RV.Net Open Roads Forum: Tow Vehicles: Dodge 3500
Search only in Tow Vehicles
 > Dodge 3500
Needs Sleep
Pacific Northwest
Posted: 03/31/07 01:00pm Link  |  Print  |  Notify Moderator
For reasons I don't want to get into right now or I will break something....
Can someone please post a photo of the Serpentine belt routing decal that is apparently mounted on every Dodge but mine? It's a 2004 1/2 with the Cummins.
Thanks.
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 03/31/07 01:53pm Link  |  Print  |  Notify Moderator
Trucks with the Diesels do not have a routing decal. You can get it from Auto Zone or most other parts dealers. I found a pic of it will try and post it.
Ok just click on the "pic" link in my sig then the 2004 Dodge Ram 2000 CTD and you will find it.
You can check here also. TDR
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
How many remember this?
Pics of stuff
Ray,IN
IN, USA
Posted: 03/31/07 02:37pm Link  |  Print  |  Notify Moderator
Public libraries have auto repair manuals for use. Your belt routing depends on the year, options, and in some cases if it is a CA certified vehicle. My old 1996 Dodge CTD had a routing sticker, and my present Duramax does.
fj12ryder
Platte City, MO
Posted: 03/31/07 02:58pm Link  |  Print  |  Notify Moderator
Sure, I have an '01 Dodge Cummins dually and it has the routing. Here's a shot of it: http://home.kc.rr.com/howandpeg/Belt%20routing.jpg
Howard and Peggy
"Don't Panic"
Perrysburg Dodgeboy
Posted: 03/31/07 03:29pm Link  |  Print  |  Notify Moderator
03 and newer use a differnt routing and as far as I know I have not seen any routing decals on the 03 and newer CTD trucks, not any of the trucks I have seen anyway (mine and 4 other buddies trucks).
Don
klenger
Tucson AZ
Posted: 03/31/07 05:59pm Link  |  Print  |  Notify Moderator
http://www.klenger.net/misc/Dodge_Serpentine_Belt.pdf
This file shows the routing for w/AC, w/o AC, and with the Jacobs Exhaust Brake (3 pages)
* This post was edited 03/31/07 06:13pm by klenger *
2008 Tiffin Allegro 32BA FRED Class A Motor Home
Looking at trading for a Winnebago Access 31C Class C
Kjun
601 Hudson Dr, Westlake, LA
Posted: 03/31/07 06:11pm Link  |  Print  |  Notify Moderator
Ok. I can not get this picture to load so here goes. Looking at the front of the engine and starting at the crankshaft. In a clockwise rotation with the crank at 6:00. Go around the bottom side of the crank with the grove side of the belt. The belt travels up over the tensioner. the tensioner rides on the back side of the belt. Then travels down toward the air conditioning compressor on the grove side. Then up to the alternator on the grove side. then down around the water pump on the flat side. then up to the idler on the grove side. then down around the power steering pump on the grove side. then around the fan on the flat side. then down to the crankshaft on the grove side where you started. This is for a 2003 with air conditioning. The non A.C. version is different. I also have that routing. Let me know if you need it. I hope you can understand this and it helps.
JIMNLIN
out here
Posted: 03/31/07 06:26pm Link  |  Print  |  Notify Moderator
my '03 2500 Dodge/Cummins has belt load decal
'97 Park Avanue 28' 5er 11200 gvwr two slides
Lone Stars
Posted: 04/01/07 10:00am Link  |  Print  |  Notify Moderator
klenger,
If I had to pick one forum member in all the forums I visit who I think has been the most help to me personally it would be you, sir! Thanks for your informative posts.
'04 Dodge CTD QC SB SRW Pullrite Superglide
'02 HitchHiker Discovery
 > Dodge 3500
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
