RV.Net Open Roads Forum: Travel Trailers: Fresh water tank drain spicket
 > Fresh water tank drain spicket
Anita967
Indiana
Posted: 04/06/07 06:08pm Link  |  Print  |  Notify Moderator
The plastic drain spicket keeps breaking, is there another way to make this work ? The only thing I can come up with,is using an outside garden hose faucet for a house w/flange. Any help in this matter would be very helpful. Thank You Jim
mockturtle
Northwest
Posted: 04/06/07 06:27pm Link  |  Print  |  Notify Moderator
We replaced the plastic valve with a metal ball valve. We knew it was just a matter of time before the plastic one broke.
Husband: Derek
Dog: Bucky
RV: 2000 Aerolite 19RB TT
TV: 1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
skipnchar
Topeka Kansas USA
Posted: 04/06/07 06:43pm Link  |  Print  |  Notify Moderator
Might be a good idea to find out WHY they're getting broken. If it's hanging low and dragging or something if you put a stronger valve you COULD damge the tank itself.
mockturtle
Northwest
Posted: 04/06/07 06:57pm Link  |  Print  |  Notify Moderator
Ours isn't 'hanging down' at all, unless we're draining our tank. It just sits in the compartment.
hwybnb
Posted: 04/06/07 06:59pm Link  |  Print  |  Notify Moderator
Those things are cheap and flimsy to begin with and after being expose to the sun for a while the plastic gets brittle. I have replaced several of them. A permanent solution is to reroute the drain line to go out under the RV and put a brass ball valve on it like mockturtle did.
dodger51
Camby, Indiana
Posted: 04/06/07 07:46pm Link  |  Print  |  Notify Moderator
The brass ball value would be the best way to go.
Bill 720
Lawton, Ok, USA
Posted: 04/06/07 08:03pm Link  |  Print  |  Notify Moderator
HI: I have had the same problem and carry a couple spares. If I ever find one in brass, I'll certainly buy it and replace the plastic. Bill
mockturtle
Northwest
Posted: 04/06/07 08:29pm Link  |  Print  |  Notify Moderator
We bought ours at Lowe's Hardware.
