RV.Net Open Roads Forum: Class A Motorhomes: What to do with sewer hose
 > What to do with sewer hose
ilovemybaby
u s a
Posted: 03/18/06 04:50am Link  |  Print  |  Notify Moderator
What's the best way to store your sewer hose when traveling? I leave mine in the basement, but I get an odor after awhile in the coach. I rinse well but it still gets in.
Gaylene & Rick
Central Tennessee
Posted: 03/18/06 04:57am Link  |  Print  |  Notify Moderator
Go buy a 4'= 5 or 6" pipe. Mount it up on the ceiling of your storage bay with straps and after rinsing it out- push it into that pipe.. put a cap on it or drill a small hole in the side of the end and push a metal rod through it to hold the hose in.
Rick, Gaylene and LadyPup the travelling beagle
2004 40' Alfa Seeya #1909
Not yet retired.. can't wait!
ozman
Ma.
Posted: 03/18/06 05:00am Link  |  Print  |  Notify Moderator
Sewer tubes.
These are a great deal.
Westenthal
Springfield, IL
Posted: 03/18/06 05:13am Link  |  Print  |  Notify Moderator
I leave one end of mine hooked up to the discharge pipe in the basement and I made a end cap with a seal on it for the other end. Works fine for me and no odor.
Westenthal
jojolou
S. E. Michigan & Mission, Texas
Posted: 03/18/06 07:36am Link  |  Print  |  Notify Moderator
I went to Wally World, bought a clear plastic tub with a top and store the sewer hose in that. Works great and the top on it keeps any smells trapped inside. Oh, there's no problems with leaks either.
jojolou
Lou
2008 Allegro Bay 35 TSB W-25.5
Itchn2go
Seaford,Va USA
Posted: 03/18/06 08:13am Link  |  Print  |  Notify Moderator
I use a 30 gal heavy duty garbage bag, rinse the hose well and store in the bag. If you think you will get a odor a mild clorox solution in a spray bottle should work. Never had a problem...Good Miles
Happy Trails.
ITCHN2GO,Seaford,VA
05 Winnebago Journey, 39K, 350 Cat, Freightliner & More
1 Beautiful Wife, 2 Beautiful Dogs
TOAD 04 FWD Vue Ready to Go
"It all depends on who you talk to"
treecounter
Bend, OR. USA
Posted: 03/18/06 08:17am Link  |  Print  |  Notify Moderator
We got a one inch sewer hose. Not the one with a pump on it. This one uses a water jet to grind up solids. Works great. It is slow so we keep a ten foot three inch hose to use at dump stations. The three inch is stored in the provided holder. We carry thirty feet of one inch hose. It is stored in a plastic container with a lid on it in the basement.
Treecounter
LACO-1
Posted: 03/18/06 08:35am Link  |  Print  |  Notify Moderator
I rinse and rinse and rinse with fresh water when I dump the tank, then connect and clamp the ends of the hose together. Have never had an oder problem. Also I store it in the compartment where all the waste plumbing is, so its not an air tight compartment, lots of air flows through there.
tom_kat
way upstate new york/lake george area
Posted: 03/18/06 09:16am Link  |  Print  |  Notify Moderator
i use a 5gal pail with a cover and wind it up in there my extra hose i keep in a tube outside.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
joelyn
pa
Posted: 03/18/06 09:28am Link  |  Print  |  Notify Moderator
just bought a 4in. pvc drain pipe by 6 ft at the plumbing store and mounted it across the back of the motorhome attached to the mud flaps or any other place on the chassis. one end is capped off on the pass. side and the drivers side by the connections has a screw cap on it. slide the hose inside and screw the cap on. can drill a few holes on the bottom to allow water to drain if any. cost about 10 bucks, they also have the thinned wall pvc which is lighter.
