RV.Net Open Roads Forum: Class C Motorhomes: Tioga Tire pressures
 > Tioga Tire pressures
Leewhiz
Johnstown, NY
Posted: 05/13/07 06:16pm Link  |  Print  |  Notify Moderator
I would read the pressure rating on the sidewall of the tire and then inflate the tire to the tire manufacturers pressure. In fact on my 1996 Tioga, the front two tires are Goodyear that state 80 psi, and the rear four are Cooper and they are rated at 65 psi. So that's what the tires are at. I have had no problems so far.
Lee
Greyeagle44F
Stratham NH USA
Posted: 05/14/07 05:56am Link  |  Print  |  Notify Moderator
The psi on the side of a tire has no bearing whatever on what the presure should be, it merely reflects a maximum pressure for that tire. Its proper pressure is based on factors relating to the wehicle on which it is used.
Believe it.
The U.S. Military: "All gave some, some gave all."
The Ancient Aviator
2002 26Q Tioga, Michelin Sneakers, Front XPS, Rear LTX M/S, no chassis "gimmicks" (Wind Machine sold APR 2006...pushing my luck at 84 years and a high performance bird).
Westronics
Redmond, WA
Posted: 05/14/07 07:52am Link  |  Print  |  Notify Moderator
Without doubt, the best material on RVs and tires is published by Michelin. I strongly recommend watching the Michelin videos ([url=http://www.michelinrvtires.com/michelinrv/toolbox/videos-demos.jsp]RV - The critical factor[/url] and [[url=http://www.michelinrvtires.com/michelinrv/toolbox/videos-demos.jsp]Things RV Owners Should Know[/url]), reading the [url=http://www.michelinrvtires.com/assets/pdf/RV_Brochure.pdf]RV Tire Guide[/url] and [url=http://www.michelinrvtires.com/assets/pdf/TB-Service-Life-for-RV-Tires.pdf]Service Life for RV Tires bulletin[/url], and following the [url=http://www.michelinrvtires.com/michelinrv/tires-retreads/load-inflation-tables.jsp]RV Tire Inflation Tables[/url]. edit: Updated for Michelin site changes.
Note: Due to invalid formatting, all formatting has been ignored.
* This post was edited 07/06/07 09:26am by Westronics *
2002 Jayco Greyhawk 24SS, Cameras (RVCams), ScanGauge II/Blendmount, 300W Inverter, Airtabs,12' Portabote w/sail, Be kind to septic systems.
Ford motorhome customer service: 1-800-444-3311.
Greyeagle44F
Stratham NH USA
Posted: 05/14/07 09:14am Link  |  Print  |  Notify Moderator
Hear Westronics well...and we will all be safer.
