RV.Net Open Roads Forum: Class C Motorhomes: REMOVING ETERNABOND
 > REMOVING ETERNABOND
rod reid
Colorado
Posted: 07/11/07 10:35pm Link  |  Print  |  Notify Moderator
Hi, the eternabond on my rv is lifting in some places at the edges and at the ends. I have purchased new eternabond with the idea of removing and replacing. Problem is how the heck do you get this stuff off?? I have tried pulling from an end ,but don't want to proceed if there is a solvent or something that will remove it. Thanks. Rod
ronfisherman
SE Michigan
Posted: 07/12/07 03:03am Link  |  Print  |  Notify Moderator
I did not read the bulletin. But here is a link to Eternabond bulletin on removing it.
Saf-TTE tire monitor
rod reid
Colorado
Posted: 07/12/07 07:19am Link  |  Print  |  Notify Moderator
Got it, thanks for taking the time to look. After I posted I had the brilliant !idea of looking up the eternabond website (slow ,but I get there ) and finally found the service bulletin. Once again thanks .Rod
dleslie125
Southern Ontario/Palmetto FL in Winter
Posted: 07/12/07 10:46pm Link  |  Print  |  Notify Moderator
When they say good luck, they mean it. So "Good Luck."
Don, Bev & Phil
07 Jayco 32SS on Kodiak May 07 Yahoo Kodiak Group
06 HR Amb 40PLQ ISC 330/950 9/05-5/07
04 Winnie Jrny 39W CAT C7 7/04-9/05)
00 Triple E Commander 5/03-5/04
Toad - 07 Tahoe LTZ 12/06 -
04 Colorado Z71 04- 06
lakerfam
Gresham Or.
Posted: 07/21/07 11:42am Link  |  Print  |  Notify Moderator
Peeling up should tell you something, its JUNK!!! Just like Snow Coat
dleslie125
Posted: 07/21/07 12:50pm Link  |  Print  |  Notify Moderator
Not really. We used EB and found it great. What may be peeling up is what it was put on - and that you have NO control over.
Snow Coat - never heard of it.
rod reid
Colorado
Posted: 07/30/07 07:13am Link  |  Print  |  Notify Moderator
Follow up to my eternabond removal post. As it turns out I do not think that it is eternabond up there. since we had this 90 plus weather i pulled the old tape again and up it came. It left a black residue not the gray like eternabond and i was able to clean that up with rubbing alcohol. applied the eternabond on the front so far and it looks good. Still have to finish it off with a bead of caulk ,but easier than I thought . The eternabond itself is not that easy to apply when you have rivets etc. to go over ,leaves lumps and crinkles ,but i am hoping this will be a one off job. Rod
Shortie
Mariposa County, CA
Posted: 07/30/07 10:44am Link  |  Print  |  Notify Moderator
Rod: You may want to check with Andy Baird, who has a Lazy Daze, and has used Eternabond extensively over the years. Andy tells it like it is and I know you would enjoy getting his feedback. His website is www.andybaird.com - he has answered all our questions with regard to eternabond and it's application and removal. Also, he will answer any and all emails to him.
j-d
Sunny Florida USA
Posted: 08/03/07 10:37pm Link  |  Print  |  Notify Moderator
Rod,
Ours had "butyl tape" whose residue removed with lacquer thinner. It was 2" wide and the EB was 4". I called EB and they said half an inch either side of the butyl was marginal adhesion area but should work. When I found the butyl would come off then the thinner would clean the glue away, I removed all the old and applied the EB. You're right about the rivets and joints. Job comes up a little lumpy.
BTW, I ran EB from trim to trim across the roof. HR had put butyl across the top only then a sealer around the curve to the trim strip on each side. I decided that some EB, even wrinked a little, was better to be seen from the ground than not prevent a leak.
Have fun!
God Bless, jd
