RV.Net Open Roads Forum: Toy Haulers: Buzz in outside speakers - '07 Rage'n
RV.net
Search only in Toy Haulers
 > Buzz in outside speakers - '07 Rage'n
Page of 5
Al/Reeni
Ft Myers, Fl
Posted: 04/04/07 09:34pm Link  |  Print  |  Notify Moderator
Now I've got nothing against a good buzz, but on our first outing last weekend, I noticed a "buzz" in the exterior speakers after they'd been on a while (maybe an hour). Didn't matter if it was CD or radio, and not evident on inside speakers. Then, it would stop for awhile, and then come back. I tried to isolate it to something running in the TH, but nothing correlated. Any ideas?
whanner
Posted: 04/04/07 09:55pm Link  |  Print  |  Notify Moderator
maybe a bad ground or a bad solder joint. when the unit heats up it will cause the circuit board to expand and cause bad connections on the circuit board.
one way to test for a bad solder joint is to tap on the unit when its making the sound. If it clears up that may be your problem. if its under warranty I would take it back and have them replace it. our unit did the same thing and they replaced the unit.
06' Ford F-350 Power Stroke 6.0L
07' Forest River Sierra 375 QBQ
Wife and 2 Kids
whanner
Posted: 04/04/07 09:58pm Link  |  Print  |  Notify Moderator
was this a concertone by any chance?
Al/Reeni
Ft Myers, Fl
Posted: 04/05/07 06:45am Link  |  Print  |  Notify Moderator
Kenwood stereo, with Concept speakers.
Trvlngnrs
St. George, UT
Posted: 04/05/07 07:09am Link  |  Print  |  Notify Moderator
Try turning the inverter off, if you have one.
Also turn off all flouresent lights.
Steve
St. George, UT
'06 WW FB2200
'07 Outlander Max XT
'04 Chevy Duramax
Al/Reeni
Ft Myers, Fl
Posted: 04/05/07 07:24am Link  |  Print  |  Notify Moderator
Hmmmm, don't have either of those. It only seems to be in the outside speakers, which tells me it's not interference in the the receiver, and it will come and go. Just about the time it gets annoying, it stops. Sometimes it's there when you first turn it on, sometimes not until it's been on for a while. I'm baffled.
whanner
Posted: 04/05/07 07:31am Link  |  Print  |  Notify Moderator
it there a fridge near the speaker or unit?
JeeperAz
Az
Posted: 04/06/07 03:09pm Link  |  Print  |  Notify Moderator
Was your water heater or water pump on?
My Ragen's speakers make a buzzing noise with one of the two items on (cant remember which one).
From what I have read, this is a common issue on Ragen's. Call the factory and ask them about it.
'06 GMC 2500HD Duramax(LBZ)
'06 Ragen FB2500
Larry & Mindy
Backseat: Maya (black lab)
Trvlngnrs
St. George, UT
Posted: 04/06/07 03:56pm Link  |  Print  |  Notify Moderator
Try running some temporary speaker wire to one speaker. If the other buzzes, and the one with the new wire doesn't...rewire them. The speaker wire may be laying against an electrical wire and picking up interference.
I had a 40 foot motorhome with a 2,000 watt inverter. When I dry camped, one of the electrical outlets hummed from the inverter...that's why I suggested turning it off.
Al/Reeni
Ft Myers, Fl
Posted: 04/06/07 07:03pm Link  |  Print  |  Notify Moderator
Water heater was on, pump was not, as we were hooked up in a CG. We're going again next weekend, and I'll try to isolate it further.
Thanks for the help, so far.
Page of 5
