RV.Net Open Roads Forum: I used a leaf blower to leak test my RV (with pics)
RV.net
 > I used a leaf blower to leak test my RV (with pics)
Page of 7
CloudDriver
New Jersey Shore
Posted: 10/04/06 08:07pm Link  |  Print  |  Notify Moderator
A recent post had a link to a company that performs RV leak testing by pressurizing the RV with a blower and then going over the seams with bubble soap. It occurred to me that this was a possible DIY project. The only blower I had available was a leaf blower. I cut a square of plywood to mount over the front vent and cut a round hole in the plywood to accept the blower outlet. After blocking the cab vents, P-traps and the range hood vent with masking tape, I turned the blower on and used a brush to "paint" the seams on the MH with bubble soap. It worked! I found that all of the marker lights were leaking, as well as a seam on the bottom of the cabover. Total cost was a couple of $$ for bubble soap.
Leaf blower inserted in plywood on vent (vent cover removed to do this)
Inside of vent with blower outlet showing (screen and vent crank removed)
Leak at front marker light
2003 Winnebago Minnie 24F - Ford E-450
MasterBoondocker
nw lower Meeeechigan, TN and FL
Posted: 10/04/06 08:11pm Link  |  Print  |  Notify Moderator
LOL ......you would need TWENTY leaf-blowers to pressure-check most MH's !!
timmac
Las Vegas
Posted: 10/04/06 08:12pm Link  |  Print  |  Notify Moderator
OK you do the leak test and fix leaks, all day,,, then you take rv out for a drive it twist and turns and all new leaks reappear, than what...
RaynSam
Florida Panhandle
Posted: 10/04/06 08:23pm Link  |  Print  |  Notify Moderator
We used the method (somewhat) on airplanes to check pressurization,the best part of it is that it is simple and it works, I just never thought about using it on an RV.
2002 Chevy,3500 Dually, Duramax, Allison 5 speed,
36ft tri axel,Spinnaker
Banks Exhaust Brake
Prodigy Controller
Ray,Sam and(deputies)Chester and Barney Fife
retired logger
WA USA
Good idea, thanks for sharing info and pic.. I'm impressed.
Short time young and a long time old !
Tom N
Sarver, PA/Crystal River, FL/Indiana, PA
Posted: 10/04/06 08:41pm Link  |  Print  |  Notify Moderator
That's a great idea! Nice photos!!
You can also use a leaf blower to check the automatic feature on an electric awning by blowing air on the wind sensor.
Sarver, PA/Crystal River, FL/Indiana, PA, FMCA
2005 Itasca Suncruiser 38R 38' 11", W24, Allison 2100MH
2008 Honda Odyssey EX-L/2003 Honda Civic EX, Roadmaster Sterling
T18skyguy
Eugene, OR
Posted: 10/04/06 08:46pm Link  |  Print  |  Notify Moderator
Give that guy a cigar! Your handy and that idea's dandy!
Retired Anesthetist. Pilot with mechanic/inspection ratings.1996 Jayco C 22 foot with 460/Banks Powerpak/Bilsteins.Wife and daughter. Two cats which control my life. 1975 Ford F-250, 84 Coupe Deville, Thorp T18, tons of tools and tons of junk.
retired logger
WA USA
Posted: 10/04/06 08:47pm Link  |  Print  |  Notify Moderator
Now I wouldn't of thought of that, thanks. Will check it out tomorrow.
Dogbone
Ontario Canada
Nice work and good idea!
2006 Holiday Rambler Vacationer 35SBD
36ft Workhorse 8.1
AMW1721
Douglasville, GA
Posted: 10/04/06 08:51pm Link  |  Print  |  Notify Moderator
That's what I like about this form , You can always learn something. let's see if it works on my 40fter.
Page of 7
