RV.Net Open Roads Forum: Snowbirds: Alert: Update 05/08/08 Dometic Refer Recall - Fires
RV.net
Search only in Snowbirds
Open Roads Forum  >  Snowbirds
 > Alert: Update 05/08/08 Dometic Refer Recall - Fires
RVSnowbird
OR-NV-AZ-OR
Posted: 11/01/06 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Potential Number Of Units Affected : 926,877
Summary:
CERTAIN DOMETIC TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN APRIL 1997 AND MAY 2003
see Dometic Refer Recall - Possible Fire Hazard in the Tech Issues forum for more information.
....RVSnowbird
* This post was edited 05/11/08 11:48am by an administrator/moderator *
RVSnowbird
OR-NV-AZ-OR
Posted: 11/23/06 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
note important 11/23/2006 Update
RVSnowbird
RVSnowbird
OR-NV-AZ-OR
Posted: 12/05/06 09:34am Link  |  Quote  |  Print  |  Notify Moderator
The latest update as of 12/5/2006 has been added to the 11/23/2006 update.
Dometic has a proposed solution and schedule for initiating the recall.
Basically, they are going to add a second burner cover to prevent the ammonia from getting to the burner if one of the leaks that can cause a fire occurs. In short, they are responding to the safety issue; and there is no info on any help with possible damage that has been done.
Since these refers are all over 3 years old (last production year was 2003), I'm sure Dometic won't do anything for failures that have, or may soon, occur due to weld failures probably caused by the higher powered heating elements.
RVSnowbird
MELM
GA
Posted: 12/12/06 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Serial number and model number information. Grillmeister reminded me that the question has popped up in threads in other forums, and suggested I get the info into them. Two quotes from posts in the thread in Tech Issues:
Grillmeister wrote:
I got through to a representative at Dometic this morning, I was reluctantly transferred a couple times. The only way I was able to convince them to connect me to someone regarding the recall was to tell them I would post the information on the RV.NET Forum and possibly save them a few hundred phone calls. I was finally connected to a gentleman by the name of Brad Sergeant, I explained the question about either being on the model number list and not the serial number list or on the serial number list and not the model number list.
He said you have to be on BOTH lists to be involved in the recall. I asked since my unit was on the serial number list but not the model number list they must use the same concurrent serial numbers on different models, he said yes they do.
I might also add that everyone I spoke to did not seem very happy discussing the topic.
Hope this helps.
Chris Bryant wrote:
I should have chimed in about serial numbers- the way Dometic does serial numbers is the first number is the year, the next two numbers are the week, and the remaining numbers are the numbers for that week- IOW, 4253407 would be the 3407th product built in the 25th week of 2004 (or 1994, or 1984, but the products take care of decades).
Every product Dometic builds goes in to that numbering system, so even air conditioners would have serial numbers in the affect S/N range.
Heck- I even have a Dometic serial number .
MELM
GA
Posted: 01/10/07 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
The Recall has been updated. This was added: THE RECALL IS EXPECTED TO BEGIN BETWEEN APRIL AND JUNE 2007.
Mel
MELM
GA
Posted: 01/19/07 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Update
The recall info is on Dometic's web site: Dometic Recall
Note: "7. If you previously paid to repair or replace a Dometic refrigerator that failed due to this defect, you can be reimbursed for your costs pursuant to Dometic´s Pre-Notification Reimbursement Program. To be eligible for reimbursement under that Program, you must complete and submit the required form and provide the necessary documentation. The Program and form can be obtained by calling 1-888-446-5157."
MELM
GA
Posted: 02/13/07 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Posted in the thread in Tech Issues:
Update 5, Feb 13, 07
Additional info is on the NHTSA websites on the recall. Here are links to these pages:
Instructions and forms for reimbursement for repairs before the recall
The recall letter
Serial number and gas valve information
Dometic's Press Release that is being provided to news media
pawatt
Brainerd MN / Mission TX
Posted: 05/11/08 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Posted: 05/08/08 02:21pm
Thanks to the members who have provided info on this new one.
Dometic has a new recall for refrigerators made between June 1, 2003 through September 30, 2006. Many of these are the same models as were in the older recall (Recall number 06E076000). (Technically, Dometic’s letter indicates an extension of the original, but NHTSA assigned a new Recall Number and the information is under that new number.)
Since it has a new NHTSA number, I’m starting a new thread on this one; but the actual work appears to be the same as in the first recall.
Text from the NHTSA website Recall 08E03200.
Make / Models : Model/Build Years:
DOMETIC / NDR1062 9999
DOMETIC / RM2652 9999
DOMETIC / RM2662 9999
DOMETIC / RM2852 9999
DOMETIC / RM2862 9999
DOMETIC / RM3662 9999
DOMETIC / RM3663 9999
DOMETIC / RM3862 9999
Recall Number: 08E032000
Summary:
DOMETIC HAS REPORTED A SAFETY RELATED DEFECT COVERING 745,574 TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN JUNE 1, 2003 AND SEPTEMBER 30, 2006, WITH SERIAL NOS. 320XXXXX THROUGH 352XXXXX; 401XXXXX THROUGH 452XXXXX; 501XXXXX THROUGH 552XXXXX; AND 601XXXXX THROUGH 639XXXXX, INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS REPLACEMENT EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT.
Consequence:
THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE.
Remedy:
THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL/MAY 2008. OWNERS MAY CONTACT DOMETIC AT 888-446-5157.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
