RV.Net Open Roads Forum: Replaced shower curtain with home made shower door
 > Replaced shower curtain with home made shower door
Truck Campers Related Tips
Spott
Ypsilanti, MI
Posted: 01/29/06 02:35pm Link  |  Print  |  Notify Moderator
It doesn't come across in photos too well, but this is a sheet of a plastic type material from the local home center. Since the toilet is raised, the door could not go all the way to the floor so I attached a piece of "Sport Nylon" material to the bottom, it moves up and out of the way as you open the door and hangs down when closed.
I had to move the shower curtain track closer to the door/wall and hung the door from "S" hooks on the original rollers.
* This post was last edited 01/29/06 05:11pm by Spott *   View edit history
Me - Kim - Spot
2005 204 ssi on the water - TCM article
CTD Hauler
Salem, OR
Posted: 01/29/06 03:09pm Link  |  Print  |  Notify Moderator
Very cool! You must have alot of time on your hands, but I sure appreciate all the ideas. I've copied the soap basket in the shower, added a tapered one above the main entry door, added an LCD TV on a wall mount, moved the spice rack up (PIA) and put a small micrwave on the counter under it.
Keep the ideas coming!!!
Ron
2005 Ram 2500 QC LB 4X4 CTD,rancho's,overloads,r/swaybar,airbags w/Dual incab control,35" Toyo M/T's,Torklift tiedowns,20K Reese hitch
1994 Snowbird 810 Truck camper
2007 Victory Lane 36SRV H5 5th Wheel Toyhauler
Ron
INSAYN
NW Oregon
Posted: 01/29/06 11:10pm Link  |  Print  |  Notify Moderator
I like it, and my bathroom is very similar. I think that this modification would do me good. Nothing like wet shower curtain stuck to your buttocks.
INSAYN
1997 F350 CrewCab PSD 4x4, auto.
2005 SnowRiver 8'10", Loaded + EU2000i.
2005 8.5'x16' Interstate West Cargo trailer, Line-X'ed
2005 16' Fish-Rite Rogue welded aluminum boat, 2005 40HP Yamaha 2-stroke O/B.
wrouleau
Taylorsville(Salt Lake City area), UT, USA
Good Sam RV Club
Posted: 01/30/06 05:03am Link  |  Print  |  Notify Moderator
Great modification. I have always disliked the plastic shower curtain supplied with our Lance.
ogrer
Peterborough on
Posted: 01/30/06 05:28am Link  |  Print  |  Notify Moderator
Looks good spot. Have you tried it out yet? You must have the same weather we have. Not enough snow the play outside, and not warm enough to work outside, so you get the play in the shop
Bob & Jan
25C106 BIGFOOT Loaded Followed by a Regal LX 1750
2006 Dodge Ram 3500 4X4 DRWRhino Liner & Rubber Bed Mat
Tork Lifts Front and Back Fastguns Superhitch Super Truss 32"
And a Pumpkin Orange Rubi in tow
eddd
Los Fresnos, TX
Posted: 01/30/06 11:00am Link  |  Print  |  Notify Moderator
Do you have any picture of it in use...
On second thought...Never mind.
drcurran
Springfield, PA
Posted: 01/30/06 11:37am Link  |  Print  |  Notify Moderator
Hey INSAYN -
Way too much information I'm having a nightmare
Dan
PS - SPOTT - Great job! Thank you!
Dan Curran, Jr.
Springfield, PA
'95 Ford/Tioga 23.5 Feet
Retired & Ready
Just Me & Mares
drcurran@bellatlantic.net
Spott
Ypsilanti, MI
Posted: 02/01/06 06:18pm Link  |  Print  |  Notify Moderator
ogrer; No I have not gotten to try it out yet, I can't wait to get on the road again.
Spott
Ypsilanti, MI
Posted: 06/30/06 09:36pm Link  |  Print  |  Notify Moderator
We have used the shower door many times and am very happy with the way it works.
A couple of changes were made, the first one being that when the material got wet it wicked upward and loosened the double sided tape. I ran a bead of super glue on the material along the bottom edge of the hard part of the door, this made it so it would not wick up.
The second adjustment was the track being screwed into the fiberglass was not strong enough, so I removed the bathroom door and track and drilled a couple of holes to gain access to the top of the shower stall.
I than inserted backing blocks (one in each hole)and mounted the track through the stall and into the blocks(with caulking).
Than reinstall the track, door & valance and the holes are invisible.
This shows the relationship of the holes and the track.
