RV.Net Open Roads Forum: Travel Trailers: heated under carriage
 > heated under carriage
Hpdisp
Fort Myers, FL
Posted: 09/08/06 09:27pm Link  |  Print  |  Notify Moderator
How important is it to have a heated under belly (enclosed underside) if you're camping in cool ( freezing a couple of times a year) weather. As long as there is heat in the TT will that suffice to keep inside lines from freezing? I realize that the water coming in may freeze outside of the TT. Your opinion?
GailZ
Baja, Alabama (Crestview, FL)
Posted: 09/08/06 09:32pm Link  |  Print  |  Notify Moderator
The heated undercarriage is for the holding tanks. It helps keep them from freezing in cold weather. I would not want my tanks freezing and/or bursting then having to clean up the mess plus put out the money for new tanks. We will not have a unit that does not have heated tanks, will not take the chance for even a couple of times out. JMHO
Gail
2004 Holiday Rambler Endeavor 40PAQ,
2004 Jeep Wrangler X
SurgeGuard
AutoFormer
Bud and Gail
jdcone
Riverside, Ca. USA
Posted: 09/08/06 10:25pm Link  |  Print  |  Notify Moderator
A floodlight bulb will suffice in those conditions. We use Xmas tree lights (the really small type) on the fruit trees when it frosts here. Haven't lost a tree yet.
Owners of Bob the Wonder Dog, and a bunch of other useless stuff.
1999 22' Tioga class C
CampingCplWva
Panhandle of West Virginia
Posted: 09/09/06 04:36am Link  |  Print  |  Notify Moderator
This is something we did not find out until after we bought our TT or else we would have gotten heated tanks on ours. We like to camp late in the fall and early in the year.
David & Mary Ann
2011 F-250 6.7 Powerstroke
2006 Sunline Solaris T-264-SR
2012 Palomino Bronco 1500
dieselmec
Mississippi
Posted: 09/09/06 06:42am Link  |  Print  |  Notify Moderator
camping world has tank heaters 12 or 110 they work great
happy camping
Live Simply,Love Generously,Care Deeply,Speak Kindly, Leave The Rest To God! (In Our Heart's Forever Our Companion Maggie.)
kywaterbug
ky
Posted: 09/09/06 07:46am Link  |  Print  |  Notify Moderator
We have ducted heated tanks on our new Layton, I wanted something that we could use year round here at lake cumberland havent got to use them yet so i am not sure how well they will work.
canoe on top
Denver, CO, US
Posted: 09/09/06 12:17pm Link  |  Print  |  Notify Moderator
Usually, if temps get down to low 30's, high 20's at night, it won't be below freezing long enough to freeze tanks and lines. If you have a low of 28 degrees, the actual temp. isn't that low for very long. It takes awhile at that temp. to freeze things. Other factors such as wind chill can enter the equasion. While you are camped with the heat on is one thing. Think about towing over a mountain pass with exposed water lines where you may have the heat off in the trailer, you have significant wind chill from your towing speed, if nothning else and possible, below freezing temps. Even then, a few hours many not freeze things to the breaking point but a long trip could create problems. Your hot water heater is exposed. Do you leave it on? If it was full of hot water, it is pretty well insulated but it is outside the trailer so, even if you have heat on inside, it is not protected. Even with heat in the trailer, the wind will negate its benefit for exposed water lines below the floor. I guess, bottom line, temps. below freezing won't hurt you, short term, it's how long they are below freezing that you have to consider. A few hours, usually not a big deal. If it doesn't get above freezing for most of the day, you are probably going to have problems with exposed tanks and lines.
