RV.Net Open Roads Forum: Class A Motorhomes: F53 OWNERS - Tips & Suggestions
 > F53 OWNERS - Tips & Suggestions
Page of 19
NAUTIQUE
SOUTHEASTERN MA.
Posted: 04/02/07 11:20am Link  |  Print  |  Notify Moderator
Well I finished the DREADED V10 plug change this weekend.
There are some good threads over on FTE about this, but thought it would be helpful here to.
I thought that this would be fairly simple in the MH, since you're basically working on top of the engine:
I found it to be a very stressful job. Lots of stuff in the way. Lots of scraped knuckles/cuts/sore knees & back! Took me just about 4 hours to do the whole thing.
Basically went like this:
* Remove 7mm nut holding COP in place
* Get fingers down in there & pop COP/Plug Boot out of spark plug hole
* Pull Boot off. Twist Spring out of COP.
* Blow out spark plug hole. Here's a pic of my air hose extender:
* Use a good 5/8" spark plug socket w/ rubber insert.
* You need plenty of socket extensions!
* Feed socket/extension down into hole and onto plug.
* Add extensions as needed and loosen plug about a turn.
* Blow out again! (I repeated this a few times as I worked it out.)
* Gap new plug to .054 and paint threads w/ Anti-Seize grease.
* Used socket plug & extension to gently get plug back in & started.
* Used more extensions & torque wrench. Torque to 120 in/lbs. first.
* Did (5) plugs on one side & then went back & torqued to 160 in/lbs.
* Install spring into Cop.
* Apply Dialectic grease on each end of Plug Boot. Slide over spring.
* Slide COP/Boot down into hole over plug and reinstall 7mm nut.
* Repeat (5) times - Have a beer - Repeat (5) more times!
Here's the parts/tools I used:
Bottom line is, by doing it yourself, you know you've got the Anti-Seize on the threads and you haven't over-torqued the plugs (stripping threads), so for piece of mind it's worth it.
Our Portable Summer Cottage II : 2000 GBM LANDAU on 1999 F53 chassis
Sumitomo ST718's,Bilstein's,Steer-Safe,UltraTrac
& Aventa II pulling a 97TJ
- Pics & Mods * GBM Thread * F53 Thread
The Crew: Lovely Wife,2 Daughters & Springer Spaniel!
LIFE IS GOOD!
mtrumpet
Hamburg, NY
Posted: 04/02/07 02:54pm Link  |  Print  |  Notify Moderator
Thanks for posting that great proceedure info NAUTIQUE. That will be very handy to have when it comes time for me to change my plugs.
You'd mentioned that you had to move some things out of the way in order to get to the plugs. What/how many items had to be removed?
If doing this job over again, is there anything in the proceedure that you would do differently?
Mark & Cherie (& Chloe)
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
Thadd
Rolling Hills Estates, Ca (SoCal)
Posted: 04/02/07 06:21pm Link  |  Print  |  Notify Moderator
I threatened to start a "I HATE MY F53" website, but have cooled down a little. This all started when I bought my used rig with 16,000 "easy" miles on it a few years ago.
My F53 is under a 97 Southwind 32 with the long (226"?) wheelbase. It will NOT go straight. I replaced the original Michellins with Bridgestones and that helped. I used 245 70X16s on the front so I could soften up the air pressure to help the harsh ride but had to keep the 235 85 X16s on the rear because the 245 sidewalls would have touched.
(Who in his right mind would put a 16" wheel under a 32' Motorhome? The same rig on a P30 has 19.5" wheels)
I have added a Davis panhard rod..helps a little; I added a safe-T-steer which helps a little in cross winds. I have had it at the front end shop twice and it still won't go straight.
Remember when we were kids and had those old $75 cars that had worn out steering boxes? That what this is like...I put a little left into and wait for it to go left; then I go past the greasy spot in the middle and nudge the wheel to the right; when it starts to go right, I ease it back to the left...It is constant steering..It is like there is 2" of play in the steering and it won't go for 20 feet without steering input.
Evertime we hit a bump, it sounds like the instrument panel is going to fall out. Fleetwood mounted it on hinges for easy access, but I have run some screws down into it to quiet it down.
460 Power, what a joke. I guess that I am spoiled because I have always had GM power in my previous rigs. I understand that the V-10 will pass everything but a service station. The V8 is a slug. I have added (recently) a Banks kit with out headers, and it seems to be a little quicker. I also added the trans command. This last week was the first trip since the Banks was installed and it seems to pull hills better and also seems to be a little more fuel efficient. I figure that I got around 8 MPG on a trip that normally is around 6.5 -7, but I really am working hard at staying at 55 (almost impossible in Socal). Also the trans doesn't seem to kick down into 3rd as quickly, which I think is a major improvement.
While it was at Banks, they notified me of a waterpump leak (33,000 miles) so I put it in the local shop. While it was there, they called to tell me that one exhaust manifold was cracked. I should have paid the extra to Banks for headers !!! DOH !!!
As I am getting up in years, I am facing the possibility that this may be my last motor home. I would like to be able to up grade the ride and power as we both grow older together, but I might just sell my 55 Chevy and buy a unit that is not on a Ford Chassis...I have bought my last Ford ANYTHING !!!!
Thadd 32H southwind
Be the person that your dog thinks you are
NAUTIQUE
SOUTHEASTERN MA.
Posted: 04/03/07 05:25am Link  |  Print  |  Notify Moderator
Hey Trumpet,
I didn't need to really remove anything.
It's more like a "nest" of stuff above certain plugs (wires, hoses, ect).
The toughest part seemed to be with the COPs. You need to work your fingers down in there, pop it off, move it to get old boot off & new on, then work it back into place.
On the plugs, you can use the socket/extension to feed it down thru the "nest" into the hole and then get a good view of where you can feed additional extensions thru to get the torque wrench on.
Not really anything I'd do different. Just need to leave yourself plenty of time to do this job - Go slow & easy!
map40
MI
Posted: 04/03/07 07:05am Link  |  Print  |  Notify Moderator
Here is a post I did some time ago on the Manifold bolts:
I'm posting this message so if somebody has to get through what I got through, at least has a reference. It migh be basic for most of the folks in this site, but I would have liked something like this, so I hope it helps somebody. I'm not an expert on this matter, so don't take my guide as a certified method. It is my experience, and if you where to use any of it's information you will be doing it at your own risk.
I started finding a broken bolt in my rear passenger exhaust manifold, broken flush to the manifold (the best case).
Just in case you've never seen one, here is a picture
So, the next step was to find a replacement/solution. I was quoted anywhere from 3000 to 700 for fix. I could have done it myself too. Another point was if I wanted to go with the same components or change to headers, which will avoid future recurrences on this issue.
Reality is that exhaust manifold warp due to excesive heat and temperature changes. The manifold can take anything while the exhaust system is in good condition. A vehicle that is stopped for month at a time suffers of exhaust clogging, which increases the temperature of the manifold, which makes the condition worst. That's why this condition is worse in MH than in other vehicles with the same engine. Headers have other problems, mostly overheating beyond what the adjacent equipment can tolerate. For this reason, don't put headers not designed for MH. By a Kit, or headers specifically designed for MH, which will adress the extra heat (even adding heatshields).
I bought the Gibson system from CW. Nice cat back system. Took a week to get to the store. I was going to install it myself, but I was missing parts, so I had to get a shop to install in.
I found a shop in Oxford, MI, which agreed to install the system.
If you do it yourself, or if a shop installs it, if you can, the best is to soak the bolts with PB blaster or another penetrating oil (I did it for 10 days, at least once a day). This will ease out the bolts. I personally recomend using a air impact wrench. I pulled some of them out, and the impact wrench made it easier. The main objective is not to brake any more bolts.
Another thing is the air injection hoses. The come from the manifold to the intake manifold. The cost is around $100 for new part. My recomendation is to don't bother getting them out if they are too rusted, just cut them and buy new ones. In my case, they both broke, and we wasted the time to take them off.
Next step is to take the O2 sensor. UNPLUG IT BEFORE YOU TAKE IT OFF THE MANIFOLD. Put it somewhere else where it's safe, you don't want to mess it up.
Once you pull the manifolds off, you need to clean the area. The shop did not only cleaned the area, but also sanded the block and painted with high temperature black paint. Now that's what I call a good job. They not only cleaned everything, but painted the block and the rails, without painting anything that was not suppoused to be black. They even did it to the generator exhaust. (Yes they did a nice job)
At this point, you need to install the headers (in my case). If you choose to re-install you manifolds, you need to check them for flatness. If they are not flat, you can get them machined. If you do, ask the also to slot the bolt holes so the manifold can move without braking the bolts.
The headers need to be instal according to the instruccions, but in my case, the shop suggested to do a little change. Instead of using the regular header bolts that came from Gibson, they suggested using
stage 8 locking bolts from Ford Racing. According to Gibson specs, you need to re-tighten the bolts every 3000 miles. This bolts solved this issue. I also talked to Gibson and they said that this bolts would not affect the warranty. In any case, CHECK with the manufacturer of the headers, because some locking bolts will void the warranty. (Ask them for your case, don't use them because I said they woulod honnor the warranty). We got them from Summit racing, for $44. After I researched a little bit I found that re-torquing the bolts every 3000 could get to some problems, and not touching them could cause even more problems, so I concluded that the shop was right.
After installing the heathers, they tried to install the Y and id didn't quite fit. Also, the o2 sensor didn't reach the new location. This costed us 1 week of sending pictures to Gibson and calling them to discover the problem. Here is what I learned from this:
1) Your O2 sensor should be locater in the same section as before, and aprox. at the same distance than the original system. If it doesn't, something could be wrong. Check with the manufacturer.
2) This kits are desing to be installed with no major problems, so when you find one, don't hesitate to call them.
The shop would not install the system because they where not happy with what Gibson was telling them. They where right at the end, it was the wrong Y for my system.
The rest of the instalation went by with no problems, except that the last piece of the pipe os 1/4 inch away from the bottom edge of the sidewall.
Once everything is installed, check for leaks.
Here there are some pictures on how it looks now:
Once again, I just wanted to provide some tips and little guide with what I leadner about this, just in case somedoby needs it. Please feel free to add any other info on it. Thanks.
Here is a link to the original post:
http://www.rv.net/forum/index.cfm/fuseac........d/15566066/gotomsg/16500359.cfm#16500359
* This post was edited 04/03/07 07:17am by map40 *
2007 Four Winds 31F
Life rocks when your home rolls
garym114
Bluff Dale, Texas
Posted: 04/03/07 07:39am Link  |  Print  |  Notify Moderator
What year was the engine changed to fix the thread problem on the spark plugs?
jeepfreak
Hanover Ma.
Posted: 04/03/07 10:05am Link  |  Print  |  Notify Moderator
just a quick note, when you get the Banks system you get everything you need to install the system . including the extension wire for the o2 sensor. and everything fits on the ford exhaust hangers. best after market parts I've ever installed!
2007 Allegro 34wa Workhorse 8.1, Allison 6-speed. Bow Tie powered 79 CJ-7 TOAD ,when A/C IS needed 2007 Jeep Commander
mtrumpet
Hamburg, NY
Posted: 04/03/07 09:13am Link  |  Print  |  Notify Moderator
NAUTIQUE wrote:
Hey Trumpet,
Great! Thanks for the info!
Also, thanks Map40 for the info regarding the mainfold.
I for one am very appreciative for this information and will put it to good use.
I also like the mentioned idea of a "sticky" for F-53, V-10 Motorhome owners. That way it would be dedicated to motorhome issues regarding this engine and chassis.
Codfish
St.John's,nfld,Canada
Posted: 04/03/07 09:38am Link  |  Print  |  Notify Moderator
I have a 99 Georgetown on a Ford chassis and it does not stay true on the highway - you have to constantly correcting it on the steering. I'm wondering about a steering stabilizer and maybe new shocks. There is 20000, miles on it.Any suggestions?
FL Mike
Ormond Beach, FL
Posted: 04/03/07 02:43pm Link  |  Print  |  Notify Moderator
FAced that water problem during a hard rain in our 2000 GBM on the Ford F53. Driving on I-26 in South Carolina got caught in an extremely heavy rain. Engine kept cutting out for a brief moment, then would come right back. Glad to know it wasn't just me...
Page of 19
