It would appear that the new Toyo A/T, 285/75/17, has a load rating of 128 which is roughly 3960 lbs/tire. A great option for those of us whith Dodges and 17 inch wheels. Just though I would share this, since I've been considering a TC.
joe_jeep wrote: i got the toyo at 305/70/16 its rated at 3540 lbs max. wearing well so far, pretty quiet, good traction, fair price. i reccommend them!
Joe,
What's the rating on your stock rims (looks like the alloy rims)?
Blaine & Linda
04 F350 PSD Crew LB SRW 4x4 3.73 Rancho 9000RSX (leaky in-cab controller) TorkLift Super Hitch & Tie Downs
Shopping for a TC
95 Sea Ray 270 Sundancer 7.4 Bravo 3
Sotar/Hyside/Aire Whitewater Rafts, Cats & Kayaks
3 Kids
Not Enuf Time
I had Toyo AT's on my previous truck and they were great... reasonably priced, excellent traction, long-wearing and relatively quiet.
However, I would say that they are an "alternate" to 19.5's only if your rear axle is less than 7920lbs... and you are comfortable being close to the max load (or perhaps over) if you have a heavy TC.
My rear axle is just over 8000lbs (loaded & wet)... I sleep a lot better at night knowing that I am 2000lbs below the tire load rating of my 19.5's.
Just so it's clear, these are only a viable upgrade if the wheels you mount them on are rated for that kind of load. A lot of wheels (after market as well as stock) are NOT.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
im not sure of the load rating of my wheels yet. but ill look into it. alcoa makes fords aluminium rims. i pick them up and deliver them sometimes. id be more worried about rubber valve stems than aluminium rims. i went to solid bolt in steel valve stems. if i get a rating on the rims ill post it.
