28pm Link  |  Print  |  Notify Moderator
Sherwin Williams has a good product called Porch and Floor paint. Very durable.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
plascell
Lynchburg, VA
Posted: 09/17/05 07:47pm Link  |  Print  |  Notify Moderator
Call Valspar Paint Tech support 800-845-9061 or email: techsupport@valspar.com
robsouth
Covington, GA
Posted: 09/18/05 09:30pm Link  |  Print  |  Notify Moderator
Valspar. what a joke. I bought some Valspar stain at Lowe's to stain my deck. Did not have enough. Went back to Lowe's for more. They have discontinued Valspar. Called Valspar to find nearest dealer. Folks, this is Atlanta area. They did not have another dealer in the area. HuH? Had to drive to Macon Ga and when I got there, their phone person that I had called did not know that they had discontinued it as well. I tried to order it direct, and was told that they only sell through dealers. When told that they did not have a dealer near me, they suggested a dealer in Ohio. Go figure. No more Valspar for me.
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
