RV.Net Open Roads Forum: Travel Trailers: Black Streaks
 > Black Streaks
Travel Trailers Related Tips
Big Red F-150
Michigan
Posted: 07/08/06 05:33pm Link  |  Print  |  Notify Moderator
Lets try this! Has anyone used RainKap (www.RainKap.com}on there RV? I'm Tring to find out if this product is worth buying? I have tried all the other idea's.
Big Red F-150
wallhorse
Missouri
Posted: 07/08/06 05:45pm Link  |  Print  |  Notify Moderator
plain old rubbing alcohol works. it just takes alot of elbow grease
brad_smith1948
Amarillo
Posted: 07/08/06 08:25pm Link  |  Print  |  Notify Moderator
Hey Big Red F-150......
Sorry I guess people just can't seem to read the question. Not only the first time you ask but even after the second time you ask. to answer your question. No I have not tried the RainKap product. I hope someone will read this and answer the question for you.
Sorry I couldn't help
Brad Smith
2007 Dodge DRW diesel
2004 Weekend Warrior LE 3105
1982 23' prowler
JBarca
Dublin, Ohio, USA
Posted: 07/08/06 09:10pm Link  |  Print  |  Notify Moderator
Big Red
I have not tried the Rain Kap. Actually they may have some merit to them. Thanks for the tip. On my NON awning side they may give some relief. But on my awning side, don't know.
Since you did ask if any one had any other ideas.
I have done something else that works. At least on the ends of the RV gutter.
Here is the front down spout. It stays on all the time.
Here is the rear. I have to take this one off when traveling. The rear of the TT does not allow me to make this one a permanent one.
Here is the spout close up
Here is the rear one unhooked. this part travels down the road with me.
For my rig, these solve the gutter black streak buildup problem.
They do not solve the rest of the streaks in the middle. Need a bigger top RV gutter to do that. I may try the Rain Kap on my non awning side. It is significantly worse with black streaks in the middle area than the awning side. Seems the awning acts like the Rain Kap and does not let the water splash on the side as much.
The down spouts I added stopped the 8 foot long black streak at least.
Hope this helps.
PS If you get a set of Rain Kap's first, please post back how they worked for you.
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we where camping!)
SFDetB420VN64
Colorado
Posted: 07/08/06 09:20pm Link  |  Print  |  Notify Moderator
Clothes pins work for me.
“Life's disappointments are harder to take when you don't know any swear words.”
MWhitner, Calvin & Hobbes quotes
LMSM1244
Savannah, Ga
Posted: 07/09/06 10:36pm Link  |  Print  |  Notify Moderator
Big Red,
I used plastic gutter extensions that snap on the existing gutters. They work real well and you can get them through Camping World, easy to install, prevents streaks, and cheap. Looked at the web site for the product you were asking about, think extensions would be cheaper and less time needed to install.
Hope this helps,
Bob
Big Red F-150
Michigan
Posted: 07/10/06 08:14am Link  |  Print  |  Notify Moderator
JBarca from Ohio, I was unable to look at your image because of my prefernce settings? Will see if I can figure it out. LMSM1244, I have the snap on extensions on the trailer, but the water never gets there because the gutter is low in the middle so the water over flows and streaks the down the sides. I will get ahold of Fleetwood about this. Wish me luck! I tilt the trailer with the nose way up during storage. Don't know what else to do.
MarkJ
Orange, MA - USA
Posted: 07/10/06 08:30am Link  |  Print  |  Notify Moderator
Does anyone have a picture, or description of the clothespin set-up.
Thanks!
Mark Johnson
TV - 06 Chevrolet X-Cab Short Bed 2500 HD
6.0 - 5spd.
05 Jayco 29FBS
Honda EU3000is
Reese WD Dual Cam SC
Prodigy
Beautiful Wife - Jennifer
Beautiful Daughter - Amanda
2 Golden Retrievers
Tylor (M) 12
Torey (M) 6
JBarca
Dublin, Ohio, USA
Posted: 07/10/06 11:14am Link  |  Print  |  Notify Moderator
Big Red up in MI
OK try this. These are hot links.
Front down spout
Rear down spouts
Rear spout on
Rear spout off
If this still does not work and you want to see, PM me an email address. I'll send
Thanks
John
PS. I tried the clothes pins. Did not work well on my gutters. Still lots of splashing. Down spouts fixed this area. Now need to work on mid section.
bwh0069
North Carolina
Posted: 07/11/06 10:00am Link  |  Print  |  Notify Moderator
Look on google for gutter zap. You will be amazed.
 > Black Streaks
