RV.Net Open Roads Forum: Class C Motorhomes: Hardwoods: I did it!
 > Hardwoods: I did it!
Class C Motorhomes Related Tips
jorn
Twin Cities
Posted: 05/29/07 08:26am Link  |  Print  |  Notify Moderator
Some time ago, I posted about the seriously messed up floor in my class C. In a nutshell, the carpet was pretty tired out and there were some rather concerning soft-spots.
Behold the horrendous mess.
Initially, I considered carving out the bad areas and just replacing the flooring. Well, without a solid space for the seams to land upon, this sounded like a bad idea. So, I instead dropped down a new layer of 1/4" plywood, which was then glued and nailed to the original flooring. The idea was that this would bond with the original floor and create a renewed subsurface. You know, one that didn't give you the sensation that you might step right through it.
New subfloor going in next to bathroom.
Once that was done, I really needed to decide if I was going to replace the carpeting with new carpet, or go all the way and drop down laminate-hardwoods. We wanted the wood, but I have never done anything remotely similar to this is my life. I was scared. Well, long-story-short, I managed to pull it off, as you can see below!
You can view more of the pics here. All that's left is to find just the right pice of carpet remnant for next to the bed and to replace in the cab.
w00t
* This post was edited 05/29/07 08:41am by jorn *
2001 Coachmen Leprechaun 314SS (Acquired in July 2008)
tizzyfit1
Auburn, WA
Posted: 05/29/07 08:37am Link  |  Print  |  Notify Moderator
EXCELLENT Job! Did the 1/4" subfloor totally eliminate the problem?
jorn
Twin Cities
Posted: 05/29/07 08:47am Link  |  Print  |  Notify Moderator
That's a damned good question, thanks for asking.
Short answer:
Mostly. Good enough.
Better answer:
The original flooring was only 3/8" (gasp!) thick particle board that was glued down on top of what appeared to be 1" foam-board. I know this because I cut a small 1" sample hole for inspection. As previously mentioned, there were places so gooshy it felt as if you might be able to stomp right through. So how is it now? Even knowing where those spots are, the cocktail of the plywood/padding/hardwoods made these spots almost like new.
If I were to do it again, I would have made a better effort to level the original flooring some more with a compound designed for just such a purpose. I also would have glued down the new 1/4" stuff with a lot more glue. Still, the plan worked well enough for a beat-up, 20-year old RV.
santosdg
Nor Cal
Posted: 05/29/07 08:55am Link  |  Print  |  Notify Moderator
Well, I think that you did a beautiful job and I was impressed with the finished product. Now what is the next project going to be? lol
Happy Camping Family 8
2003 Jayco Granite Ridge 3100SS
"Live, Love, Laugh!"
spkncarl
That Way
Posted: 05/29/07 09:04am Link  |  Print  |  Notify Moderator
Huge improvement....Great Job!!!
jorn
Twin Cities
Posted: 05/29/07 09:05am Link  |  Print  |  Notify Moderator
Thanks for the compliment! I seriously was way in over my non-handyman head here, so I'm shocked it turned as well as it did.
What's next? Oh, you HAD to ask
  • The dash AC doesn't work. This is gonna be expensive.
    Both the interior and exterior shrouds for the roof air need to be replaced. No biggie.
    Despite not one but two fixes I thought went well, I still get a leak near the shower in a heavy downpour. I'm sick to my stomach just thinking about this one. I'm gonna bring it somewhere to have it pressurized to look for exactly where the leak is. This guessing isn't working anymore.
    We want to replace all the wallpaper.
    The seats in the cab are fugly; they gotta go.
    Now that I have a TV tuner in my laptop, I suddenly care that the antenna is trashed.
    An exterior shower would be nice.
    The wife wants a new toilet.
    The generator runs poorly in warm weather.
pipers family
Central Texas
Posted: 05/29/07 09:44am Link  |  Print  |  Notify Moderator
Isn't it nice to be "needed". The flooring looks great- I am totally impressed.
gohogs34
Millington, TN.
Posted: 05/29/07 10:27am Link  |  Print  |  Notify Moderator
Great job. I am considering doing this in our class A Mirada. Scared to start. Questions? Is the heat in the MH setting around now used going to make the floor buckle due to not able to move with the bench, couch bolted through it? How do you cut around the batchroom door way and how did you do the steps. I have two steps and was may leaving them carpet, but yours looks good. Thanks for you help.
chrisguld
Posted: 05/29/07 11:15am Link  |  Print  |  Notify Moderator
Good Job Jorn! I especially like how you ran the flooring up the wall, and down the steps. It's beautiful.
We too got rid of our carpet. We put down vinyl tile. Actually, we didn't do it .. .I wouldn't know where to start! But luckily we have great friends who do this kind of stuff all the time. Check out this complete motorhome remodelthat they did
Pictures of our floor project are on our blog here.
Chris Guld
"Blessed are the Flexible, for they shall not be bent out of shape!"
Full time in our 30' Safari Class C with Datastorm
See our weblog/travelog, at GeeksOnTour.Blogspot.com
RV.net Blogger
jorn
Twin Cities
Posted: 05/29/07 11:25am Link  |  Print  |  Notify Moderator
Thanks! I debated wooding-in the step, but everybody who has seen it likes it. It wasn't easy, given that the entire "bucket" that represents the step is made of cold, hard steel. Brad nails don't exactly fire through that stuff!
That looks fantastic! It also looks quite familiar. Seriously, I found out how easy laminate-hardwoods are to install. I had the click-together kind. It's prep and the trim that takes time.
Nice.
