RV.Net Open Roads Forum: Fifth-Wheels: Challenger Black Tank Flush
 > Challenger Black Tank Flush
KY5B
Wise County TX
Posted: 05/29/07 04:00pm Link  |  Print  |  Notify Moderator
Just purchased a Challenger from Keystone. 29rkp. It has a Black tank Flush hose connection. It doesn't work...i.e No water gets to the balck tank. Keystone told me it was possibly a check valve problem. However there is no check(backflo) valve at the hose connector. Keystone customer service could not help me. Has anyone else had this problem? Rig was purchased and manufactured in Feb 2007. Yes, I have the black tank valve open...(smile) Thanks
dbbls
Arkansas
Posted: 05/29/07 04:18pm Link  |  Print  |  Notify Moderator
If it was manufactured in Feb 2007, the problem is Keystones. Take it back to the dealer.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
jjfay03
Washington State
Posted: 05/29/07 11:10pm Link  |  Print  |  Notify Moderator
Hello, I just bought a Challenger 34 BHS this weekend please let me know what the problem was and if Keystone was helpful fixin your problem.
THanks,
John
John and Jeannine + 3 Boys.
2007 Dodge 2500, 5.9 CTD LB, Husky Brake Controller,
Linex, Firestone Airbags, and a Pac Brake.
2017 Jayco Eagle HT 29.5BHDS 5th Wheel
3 Man's best friends!!!
Humpty
Clayton, NC
Posted: 05/30/07 08:08am Link  |  Print  |  Notify Moderator
We just got an 07 33DBB with 2 black tanks. One Flush works, the other does not. I have not had a chance to trouble shoot yet. When I have a chance, I will remove the panel by the 'water works' station to look for an anti-siphon valve. I bet there is one installed backwards somewhere.
If I can't figure it out, I will let the dealer take care of it at the end of the season.
2007 Challenger 33DBB parked on the Coast
2016 GMC Canyon Diesel
TnTtravelers
East Slope Sierra, California, USA
Posted: 05/30/07 08:47am Link  |  Print  |  Notify Moderator
Check to see if the black and grey dump valves are marked backwards. And please let us know what you find. I suspect that this may help others with similar models...
Tim and Tina (kudo too)
Livin' good, while the livin's good!
2005 Ford F350, 4x4, Crew Cab, Short box
2007 Everest 295TS 5th Wheel, Superglide hitch
JT Stabilizers">
Firestone Air Suspension System
TST tire pressure mntr system
exakpix
Oklahoma
Posted: 05/30/07 09:40am Link  |  Print  |  Notify Moderator
My Everest had an anti-siphon/pressure release valve that started leaking; after I tried to clean it then it plugged completely. Found it behind the shower faucet. Keystone was not much help so I just put in a brass staright line check valve and it works just fine. Here's the original: http://groups.msn.com/WarrenandLynda/ala........a2006.msnw?action=ShowPhoto&PhotoID=1705
'05 Keystone Everest 323P
'01 F350 Crew Cab 4x4 V10
Goin4forty
Wisconsin
Posted: 05/30/07 09:42am Link  |  Print  |  Notify Moderator
Mine has always worked fine however our friends was installed backwards. If they are not taking the time to look at the part it is a 50-50 shot I guess. We took off the panel ,and turned it around and now it works fine. I agree that this is a dealer issue and should be easily fixed by them.
Even if you have the black tank valve closed, water will still flow through the flusher, that is if the backflow preventor is installed correctly. It will just fill up your tank in time and that can create a mess. [emoticon]
2007 34RBH Keystone Challenger
2005 Chev 2500HD CC, D/A, 4X4, Hypertec, Prodigy, Mor-Ryde, Firestone Airbags, JT Strong Arm
2007 Polaris Ranger SE XP700
KY5B
Wise County TX
Posted: 05/30/07 01:16pm Link  |  Print  |  Notify Moderator
Thanks for the feedback folks. EXAKPIX, how did you get to the valve behind the shower? I think you have my problem identified. The hose from the Flush connection goes up to the rear of the shower!! The picture you sent goes well with the information from Goin4forty. Thanks again.
KY5B
Wise County TX
Posted: 05/30/07 01:23pm Link  |  Print  |  Notify Moderator
Further information for others who replied. The valves are marked correctly. I removed the wall behind the "water works" and there is no check valve where the hose connects to the flush connector. Keystone did tell me to look there to see if the valve was deffective or in backwards. Keystone also told me that the Challenger builders will very often change things during construction and it is difficult to keep up with their changes. Keystone customer support did not have any plumbing diagrams from Challenger.
exakpix
Oklahoma
Posted: 05/30/07 02:24pm Link  |  Print  |  Notify Moderator
Certainly don't know if your valve is behind the shower faucet or not, mine is, but sometimes you find them under the bathroom sink. I removed the 4 screws holding the shower faucet to the enclosure and gently pulled the faucet out...be careful, on mine the hot and cold and black tank rinse lines were tie wrapped together. Look around under your bathroom sink faucet first to see if it is there. Good luck.
