RV.Net Open Roads Forum: Fifth-Wheels: New Wheels and Tires, before and after pics
 > New Wheels and Tires, before and after pics
Trailer Trash 2
Santa Fe Springs, CA
Good Sam RV Club
Posted: 07/07/07 01:02pm Link  |  Print  |  Notify Moderator
Looks fantastic!!
Did you have to change you roto-choks? due to the space between the tires changing
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
2009, Dodge, 3500, Q Cab, Cum/Diesel, D.R.W.
Pulling a Super Fine Montana 2980RL
pritch272
Martinez, GA
Posted: 07/07/07 02:06pm Link  |  Print  |  Notify Moderator
The wheels I bought from trailertiresandwheels.com
and the tires I bought from Sam's Club
I took some measurements and a picture or 2 and sent them to Scott at trailertiresandwheels.com, who thought I would be OK. I went to the local Trucks and Moore shop, they thought I wouldn't have any problems, and also went to a trailer specialty who didn't see any issues.
The only possible clearance issue is being addressed in this thread and concerns the distance from the back sidewall of the tire and the rectangular slide bar. I checked the wrong side for clearance measurements before I ordered, but I think I might be ok.
I have only driven about 7 or 8 miles with the new tires, so am not sure if I can report any difference in towing. I did get on the interstate for 2 or 3 miles, it seemed to handle fine.
As for the roto-chocks, I don't have them yet, I'm still using a couple of bricks.
I had about 3.2 inches above the wheel before and now have 1.5 on the slide side and 2 inches on the non slide side. I now have about 3" between the tires, where before I maybe 5. The diameter difference is 2.18" so the tire increased 1.09 vertical, which also factors in the wheel change.
And yes, my wallet is a lot lighter, as well as any concerns about having a blow out. I installed new metal valve stems as well, I had to find skinny ones that bolt in from the inside of the wheel, and had to add .75" metal extenders also.
2007 Keystone Laredo 29RL, 2000 Ford F250 SD 7.3 PSD, Firestone bags, Pressure Pro / Metal Stems. 16" Michelin XPS Ribs. MorRyde Pin Box. Dirt Devil CV950 Central Vacuum, 2000W AllPower by Kipor (Honda Clone), 4000/3500W Champion C46540, Honeywell 2000i
buckbs
Foley, AL, USA
Posted: 07/07/07 03:54pm Link  |  Print  |  Notify Moderator
For the people who have heavier rigs, and need "G" rated tires and wheels, I went with Goodyear G614's and Alcoa forged aluminum wheels which are made for 110PSI.
Cost some money, but I have had them for two years and made two trips across the country. They make me feel safe when going through the "rockies" with the sharp drop offs right next to the asphalt.
$800 for the tires, and $900 for the wheels, but if you "are going to play, you gotta pay".
buck
KSadler1
Albuquerque, NM
Posted: 07/07/07 04:21pm Link  |  Print  |  Notify Moderator
How are you guys seeing the pictures? All mine shows is, "image not shown due to your preference setting".....
Ken
2008 Ford F250 XLT Super Duty SB Crew Cab 6.8L V-10 4x4 4:10
2005 Keystone Copper Canyon Sprinter
ol Bombero-JC
Posted: 07/07/07 04:55pm Link  |  Print  |  Notify Moderator
KS - Pics just fine - probably as indicated: "your preference setting/s". [Browser I'm using is Firefox - haven't used IE in a while] TT2 - If you already have Rotos - call Pearl - they will make changes for you, I suspect for just S/H charges. buckbs - just to be informed (you already have 'em) check the lengthy "G614 Warning" thread in Escapees HDT forum back about 3 or 4 pages now.
Note: Due to invalid formatting, all formatting has been ignored.
Dennis M M
Geneva, IL
Good Sam RV Club
Posted: 07/07/07 06:03pm Link  |  Print  |  Notify Moderator
Really nice looking set up! like Joe I am curious about wheel rand and where you got them.
Oops, posted before I read the whole thread - disregard
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'05 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro;
Optima Batteries
bertpapa
La Crescenta, CA 91214
Posted: 07/07/07 06:16pm Link  |  Print  |  Notify Moderator
looks great! we just did the very same thing to our laredo and we do notice a much better ride. i am very happy with the decision to swap the 15" cheap tires for the michelin ribs - what a difference!
we do have rotochoks and called the company - they sent different sized plates (smaller) which we swapped out, saved us $$$$ by not having to buy all new rotochoks and it was easy to swap the sizes - great company and i would recommend rotochoks to all.
Bertpapa
Bertpapa's Wife
2 Daughters (21 and 23)
1999 Ford F250
Pullrite 16K Super 5th with Super Rails
Prodigy Brake Controller
2006 Keystone Laredo 29RK
pritch272
Martinez, GA
Posted: 07/07/07 06:27pm Link  |  Print  |  Notify Moderator
bertpapa wrote:
looks great! we just did the very same thing to our laredo ...
What size Ribs did you put on? It looks like the RK has the same slide as the RL, hows the clearance on the back side of the tire, between it and the rectangular slide mechanism? How much do you have?
RedRam
Moved from the smallest county in Texas
Posted: 07/07/07 06:44pm Link  |  Print  |  Notify Moderator
Can-AmDuo wrote:
Looks great... We are thinking of going to 16" E's on our Cougar 290RKS.
Can-AmDuo,i don't think you will have any problems as our Cougar came with 235/85/16E's .
04 Dodge CTD
08 Bighorn 3370
davedave098
michigan
Good Sam RV Club
Posted: 07/07/07 09:50pm Link  |  Print  |  Notify Moderator
looks real nice -- did you flip your axels -- on my laredo the tires hit the top of the wheel well ?
When Life Sends You A Bunch of Lemons & Limes Demand Some Tequila And "Call Me for Help "
