RV.Net Open Roads Forum: Tech Issues: 12 Volt bulb wattage
 > 12 Volt bulb wattage
Woodwalker
Keithville, La.
Posted: 09/04/06 07:17pm Link  |  Print  |  Notify Moderator
Is there a web page which gives 12 volt bulb wattage if you have the bulb number? I want to check in some areas of my coach at the wattage of the bulbs in the fixtures and increase the light output if possible. Thanks for any info.
T Munds
Art D
Louisiana
Posted: 09/04/06 07:27pm Link  |  Print  |  Notify Moderator
Yes there is. I found it some time back for the same reason as you. But I can't remember the site. Just Google it with some good words like "wattage for 12vdc lamps".
Geaux LSU
sandygirl
Southern Utah
Posted: 09/04/06 08:33pm Link  |  Print  |  Notify Moderator
There are many but this is the best as far as info goes. http://www.donsbulbs.com/cgi-bin/r/t.pl
Sam(somewhere close to glacier park)
[/purple][b]Kari & Sam Hurricane, Utah[/b] 2004 34' Damon Challenger 315
Note: Due to invalid formatting, all formatting has been ignored.
johndeerebilly
Morenci, Michigan
Posted: 09/04/06 09:04pm Link  |  Print  |  Notify Moderator
www.bulbman.com gives a COMPLETE listing of all or most all bulbs anyone could ever think of along with a picture and wattage as well as a ton of other info regarding bulbs. hopes this helps [emoticon]
miket
Southwick, Ma
Posted: 09/04/06 09:16pm Link  |  Print  |  Notify Moderator
Ge used to have a miniature lamp catalog that listed bulbs by number showing voltage current and candlepower or watts. They do have one on line, but it's cumbersome to use--
catalog link
catalog
Mike T
2005 Winnebago Voyage 33V, Workhorse W20, with '06 CR-V in tow, SMI 4 wire Braking system, Blue Ox Underskirt, Pressure Pro.
Matthew_B
The boonies near Dallas, Oregon
Posted: 09/04/06 09:33pm Link  |  Print  |  Notify Moderator
This page should probably be put up in the FAQ
RJgonfshin
Winston Or, USA
Posted: 09/04/06 10:40pm Link  |  Print  |  Notify Moderator
Good luck if you change to higher wattage bulbs. I hope you have some hi quality fixtures that will handle the extra heat.
Rich
' 98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
bill h
hassayampa valley
Posted: 09/05/06 03:31am Link  |  Print  |  Notify Moderator
And melted or discolored lenses.
NOTE: Any incorrect spelling is intentional to prevent those annoying popups.
84 Barth 30Tag powered by HT502/Thorley/Weiand etc, Gear Vendors OD.
Siamese Calvin and Airedale Hobbes, 4WD Toyota toad
