RV.Net Open Roads Forum: Truck Campers: Went to scale with Bigfoot
RV.net
 > Went to scale with Bigfoot
sasha_j
Cape Hatteras National Seashore, NC
Posted: 12/04/05 09:33pm Link  |  Print  |  Notify Moderator
Snow Foot wrote:
I finally got to a scale after 12 months of buying my camper and truck.My truck I allready new the wieght of at 8000LB,with a gvwr of 11500.It is a 05 cc lb 4x4 psd Ford.With th 2500 10.5 bigfoot in the back loaded except water it came in at 11700.That is with 40 gal of diesel in the truck.I thought it would be more.I didnt get a chance to get the wieght of the front or back axle seperate like I would have liked to.
For comparison, here is my rig. We have the same truck, but my TC is shorter than yours, but has a slide out. Our TC weights are about the same since my water tanks were full on the scales.
My truck's weight only, with full diesel, one passenger and light
weekend supplies:
Front axle: 4,920 lbs
Rear axle: 3,160 lbs
Gross weight: 8,080 lbs
My truck's weight with camper, fully loaded and wet for trip:
Front axle: 5,560 lbs
Rear axle: 6,620 lbs
Gross weight: 12,180 lbs
My ratings:
Front axle GAWR: 6,000 lbs
Rear axle GAWR: 7,000 lbs
GVWR: 11,500 lbs
GCWR: 23,000 lbs
My camper certification is good for 2858 lbs:
The factory sticker on the inside drivers side pillar shows a 3671 lbs
payload capacity for the combined weight of occupants and cargo.
On the Ford Fleet web link, my truck is shown as rated for 4200 lbs
payload capacity.
On the 2005 Ford Truck Towing and Camper guide (color), the rating is
shown as 3,411 lbs.
On the 2005 Ford Truck Camper Loading Guide (black+white), the rating is
shown with every possible variance and options. The ranges here are from
3,411 lbs to 2,561 lbs.
* This post was edited 12/05/05 04:48am by an administrator/moderator *
Our Web Site
05 Ford F350 SD 6.0 PSD CC LB 4x4 SRW Lariat, 11500 GVWR, Alum Ricksons, G124 265/70R/19.5/G tires, Airbags
05 Snowriver 8'10" Super Slide w/ 100 W Solar, All Weather, slides
07 Prolite 7.5x14 V Nose Aluminum Toy Trailer Mobile Garage
Reddog1
El Dorado, CA
Posted: 12/06/05 08:41pm Link  |  Print  |  Notify Moderator
Please do not confuse those that would sue you because you are one pound overweight. Common sense does not apply.
I would be hesitate to tell anyone they are overweight. I would tell them to be at their comfort level. If I saw something that I thought was obviously unsafe (to me), I would question them about it.
Snow Foot - I would not hesitate to caravan with you. I would be indifferent who was in front.
I am very encouraged in reading post that display a little common sense.
The most unsafe people I encounter are those that are hung up on certificates, and I am an Educator.
Wayne
sasha_j
Posted: 12/06/05 09:31pm Link  |  Print  |  Notify Moderator
I hope Wayne doesn't think I'm hung up on certificates. I wanted a truck with an offical camper package yes, but I just posted my info so folks can compare and contrast with thier own rigs. Plus I was pretty pysched that my TC was similar in weight to a longer Bigfoot, albeit, one with no slide.
Reddog1
El Dorado, CA
Posted: 12/07/05 06:31pm Link  |  Print  |  Notify Moderator
sasha_j - I honestly gave no thought to you being hung up on certificates.
What I would like to see from the big three is item-by-item details of the upgrades on the trucks that they have rated to carry more weight. Simply something like "Camper Package" is not much.
Wayne
beach3
Aurora, Illinois, U.S.A.
Posted: 12/07/05 08:48pm Link  |  Print  |  Notify Moderator
I don`t see any problems with your weights. As you can see from my signature we have the bigger BF. We are over on the GVW but under on the axle weights. The major things to remember are always check your tire pressures and allow for greater stopping distance. If you look at most tire manufactures info the biggest cause for blow outs is under inflated tires. Any time a load is hauled there will be a greater stopping distance no matter what size truck. We also snowmobile and tow a Pace enclosed trailer many times. No problems. Love our Bigfoot for winter camping.
Charlie, Nancy, and Sarge say HI
2001 Ford F350 Lariat Supercab SRW Diesel 4X4
2001 25C10.6 Bigfoot Camper
BOCI Member
Sir Lancelot
Central California
Posted: 12/07/05 09:18pm Link  |  Print  |  Notify Moderator
I have seen what happens to an under-inflated tire. But what happens to a tire that is inflated correctly (80 PSI for my current load range E tires) but is over-loaded. Does it blow out catastrophically or separate or ??? On my last trip, the rear axle was carrying 6200 pounds on tires rated for 6084 pounds (total). The tires didn't get hot, didn't look squashed, nothing. But I still cringed when hitting every pothole and bump, just waiting for the tires to blow. That's why I'm having Vision rims and 245/70-19.5 tires mounted this weekend so I won't have to even think about overloaded tires anymore! It will be a big load off my mind.
Kirk
1999 Dodge Ram SLT 2500 Quad Cab, V-10, Auto, 4x4
Vision Type 81 wheels with Kumho KRS03 245/70-19.5 tires
Airbags w/In-Cab control, Rancho 9000X w/In-Cab control
2005 Lance 1025, A/C, Onan Camp Power 2500LP generator
