leighc
NH Upper Valley
I’m having Rancho RS9000X shocks (manually adjustable type) installed on my truck.
If you also use these, I’d appreciate it if you’d let me know what setting you use while
1) unloaded
2) loaded.
We stay on good gravel or better roads. Fully loaded, our truck will be about 150 lbs either side of Ford’s spec GVWR (9,900 lbs).
Thanks in advance.
llc
'04 Lance 835. '02 F350 Diesel SRW 2WD
btggraphix
Golden, CO
The answers will vary with the specific vehicle combination and road surface etc. In general, I run 5 or 3 front/1 rear unloaded, and with the TC in I run 7 front, 9 rear. It rides better than stock shocks both loaded and unloaded for me.
JacintoKid
San Antonio, Texas (formerly sheepdog)
I had mine installed about 3 weeks ago. I started out at 9 loaded and 1 unloaded. I use the camper almost every weekend. Now I use setting # 9 when loaded AND unloaded. (I quickly got tired of adusting them.) I did see a noticeable ride improvement with and without the camper.
07.5' Dodge 3500 DRW 4x4 L/B Cummins
08 Arctic Fox 990
(2) KLX 400's and a flotilla of small boats
BigBlueDiesel
New Mexico
For our truck
Unloaded F-2 R-1
Loaede F-6 R-9
2006 Crossroad Cruiser 25RS
2005 Bigfoot 2500 9.4 ---Sold
2003 F-250 Crew Cab SB 4x4 Diesel
Rookie
Boston, MA
Front loaded or unloaded:5
Rear loaded: 9, Unloaded: 4
Still experimenting with best settings in Ranch/Airbags combo
Rookie
2009 Keystone Challenger 34 QSB
2005 GMC Sierra 3500 Duramax/Allison DRW
2001 BMW K1200LT
jma
Edmonton
front loaded/unloaded 5
rear loaded/unloaded 9
I've tried various settings unloaded and I can't see that much difference so I leave it at my loaded setting all the time.
Twice Retired
Commonwealth of Virginia
We run ours 8 rear loaded and 6 front loaded. Unloaded 4 all the way around. Great shocks and they significantly improved our truck when loaded. With the 5er and truck loaded, we run about 2,500-2,800 lbs on the rear axle above the truck unloaded weight. Downside was it made me realize how poor the OEM shocks were from day one!!
I'm thinking about installing the remote controller. I have two new kits in boxes, so may install one and sell the other. Others have told me they really do like the ability to adjust while on the go.
Good luck!
Twice Retired
2007 Phaeton 40QDH MBE 926
2009 Jeep Liberty Limited 4x4 Toad
Woodsman Bob
Kitsap County, WA
5 front
9 back
1973 Chevy C30 CrewCab. The original "Big Dooley".
Modified GoodWrench Crate 454
Turbo 400
1984 Lance Model 800 Truck Camper
"I'm going home, and when I want to go home I'm going mobile..."
-The Who
kehale
Arizona 2011
edited 02/11/06 10:17am by kehale *
06 Lance 1181
AutoEngMike
Erie, PA
You are going to have to experiment as it will be different for every vehicle and driving style. I can reach my rears without having to crawl around on the ground and the fronts by turning the tires to far right or left. Currently I have mine on 5 front and rear, we have rough roads and I like the handling on highways. I plan to use 7 to 9 when towing but haven't done much experimenting because I just put them on last month.
Make sure the guy installing them places the knob where it is easy to reach (if possible) unless you are getting the remote control kit.
2003 Ram 1500 Quad, 4X4, 5.7L Hemi, 3:55 gears (picture)
replaced with
2010 Ram 1500 Laramie Crew, 4X4, 5.7L Hemi, 3:92 gears
2009 Honda Pilot Touring (wife's)
2006 Rockwood Roo 23SS, 6500lb GVWR
http://community.webshots.com/user/AutoEngMike
