Spott
SE Michigan
The only windows we have in the rear of our TC are both in the door, the small clear one at the bottom and the upper one that you can't see out of.
I never liked the frosted glass in our upper rear window of the TC, I want to be able to look out and see what is or isn't there.
So today I removed the frosted glass and installed clear tinted glass. A very easy retrofit, removed the screws and pulled the pieces out. Cleaned the old putty off and used the old glass as a template to get new glass cut.
Putting the new glass in was a little harder than expected since I didn't have any extra hands to assist, so I used clear packing tape to hold the glass in the exterior frame while I reassembled everything. I than just cut the exposed tape and pealed it off.
But now it is possible to see into the camper, especially at night so I installed a curtain inside the camper.
edited 02/02/07 03:39pm by Spott *
Me - Kim - Spot
silversand
Montreal
Nice clean looking job!
Have you got a pic of the window and bezel taken out?
Thanks for posting this.
Cheers,
Silver-
Silver
Spott
SE Michigan
Here's a shot of the inside bezel removed.
It's really hard to see in this resized photo, if you want the larger version pm me.
rjweiss
NC
Great write up ! Thanks
Was there a problem getting the right safety glass, size & thickness?
Cost?
Ron W.
2003 Dodge 2500 SLT Auto HO Diesel CC SB
Keystone Cougar 245 RKS 5th Wheel
Rancho 9000
Firestone airbags
Quickair 2
Suzuki DRZ400SM
Suzuki DL650
mustangricky
Renton, Wa
Spot,
I did the same thing in my Host Tahoe. For the curtain the DW made a matching one just slightly larger than the window and we Velcro it into place when in use and that way its easy to store when not needed.
Due to the design in my previously owned 5er you could not stand up and look out a window. We can do that in our TC. It's a small thing I grant you but it adds to the livability to be able to see outside when you're standing...keeps you from having to bend over.
Mustang Ricky
1999 HR 36'Endeavor
Ford V-10 4 Spd
2000 Subaru Legacy Outback
Surf & SUP Boards - Endless Summer
PR Connection
Powell River BC
you know there is one more thing that bugs me about the rear windows. For those of us who have thermal pane windows why don't they make them for the rear doors. It is the only windows in my camper that sweats perfusely in the winter.
Dan
2006 3000SL26 Bigfoot Class C
320 Watts Solar With Bluesky 2000 Regulator
Four 6volt U2200 Batteries
2000 Watt PSW Magnum Inverter
Spott
SE Michigan
rjweiss wrote: Was there a problem getting the right safety glass, size & thickness?
Cost?
This piece is 1/8" and slightly larger than 12.5" X 21.5", you can get any piece of glass cut to fit and sent out to be tempered. This size piece would run $15 standard tinted plate glass and $40 tempered.
Delivery difference is, standard is cut while you wait and tempered is about two weeks.
joe_jeep
hazel park, mi
i can see out my rear window pretty well. the wife is kinda shy, and we havent gotten around to making a curtain yet. she just leaves the bathroom door open to block the view from all the campground peeping toms.
2002 f250 sd shortbed supercab 4x4 lariat v10 3.73
2009 jayco jayflight g2 32rls
2005 jeep wrangler rubicon unlimited sahara
jeep cj, d60's, coilovers, 42's, lots-o-tube
btggraphix
Golden, CO
Nice job Spott. This has been on my list too. I wonder when I will get around to it, but this is a good reference on how easy it actually is.
Thanks!
whizbang
Kenmore, WA
We did the same thing three years ago.
Our curtain has velcro on it so it sticks to velcro strips on the window frame. Easy on - easy off.
Whizbang
2010 F150 with 1994 Jayco Sportster 7ft Pop-up
http://www.raincityhome.com/RAWH/index.htm
