RV.Net Open Roads Forum: Truck Campers: Water heater mod. & Bathroom soap holder
 > Water heater mod. & Bathroom soap holder
Spott
SE Michigan
Posted: 12/14/05 07:10pm Link  |  Print  |  Notify Moderator
Based on someone else's PVC hot water heater drain idea (can't remember who it was) I added a solid brass ball valve, for a no tools required drain. Since I used a hose bib I can add a short section of hose and empty into a bucket so I don't make such a mess.
And I added a small wire rack (SS) in the bath to hold two bottles, one soft soap and the other shampoo. No mess dispensers and they stay in place.
Me - Kim - Spot
Pete_k
Stantonville Tn
Posted: 12/14/05 07:26pm Link  |  Print  |  Notify Moderator
I like both of those ideals. But the soap one the best. I had to clean a bottle of soap up from falling over and leaking all over the place.
I hope to load ours up next week. so I may have add both of those to it.
Pete
2004 Duramax/allison Trans C/C 4x4
2006 Okanagan 811 SL
new 5th wheel camper soon.
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
CloudDriver
New Jersey Shore
Posted: 12/14/05 07:34pm Link  |  Print  |  Notify Moderator
I like the water drain idea and would like to do the same on mine. Is the hose bib a part of the valve, or screwed to a short nipple?
2003 Winnebago Minnie 24F - Ford E-450
Spott
SE Michigan
Posted: 12/14/05 08:19pm Link  |  Print  |  Notify Moderator
The ball valve is one piece, threads on one end and Hose Bib on the other. About $6 at Lowe's. I had to "adjust" the handle a little to fit the space and I like that if I leave the valve "open" I can't close the door. So I know if the door is closed the valve is too.
I did have to take apart a little bit of the water heater in order to screw the valve into place then reassemble heater, very simple job though.
Peg Leg
Anderson, IN
Posted: 12/14/05 10:37pm Link  |  Print  |  Notify Moderator
Spott, A idea that I stole from another camper is taking one of those soap bottles, a piece of duct tape and a magnet. Tape the magnet to the bottle, real hard ain't it, then I can slap it about anywhere.
Now to this add one of those 300 oz liquid detergent dispensers with the push button nozzle. I write on it with a permanent marker "hand washing only", add water and set it in a sunny spot with a hand towel, wolla no more running inside to wash your paws.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker
Yamaha EF3000iSE
retired gadgetman
XA4AV8R
Kennewick, WA, USA
Posted: 12/14/05 10:52pm Link  |  Print  |  Notify Moderator
[quote=spott] I can add a short section of hose and empty into a bucket so I don't make such a mess. I am going to do your mod on mine...we can probably just leave the short hose installed and tuck it in. Then there would be a quick and easy(no need to unlock the outside shower) supply of hot water from the outside without going inside with the container to get it.
Note: Due to invalid formatting, all formatting has been ignored.
'97 Dodge 3500 4wd '99 Northern-Lite Ten 2000CD
ogrer
Norwood On
Posted: 12/15/05 05:52am Link  |  Print  |  Notify Moderator
We did the same, We leave the hose on the drain all the time, coiled up around the heater and usually drain out the hot water tank when we shut the camper down between trips.
As for the wire racks, we added a small one at the sink and added a row just below the ceiling, in the bathroom, which allows the other half to bring her stuff, with out taking usable space.
We still are looking for other magic storage ideas.
Bob & Jan
25C106 BIGFOOT Loaded Followed by a Regal LX 1750
2006 Dodge Ram 3500 4X4 DRWRhino Liner & Rubber Bed Mat
Tork Lifts Front and Back Fastguns Superhitch Super Truss 32"
And a Pumpkin Orange Rubi in tow
roadranger
Colorado Springs, Colo
Posted: 12/15/05 09:44am Link  |  Print  |  Notify Moderator
Great idea!
Unfortunately, my water heater has an annode rod for the plug assembly.
Can't replace that with a valve...
'01 Dodge 2500 4x4 QuadCab HO Cummins 6 spd,19.5 Ricksons,Ranchos,Hellwig sway,4 leaf helper springs,Titan V hitch w/28in. extension.
'03 EAGLE CAP 950,slide out,dual batteries,Honda EU2000.
Tow- 7000lb.tandem axle Cargo trailer
Semper Fi, RVN
BillArf
NY and Florida
Posted: 12/15/05 10:50am Link  |  Print  |  Notify Moderator
There was good reason the other fellow went with CPVC non-metal fittings ! 8-)
Spott
SE Michigan
Posted: 12/15/05 10:53am Link  |  Print  |  Notify Moderator
And that would be???
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
