RV.Net Open Roads Forum: Class A Motorhomes: Turning Radius on Larger Rigs
 > Turning Radius on Larger Rigs
gdoily
Posted: 02/07/07 07:45am Link  |  Print  |  Notify Moderator
Question on turning radius for larger rigs - when did the manufacturers of the 40 ft + rigs start to tighten up turning radius? What is the means - IFS? The newer Newells have a turning tag, but they are way out of range for me personally. Was there a general shift in industry at a certain time when they started making these units more manueverable?
Thanks
Rex & Shirley
Bastrop, Texas
Posted: 02/07/07 08:03am Link  |  Print  |  Notify Moderator
Our '00 Win. Itasca Horizon was on the then new Freightliner chassis with a very tight turn radius. Is a very odd feeling to need to look out the side window if you had the steering cranked all the way over.
IFS is Independent Front Suspension. What your car has. Most HD chassis use a forged straight axle like in HD trucks. Nice marketing but I can't see the real value.
Rex & Shirley S.
4 big dogs in a
Gulf Stream FriendShip
JasonD
Annapolis, MD
Posted: 02/07/07 08:40am Link  |  Print  |  Notify Moderator
Our '04 40 footer can turn around in a cul-de-sac no problem. Looking at it, you'd think it'll never make it, but it does with room to spare. Big class A's are more maneuverable than you think.
2008 42' Foretravel Nimbus CE
2007 Chevy Tahoe toad
John Canfield
On the road!
Our chassis has IFS and a wheel cut of 56 degrees. We can maneuver our coach into some extremely tight spots due to the turning radius.
Cheers - John
Our current location
Our blog
Our web site
2005 Itasca Horizon 40AD, 2005 Jeep Liberty CRD
F1/D3/7000 - Datastorm
KOG
Winterville GA
Posted: 02/07/07 09:14am Link  |  Print  |  Notify Moderator
Leaf sprung front axles tend to limit turning radius because the springs have to be set far inboard from the wheels to allow a sharp wheel cut. Use of IFS, coil or air springs allows sharp wheel cut without the tire hitting a spring.
Techie
Pahrump, NV, USA
Posted: 02/07/07 09:15am Link  |  Print  |  Notify Moderator
In addition to the degree & IFS if your tag is liftable you also shorten the turning radius considerably. We can get our 40' w/tag (06 CC Allure) around almost as easily as when we had a 33' gas rig.
2011 Airstream Classic Limited 34'
2011 GMC Sierra 2500HD Duramax/Allison SRW
Follow our adventures
pmx2
Nebraska
Posted: 02/07/07 05:51pm Link  |  Print  |  Notify Moderator
The answer to your question is yes there is a general shift to make large motorhomes more maneuverable and reduce the turning radius. Like John above, we have a Horizon with a 56 degree wheel cut and it can make a very tight turn for a 40 ft unit. Look for units with wheel cuts of 56 degrees or better and you will get good turning performance with or without a tag.
2cyber71
Pennsylvania
Posted: 02/07/07 05:55pm Link  |  Print  |  Notify Moderator
My 40ft Mh has a 55 degree wheel cut, nice.
gdoily
Posted: 02/07/07 08:47pm Link  |  Print  |  Notify Moderator
Thanks for the responses..
Did a little research, and found the following on the Newell Tech Talk board from one of their technicians:
Adjusted properly, the turning radius of a 45 foot Newell with the Dana IFS (1997 - 2004) is approximately 44 feet. With the new ZF suspension, including the active steering tag axle, the turning radius is approximately 37 feet.
This seems consistent with some of the other manufacturers specs - some of the very newest designs get down to around 37', and otherwise, with the IFS, most are around 44' (for a 45' bus).
chastho
arkansas
Posted: 02/07/07 09:15pm Link  |  Print  |  Notify Moderator
Some 07's now have 60 deg wheel cut.
