Truck Campers Related Tips
dhackney
San Diego
I thought the folks on this forum might be interested in this 4x4 TC project we just finished.
Project complete Sunday 3 June, 2007 ~8PM PDT / 0300 GMT / Zulu
Rollout shot:
Project: Hackney Expedition Vehicle
Goal: Self-sufficient, Self-Extracting Global Expedition Vehicle
Mission: 2 - 3 years of unsupported exploration primarily in developing countries
Project time: One year
Build time: Nine months
Project type: Private
Funding: Privately funded, no commercial sponsorships, endorsements, financial or product support
Concept design: Douglas Hackney - inspired by an FG/Bigfoot design of Carl Hunter
Bumpers, frame extension, pivot frame, storage box, etc. design and implementation: Mark Johnson
Electrical, plumbing, electronics, etc. systems design and implementation: Douglas Hackney
Custom storage boxes: Fleet Metal Box
Powder Coating: Jerico Metal Fabrication and Powdercoat
Chassis: 2007 Mitsubishi Fuso FG 140 4x4
Camper: 2006 Bigfoot 20C10.11FR
Engine type: DOHC 4-stroke cycle, water-cooled, turbocharged, intercooled diesel
Power: 147 HP @2700 RPM / 108.12 KW
Torque: 347 ft/lb (lbf/ft) @1600 RPM / 47.97 kgf/m
Displacement: 299 c.i. / 4.899 liters
Bore/Stroke: 4.49x4.72" / 114x120mm
Drivetrain: four wheel drive, manually selected, dual range
Front axle: open
Rear axle: limited slip
Transmission: 5 speed manual
Overall gear ratio (1st Gear - Low 4 Wheel Drive): 64.2:1
Top speed: ~75 m.p.h. / 120.70 k.p.h.
Cruising speed: 60 m.p.h. / 96.56 k.p.h.
Tires: Mud & Snow Yokohama Y-7428 LT742 235/85R16; 3 polyester plies sidewall, 2 steel plies tread
Spare tires & wheels: two
Overall length: 27.17' / 7.98 meters (tip of front bumper to rear bumper)
Overall height: 12.04' / 3.67 meters
Overall width: 8.58' / 2.62 meters (rub rail to rub rail)
Front axle track: 65.6" / 166.62cm
Centerline to centerline rear duals: 10.75" / 273.05mm
Outer edge of tire tread to outer edge of tire tread - front: 71.75" / 1822.45 mm (stock tires)
Outer edge of tire tread to outer edge of tire tread - rear: 79.00" / 2006.60mm (stock tires)
Wheelbase: 154" 12' 10" / 3.91 meters
Turning radius: 28.2' / 8.56 meters (outer tread edge of outer front tire)
Mid Wheelbase ground clearance: 15" / .381 meters (stock tires)
Minimum ground clearance: 12.5" (xfer case skid plate) / .318 meters (stock tires)
Front differential ground clearance - max load: 8.5" / 215.9mm (stock tires)
Rear differential ground clearance - max load: 7.625" / 193.68mm (stock tires)
Horizontal centerline front differential, max load: 14.375" / 365.13mm (stock tires)
Horizontal centerline rear differential, max load: 14.125" / 358.78mm (stock tires)
Breakover: 79 degrees (from vertical at mid wheelbase), 11 degrees from wheels (stock tires)
Approach angle: 29.4 degrees (to front cab step) (stock tires)
Departure angle: 17.1 degrees (to departure caster wheels) (stock tires)
Top of rear wheel to box: 7.25" / .184 meters (stock tires)
Bottom of frame rail to ground @ rear axle: 26.5" / .673 meters (stock tires)
Bottom of frame rail to ground @ front axle: 29.5" / .749 meters (stock tires)
Chassis (everything except the camper) % of total weight: 63%
Camper % of total weight: 37%
Front axle % of total weight: 36%
Rear axle % of total weight: 64%
Left side % of total weight: 51%
Right side % of total weight: 49%
Left front % of total weight: 19%
Right front % of total weight: 17%
Left rear % of total weight: 33%
Right rear % of total weight: 30%
Center of gravity behind front axle: 98.14" / 249.28cm
Center of gravity from passenger outer tread: 36.19" / 91.92cm
Center of gravity height: 58.92" / 149.657cm (estimated based on tilt test)
Maximum left roll angle: 31.12 (estimated based on tilt test)
Maximum right roll angle: 31.56 (estimated based on tilt test)
Maximum back roll angle: 43.48 (estimated based on tilt test)
Maximum front roll angle: 59.02 (estimated based on tilt test)
Shocks: Bilstein
Springs: Deaver
Rear sway bar: 1.25" / 31.75mm x 36" / 91.44cm
Camper & storage box frame: three point pivot
Pivot frame suspension: 50/50 Fox shocks
Front winch: 16,500 lbs. / 7,484 kilos
Rear winch: 16,500 lbs. / 7,484 kilos
Fuel capacity: ~100 gallons / 378.54 liters
Range: >1,000 miles / 1,609 kilometers
Fuel tanks: dual saddle
Fuel filters: dual one micron with online hot swap backup
Genset fuel rate: ~.2 gallons / .76 liters per hour
Air compressor: 4 cfm / 113.27 liters per minute
Air tank: 4 gallon / 15.14 liters
Maximum system working pressure: 150 psi / 1034 kpa / 10.34 bar
Air seats: dual, 3" stroke, 5 air bladders, heated
Air horns: triple, 152 decibels
Drinking water capacity:
Raw, filtered & unsterilized: ~45 gallons / ~170 liters
Fresh, filtered & sterilized: 33 gallons / 125 liters
Total: ~78 gallons / ~284 liters
Raw water input: any fresh water source
Drinking water filtration: 200kbs
Voice communications access: dual global, cab and camper external antennas for primary, camper external antenna for backup
Local voice communications: GSM 3G
Low data rate access: global
Emergency Beacons: EPIRB 406 MHZ global
Radios: VHF (bike to bike, bike to truck), CB (US band)
GPS: one fixed, three portable, cab and camper external antennas
LAN: Gigabit Ethernet
WLAN: 802.11g
Data storage: 2TB configured as 1.5TB RAID5
Document handling: color scanner/copier/ink jet printer 8.5x11" / 21.59x27.94cm
Photo printing: 4x6" / 10.16x15.24cm dye sublimation
Cab video: DVD playback, rear color camera w/microphone
Cab stereo: 300 watts, four 4.5" / 114.3mm drivers, one 10" / 254mm subwoofer
Camper stereo: 70 watts, four 5.25" / 133.35mm drivers
Camper TV: 25" / 63.5cm LCD HD (US standard ATSC)
Camper TV sound: 5 channel Dolby/DTS wireless headphones
Camper TV playback: upconverting DVD
iPod integration: cab and camper
Berth: fixed ~60x80" / 152.4cm/203.2cm
Head: dry, fixed shower
Range/cooktop: three burner
Oven: convection microwave
Furnace/heater: 30,000 BTU
Water heater: 6 gallons / 23 liters
Refrigerator (3 way: LP, 12VDC, 120VAC): 6 cf / 169 liters
Air conditioner: 11,000 BTU
Galley sink: dual
Integrated exterior LP Grill: 12,000 BTU stainless steel
Primary chassis materials: steel, stainless steel, aluminum
Primary camper materials: chopped mat fiberglass & wood ply sandwich cored with injected foam, wood, single layer fiberglass
Camper glass: dual pane
Camper leveling jacks: electric / manual
Fire extinguishers: Four ABC type (cab - 1; storage boxes - 1, camper - 2)
Ditch bags: two
Vehicle recovery kits: one
Winch line extensions: two
Winch anchor: 14,000 lbs / 6,350 kg capacity
Hand tools: ax, cross bow saw, pick, short and long shovel, pry bar
Pneumatic impact wrench: 1/2" / 12.7mm 500 ft/lb / 69.13 kgf/m
Locking external storage capacity: 268.01cubic feet / 7.59 cubic meters / 7,589 liters
Camper internal storage: 92.98 cubic feet / 2.63 cubic meters / 2,633 liters
Total storage: 360.99 cubic feet / 10.22 cubic meters / 10,222 liters
Auxiliary vehicle storage capacity: two motorcycles up to 94" / 238.76 cm long and 48" / 121.92cm high (taller bikes can be accommodated if you compress the forks)
Other views just prior to completion (missing some box corner / stone guards):
Project buildup photos are at:
BEV Buildup Photos
You can follow our travels at:
http://www.hackneys.com/travel/
edited 06/05/07 11:45pm by dhackney *
Rig buildup site: http://www.hackneys.com/mitsu/
Main travel site: http://www.hackneys.com/travel/index.htm
dirstu
Torrance,CA USA
Ultra Cool !
Thanks for posting with all the great specs.
I like the full utility concept.
Let us know how the on the road goes.
Peace
2005 Outfitter Apex 9.5
2003 F350 FX4 Lariat SRW/LB/SC 6.0 Auto
3" Edge Lift,X Springs, BFG A/T 285/75/16 E-Rated, (2front)Bilstein 5100, (2rear)Rancho R9000, AirLift Load Controller I,Edge Juice w/Attitude, tons more goodies.
1181guy
Los Angeles, CA
How is the camper secured?
Is it still removable?
2008 Ford Superduty with Lance 1181.
robseg
San Jose, CA
Very nice!
2005 F-350 SRW 6.0L 4X4 Line-X Torq Lifts
2006 Lance 835
2006 Sand Car 1989 Honda Pilot
2005 Honda EU3000is
dhackney
San Diego
1181guy wrote: How is the camper secured?
We used the stock tie down points. Details on tie down construction and tie down to storage box seals are in album 25 at: http://www.hackneys.com/mitsu/index-buildup-photos.htm
1181guy wrote: Is it still removable?
One design requirement was that the camper be removable for service or repair. We hope to never have to take if off again, but if we need to, we can.
looney bin
Nevada City, CA
That is REALLY something! Great concept and exceptional design...I have a friend that will be going to go NUTS over your project...I will send him the link. He has been talking about building something very similar to your Expedition Vehicle.
I could only look for so long myself...the wife would leave me for sure if I bring another new camper home!
Great job guys and thanks for the pics, the coolest thing I have seen in a long time!
Happy Expeditions!
looney bin
18seeds
Denver
what kind of wheel chock is that for the bike?
2006 Dodge Ram 2500 Cummins Turbo DIESEL
BradW
Flat Rock, Alabama
Douglas,
Question: Occasionally we have people ask how to estimate the vertical CG of their rigs. Can you give us some insight on how you performed the tilt test and arrived at your number?
Question: What is meant by pivot frame?
Question: What brand winches are you running?
Cool rig, but I strongly disagree with the following statement: “Project complete Sunday 3 June, 2007 ~8PM PDT / 0300 GMT / Zulu”. You know that projects like these are never really complete.
Thanks,
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos ........Visit the RV.net Blogs
4SEASON
Thousand Oaks, CA. USA
It's absolutely Beautiful.
Well Done.
Are there permanent mount steps or a ramp that come out for camper door access?
What 3rd world countries and why?
One thing I don't like is no way to start and drive away quickly (under attack emergency) while camped. This could be improved with a roof hatch in both the camper and cab. At least that way you don't have to go out the camper door and run around.
rhode trip
Rhode Island
Doug,
I've been following your progress on a couple of other forums. Thanks for your detailed reports, they are very valuable for a lot of folks interested in the expedition vehicle concept. I've always said my business has been a "very expensive education" and I'm sure thats been the case here as well, so thanks for sharing! You are to be commended for documenting the good, the bad, and the ugly. Good luck with the rig and your travels!
Jim
2002 Dodge 3500 CTD/DRW/
2000 Northern Lite 10-2000cd
www.LapelPinPlanet.com
