Open Roads Forum
Print  |  Close
Topic: Oil filter for a Marquis Gold Generator
Posted By: RVdude on 11/04/05 09:30am
Hi all,
I have a 2003 Onan Marquis Gold 5500W generator. Everytime I head out to Camping World to get a oil filter for it, there out of stock.
Does anyone know if a Fram or other automotive oil filter will work and what the part number is? The Onan filters look just like Fram or other automotive screw on oil filters. Also, what type/weight oil does everyone use when changing the oil.
Thanks!
2003 Siverado 2500HD, K&N Gen II FIPK, Hypertech III Programmer, Gibson Dual Performance Exhaust.
2004 22FT Weekend Warrior 5200#'s Dry, 8500#'s Loaded.
Posted By: Rick Jay on 11/04/05 09:36am
Hi,
Can't help with a cross reference number for the filter. I just picked up the Onan filters at our local Cummins/Onan dealer. I thought they were priced reasonably enough (forgot the exact amount) to just stay with the Onan brand. I always pick up enough to keep a spare or two with me on the road...just in case. I'll probably continue to do so at least as long as the warranty is in effect.
As for the proper oil, check you manual. I believe my Marquis Gold 7000W generator lists several weights depending upon the temperature range. Going from memory here...I think it listed 5W-30 for -20 to +50 degrees and 10W-30 for +10 to +100? degrees. I think they also listed a 15W-40 and a straight 30W under certain temperature ranges. In addition to the owner's manual, there is a sticker on the generator that has this info as well.
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (21-Angel, Lexi96.org), 1 girl (16), 2 boys (17 & 14). Two Chinook dogs, 13 & 11.
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
Posted By: Kenneth on 11/04/05 09:55am
Does this look right:
WIX
Posted By: sandygirl on 11/04/05 10:18am
I would order the right one from Funroads. They have the best price around. Any RV dealer will carry the filter for your Onan but they will be 10-12 dollars verses 7.50 at fun roads. The wix is 7.23 so your not saving much there.
Sam
[/purple][b]Kari & Sam Hurricane, Utah[/b] 2004 34' Damon Challenger 315
Note: Due to invalid formatting, all formatting has been ignored.
Posted By: Robert78121 on 11/04/05 10:20am
I get them from Napa as they have a cross reference from them. It's handy to get them from my local Napa guy. Ditto the sticker on the generator for oil weight. I run 15w40 for my temperature range.
Washington DC Area (NOVA)
Camper: 2004 Damon Daybreak 3285 WorkHorse 8.1
Toad: 1996 Jeep Cherokee XJ 4x4 - BlueOx
Toy: 2012 Ninja 650 - Versa Haul VH-SPORT-RO
Spent three years full time, so I know a little about it.
Posted By: OldF**t on 11/04/05 09:43am
You can buy them direct from the Onan store here .
Jim
2004 Hurricane 32R (F53)
Demco Excalibar
2010 Ford Ranger 4X4
2017 Harley Tri Glide
1 wife and 3 cats
Posted By: chasfm11 on 11/04/05 11:42am
I don't know if CA is the same as TX but I can buy my filters at a local Cummins dealer cheaper than I can at my local Auto Parts store. For example, the Fleeguard engine oil filter cost me $10.79 at Cummins versus $15.95 for the equivalent WIX filter at O'Reilly. I shopped my generator filters the same way and fould similar savings - and they never seem to be out of stock on anything that I need.
I get into Dallas every once in a while and just make it a point to stock up on Onan and Fleetguard items while I'm there.
2000 Georgie Boy Landau 36'DP Cummins 5.9, Allison 1000 5sp
2005 Saturn Vue Toad, Falcon2 Towbar, BrakeMaster Toad Brake
Posted By: Glenn Cooper on 11/04/05 12:35pm
Onan,Marquis Gold 5.5 WIX oil filter # 57398, $10+. TENN.VOL.
Posted By: Rick Jay on 11/06/05 04:57pm
Hmmmm....$7.50 for the Onan and $10+ for a Wix. Tough decision. [emoticon]
And yes, if there is a problem with a non-OEM filter they can cover any damage. But now you're stuck in the middle between the OEM and the aftermarket company trying to determine who is at fault and then trying to get reimbursed. Sometimes it might be worth it. Based upon my first sentence, I don't think this is one of those times. [emoticon]
~Rick
Posted By: Glenn Cooper on 11/06/05 06:24pm
Onan makes generators, Wix make filters! Sort of like SEARS dont make
tires, battery's, weed eaters, lawn mowers, washers&driers, well they dont
make anything. You think they make CRAFTSMAN tools????????? TENN.VOL.
Posted By: Clay L on 11/06/05 09:43pm
I also get mine from the local Cummins dealer - less than $8 as I recall. The fuel filters are very reasonable too - $1.95 each as I recall.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Posted By: Rick Jay on 11/06/05 09:53pm
Glenn Cooper,
I didn't say Onan makes the filter. It doesn't really matter to me who makes it for them. THE ONAN NAME IS ON IT. Therefore, they have endorsed it to work properly in their product. If it doesn't, then it's THEIR problem, not mine, and I only have to point my finger in one direction: Onan. With a non-OEM filter you're left pointing in at least 2 directions. The issue will probably still get resolved, it's just a bit more complicated.
As I said...if there was a clear savings advantage of using the non-OEM filter, then that is an incentive. In the case of the prices posted here, the Onan filter is cheaper than the Wix.
I don't think $2.50 per filter is going to make or break any of us, so it probably really doesn't matter. Plus, I'm pretty sure that it's possible to pick up the Wix filter for less than what some Onan dealers sell theirs for.
The important thing here is that we do the required maintenance using parts from a supplier that we have confidence in so that in the unlikely event there IS a problem, we can get them to help us out. [emoticon]
~Rick
Posted By: sandygirl on 11/04/05 10:34am
I don't know if I would take a chance on running a non Onan oil filter, at least during the warranty period. Onan uses some type of bypass filter, an aftermarket filter may or may not meet this spec. Why take a chance.
Sam
Posted By: Kenneth on 11/04/05 10:36am
If you use the filter recommended by the aftermarket filter maker (WIX & NAPA, Purolator, etc.) they cover any damage caused by a failure of their filter.
Ken
Posted By: Glenn Cooper on 11/07/05 07:20pm
RAY-JAY, {IHAD A FRIEND} But all seriousness asise,Jay---the point I
was trying to make was that Onan, Mopar, Harley and who knows, put
these and other PARTS out for contracts bid, that LOW contract!!!!!
Sure they may say filter X-microns and small rocks, PAINT IT GREEN
and I will purhase xxx no. in 3yrs. $1.53 each, sorry we can get the
ones from mexico for 87cents each. LOW BIDDER!!!!!!!!!!!
When I was a young man, I can hardley member----I said I buy CHAMPION
plugs, FRAM filter and GERBER baby food. it was the name I trusted!!!
Now I would not put a fram filter on my x-wife car!!!! And I just paid
$10.00 for NGK dual whammy mammyjammers plugs. We both know they are
not worth that! But I am not going back and have to worry about plug
again, Ihope! Dont have any need to know about GERBER baby food.
Oh buy the way my brushes on the 5.5 marquies gold Part# 214-0109
were less then half-inch today. Dang LOW bidder------but the good
news is the block and brushes are less than $25.00 I think the
gen. has bout 460hr. less than 500 anyway. I have enjoyed the
conversation JAY!!! TENN.VOL.
Posted By: amore on 11/07/05 07:28pm
Hey RVguy,
what did you do, jump ship on us? You asked for help and then you don't reply. We know what to do and how to go about it, the rest is up to you.
amore
Rich & Vickie & spoiled Yorkies
Posted By: Rapid Ray on 11/07/05 09:03pm
The 5500 Marquis Gold should use part # 0122-0836 which is sold by Onan for $7.50 on line at their site. My manual indicates using 30 weight oil for our California weather/temp. I think they prefer not using multi weight oil unless your in colder climates.
Posted By: pegaraiza on 07/31/07 09:08pm
We have purchased the WIX filters (twice) and could not get either one to install correctly - the threads wouldn't 'grab'....cost was $11 per...order directly from the Onan store for $7.50 but pay shipping ($10 for 2)...or buy from your local RV dealer
Posted By: bigdaddy & littlemama on 11/08/05 07:35am
Just picked one up at CW (122-0836 Onan) for around 10 bucks.
bigdaddy & littlemama and "Miss Lucy & Chucky"
'02 Allegro Bay 35DB W22
"07 X Unlimited Wrangler
'05 Harley Trike
Our other coach is a school bus(yes, we both drive)
Posted By: TomDnSC on 03/06/06 08:47am
Wix 57398 or NAPA FIL 7398 crosses to a Onan Part No. 122-0836. Some NAPA stores keep them in stock.
Posted By: RRRKKK on 03/06/06 11:24am
I use the Wix 51764 reason being it has a 1" nut on the end of the filter. this makes it easy to get filter loose. Most have the same threads on filter screw on pipe. Yes I know all about the by-pass. And I trust Wix.
There is a fine line between "hobby" and "mental illness"
Ron K
Print  |  Close
