Spott
SE Michigan
These are the mounts I made, pieces sticking out can be removed when camper is not on the truck.
This is the front belly bar
And the rear, two pieces to get below the fender. First piece goes into the hitch ends and then the extension.
Me - Kim - Spot
PR Connection
Powell River BC
Here are mine on my 02 chev
Hope this helps someone. These are not removable.
Dan
2006 3000SL26 Bigfoot Class C
320 Watts Solar With Bluesky 2000 Regulator
Four 6volt U2200 Batteries
2000 Watt PSW Magnum Inverter
RDalr
St-Zotique
Spott,
Is this one inch tubing at the front? If so, is it prone to bend under load? I believe mine is 2 inches at the front! Perhaps I could have used half the size.
RDalr
Spott
SE Michigan
The front are made from 2" square 1/4" wall and 1 1/2" with 3/16" wall.
The rear are 2" with 1/4" wall and 2 1/2" with 3/16" wall.
RDalr
St-Zotique
spott,
thanks for the reply.
Long Lizard
Pollock Pines,CA
I built the rear camper mounts on my '06 Ford by simply using two inch O.D. tubing and welding tabs on the outside to hook onto. The tubing slides easily into Fords newer receiver hitches with no body interference. Twenty bucks or so in materials and it's overbuilt.
2005 Eagle Cap 950 and '06 F-350.
cdl2
ohio
You guys must love to weld, looks good. Before I got Stable-Lift I bolted a piece of square tubing to the frame, didn't stick out past the body. Then slide in a piece of unistrut, with eye bolts. When TC was off truck slide out the unistrut, I didn't have to watch out for my shins getting busted-up.
'97 Safari Serengeti, 300 Cat ; '89 Lance LC900 w/Stable-Lift
mokai
Springfield , OR
Here are the custom tie-downs I had made for my Toyota Tacoma...They are Class 1 receivers welded to the frame and pinned so the posts can be removed when not in use..
front
rear
2003 Supercharged Toyota Tacoma EX Cab 4x4 3.4L V6 5speed
Firestone AirBags w/pump controller,
2004 Custom made camper
My Photo Gallery
30yrtc
Monson,Me
mokai
I do not want to sound negative, please , this is to be a constructive comment:
The chains do not have enough 'angle' fore and aft, I do not see the size of the TC, If it is heavy, and rough roads , it may be a problem.
Hooks are also not the best idea, if camper shifts, hooks can drop off.
JoeChiOhki
Sauvie Island, OR
That'd have to be a lot of shift 30 yrtc, I use turnbuckles pretty similar to those on mine and have had the camper shift more than once without them coming out of the eyes on my happijack ears. It may be due to the pitch being different or something, unless I'm looking at something totally different than you.
On the angle, I can't think the pitch is too far off from what you get with a set of Tork Lifts front or aft. You only get a good 45 degree style angle in the front if you're using a bed mounted tie down, any kind of frame mounted tie down is going to have far less pitch due to the restriction in how far foward you can place that tie down point without interfering with something else, like the doors on the cab for example.
I will note that both is front and rear tie downs are angled forwards vs opposing angles which help hold for both forward and backward movement in addition to the side to side. So, while I doubt he'll have too much trouble with it shifting backwards, he may have a chance at some take off in the rear over a particularly hard bump if the camper tips forward at all. (Presuming there's a gap in the front of the truck bed created by rubber bump stops of some sort)
CB Channel 17 Redneck Express
