RV.Net Open Roads Forum: Tow Vehicles: Auxillary fuel tanks
Search only in Tow Vehicles
 > Auxillary fuel tanks
hotpepperkid
Chino Hills CA
Posted: 10/25/07 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Dieselgem wrote:
I had my transfer-flow tank installed by the Ford dealers installer. If there was a problem the dealers would not be setting up the installs.
Did the Ford dealer reset the computer so the overhead and fuel gauge read correctly?
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
10.5 Dave
Central Ohio
Posted: 10/25/07 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
country1 wrote:
When you guy's are running these RDS tanks with the filler neck "T" do you leave the RDS tank valve open all the time? Or do you stop when the stock tank gets close to empty and just open the valve long enough to re-fill the stock tank? I'm getting ready to install one and would like to know how you all have been using these.
Thanks
I leave mine open all the time.Make sure when you fill up you fill the stock tank first.
2007 Revolution LE 40E 2007 Pontiac G6 3100 lb toad
2000 Camaro SS 10.5 Outlaw 2250hp 3000lbs
2008 Cummins 3500 DRW SLT Quadcab 4x4 RDS 60 gallon tank
MichaelC
Vancouver, Washington
Posted: 10/26/07 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
How good does the T connection from RDS(Northern Tools) work? Does it shut off with a check valve of some kind, or do you have to watch your guage. I am thinking of ordering one, and using a 12v pump and fill main tank at rest stop's.
2008 Ford F-450 King Ranch
2000 SE102 Snowbird 34+2
Dave H M
IL
Posted: 10/26/07 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
the rds gravity has a DOT approved roll over valve that will also function as the shut off when the fuel gets to the level of where the aux is plumbed into the truck tank.
I leave mine open when traveling/towing. Diesel only flows down into mine about twice as fast as the truck guzzles it.
I shut it off when not in use just because it makes me feel better. I have forgotten it for days in the past and no drops or smells anywhere.
It would take a long time standing around waiting for it to fill the truck tank.
juzplanekrazy
Huntington Beach Ca.
Posted: 06/12/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
I know this is a old thread from last year but I'm going to resurrect it.
I'm ready to purchase a RDS tank and I'm really going back and forth between the 90 gal and the 60 gal tank. The 90 will hold some serious fuel and add some serious weight at the same time, and eats up the whole bed area in front of the hitch.
The 60gal model seems about rite It leaves a foot of more behind the hitch, I guess a place to throw some wood or what not.
I just can't decide. What's the going size you guys are using?
Airstreamer67
Pineville, LA USA
Posted: 06/13/08 05:34am Link  |  Quote  |  Print  |  Notify Moderator
I got the 90 gallon model for maximum fuel management flexibility. It isn't full all the time, just when I need it, but it sure is nice to reduce the pain of filling at diesel stations by a factor of three while on crosscountry trips.
Albin
North Alabama
Posted: 06/13/08 06:00am Link  |  Quote  |  Print  |  Notify Moderator
Which 60 and which 90? I have the 72118 90 gallon NT/RDS vertical tank that is 26"h x 14" thick x 60" wide. The 60" was the pain in the butt part, it barely fit within the bed plus left little room for the 3/8" ball valve.
One thing you may want to think about doing is installing a fuel water separator filter between your aux fuel tank and the OEM fuel tank. Mine has saved my butt at least once from dirty contaminated fuel. Plus it's a lot easier to drain than the OEM HFCM. I have four fuel filters on my '06 PSD and I can drain the two aftermarket filters in much less time that it takes to drain the HFCM.
Gravity feed is simple, easy, fairly cheap and reliable.
And the gravity-feed legality debate is over: read the section on gravity feed and then read the last two pages in the paper located here:
http://www.rocketcityrockcrawlers.com/bi........an_Aux_Fuel_Tank_paper_2007-06-18_R1.pdf
Good luck.
Al
KI4Dxx
‘85 Toy 4Runner
'06 F-350 SRW 6.0 PSD XLT 4x4,
juzplanekrazy
Posted: 06/13/08 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Wow, What a awesome write up Al. Thanks so much, great information in there.
After thinking about it some more last night I think I'm going big. The benefits much out weigh the loss of bed space. I don't use my truck like I did when I worked out on the job anyway's, it pulls the trailer, that's what I got it for. If I can't find a little extra space to throw a few items in a 40' toy hauler than somethings wrong.
Maybe I'll come back and add a few install pictures when I get it done. But I doubt I can beat what Al did.
Thanks for the info guys.
jasonlisan
Colorado
Posted: 06/13/08 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Joe, let me know how it goes because curious minds want to know. I priced a 60gal under the bed from transfer flow here in Denver and they wanted a pretty penny (like $1500.00) for the tank/install. Haven't inquired but are the ones that go into the bed cheaper??
juzplanekrazy
Posted: 06/13/08 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Howdy Jason, The 90 gal RDS in-bed tank is like $700 + $69 for the fuel fill kit. The 60 gal is a $100 cheaper. If your like me and don't use the bed for hauling stuff when not towing then a in-bed type should be fine. Not as cool as the built in frame install type but half the cost. I'm hoping I can find a place local that sells the RDS tanks so I can save a little on shipping. The thought of making it over a 1000 miles without stopping at a gas station is pretty awesome. Much less when I see a cheap price, I'll be filling up
keep ya posted........
