RV.Net Open Roads Forum: Fifth-Wheels: Tire Clearance Question
 > Tire Clearance Question
Fifth-Wheels Related Tips
pritch272
Martinez, GA
Posted: 07/07/07 11:55am Link  |  Print  |  Notify Moderator
Finished getting the Milestar ST225/75D15's off, and getting the Michelin 245/75R16 E's on- Clearance seems fine, except for just one close area on the back side of the front tire on the side with the slide, the middle of the sidewall, (halfway between the rim and the tread), is adjacent to the rotating bar for the slide on that side. There's about 3/16" (maybe a hair less) between the side of the tire and the corner of that bar (it's rectangular). I drove it home from Sam's Club, stopping off at a couple of places, one where I had to turn around in gravel, and make some backing maneuvers to get turned around. I say this as I see no evidence of the tire having made contact with that bar. I didn't notice this close clearance until after I got home and crawled under to check things out.
Here's a picture, and my question is, do I have anything to be concerned about? Should I take the tire off and smooth that edge out, the edge where the one rectangular bar goes into the other?
2007 Keystone Laredo 29RL, 2000 Ford F250 SD 7.3 PSD, Firestone bags, Pressure Pro / Metal Stems. 16" Michelin XPS Ribs. MorRyde Pin Box. Dirt Devil CV950 Central Vacuum, 2000W AllPower by Kipor (Honda Clone), 4000/3500W Champion C46540, Honeywell 2000i
pritch272
Martinez, GA
Posted: 07/07/07 12:06pm Link  |  Print  |  Notify Moderator
What about the possibility of making some sort of adjustment on that bar, can it be adjusted so that it stops where that side of the rectangular bar is straight up and down, rather than where it is now?
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 07/07/07 12:21pm Link  |  Print  |  Notify Moderator
You might be able to put spacers behing the wheel to gain some clearance.
Trailer Trash 2
Santa Fe Springs, CA
Good Sam RV Club
Posted: 07/07/07 01:07pm Link  |  Print  |  Notify Moderator
Is that clearance from the factory or did you go bigger and wider on tire size.
Sure hope you dont have tire seperation, because it will possable tear up that slide bar next to that wheel.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
2009, Dodge, 3500, Q Cab, Cum/Diesel, D.R.W.
Pulling a Super Fine Montana 2980RL
Everest364Q
Memphis TN
Good Sam RV Club
Posted: 07/07/07 01:20pm Link  |  Print  |  Notify Moderator
The bar is part of the gear mechanism on Lippert slides. There is only one hydraulic ram on one side, and when the side moves, there is a worm gear that turns that rod which in turn moves the worm on the other slide leg. You can't mess with it or your slides won't work.
I have a slide also that spans the axles, and the bar is fairly close to the tires, but it doesn't look quite that close.
I would just keep an eye on both the bar and tires, and as long as you don't see any indications of rubbing, you are probably fine.
Larry
2006 F350 DRW CC Lariat King Ranch
6L Diesel / Torque Shift Auto / 4.30LS Rear End
13,000Lbs GVWR / 26,000Lbs GCWR
2006 Everest 345S Fifth Wheel
pritch272
Martinez, GA
Posted: 07/07/07 01:22pm Link  |  Print  |  Notify Moderator
I upgraded from ST225/75D15 (8.85 width) to LT245/75R16 (9.64 width), I should have moved closer only half that difference about .395, assuming the wheels I took off were 0 offset as I put on 0 offset wheels.
pritch272
Martinez, GA
Posted: 07/07/07 01:24pm Link  |  Print  |  Notify Moderator
Larry
Do you think I should smooth out that one protruding edge a little?
Everest364Q
Memphis TN
Good Sam RV Club
Posted: 07/07/07 01:35pm Link  |  Print  |  Notify Moderator
You could hit it with a grinder, just smooth it up a bit, but I wouldn't attempt to thin it down any.
Larry
minnow
Upstate New York
Posted: 07/07/07 01:54pm Link  |  Print  |  Notify Moderator
Good God man, didn't you read the first post ?
Kenneth
Washington, the state
Posted: 07/07/07 03:15pm Link  |  Print  |  Notify Moderator
Probably too late, but LT235/85R16 would have been a better size choice. These carry the same load and have the same outside diameter as LT245/75R16. The tire shop guys should have known this.
