RV.Net Open Roads Forum: Tech Issues: Sound deadening box for EU1000i
 > Sound deadening box for EU1000i
Page of 6
Tech Issues Related Tips
jauguston
Bellingham, WA
Posted: 07/17/07 10:09am Link  |  Print  |  Notify Moderator
Alan,
I have done testing with a remote temp sensor on the hot air outlet from the generator and the air out temp is less than 3 degrees higher in the box with a 500w load running for a hour than it is outside the box. The hot exhaust is directed against a 1" thick blanket of high temperature pipe wrap blanket that is rated to 2000 degrees. From there it mixes with the cooling air and is cooled to around 190 degrees. So far I don't forsee any problems but who knows, it is a work in progress (-:
The pictures bill posted are "Under construction". I will take the "Finished" ones today. They may more clearly show what I did.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 275
AIMS 2500w inverter 4-6v GC batteries
4-Kyocera 130w solar panels SB3024iL MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Kenneth
Washington, the state
Posted: 07/17/07 10:19am Link  |  Print  |  Notify Moderator
I'd add a couple of high output small box fans (muffin fans, computer fans, etc.) to push fresh air into one end of the box. These are available in either 12vdc or 120vac, and could be powered by either the 12vdc charging outlet or one of the regular 120vdc outlets. Grainger is one good source for these fans. Their specs list both the fan noise level and the air output capacity. The optional cord for the fans is handy, and the finger guard screens are smart.
Largestal
Lexington, KY
Posted: 07/17/07 11:54am Link  |  Print  |  Notify Moderator
Jim -
Thanks for the response, I am always curious about all the details.
Best wishes.
smkettner
Good Sam RV Club
Posted: 07/17/07 12:03pm Link  |  Print  |  Notify Moderator
I am surprised you used what looks like foil covered material inside the main box. I would think that would reflect the sound waves more than some more open material. Looks great, any actual sound measurements in the works? Will it have a lid?
jauguston
Bellingham, WA
Posted: 07/17/07 01:06pm Link  |  Print  |  Notify Moderator
That shiny material is a engineered multi-layer product that is commonly used in the engine room of luxury power boats. It is very effective. The only down side to it is a sheet 32"X54" costs almost $70.00. It took almost a full sheet. That stuff is the heaviest part of the box.
I just e-mailed the finished pictures to billh. He may post some of them. That is fine with me.
Sound measurements were done. My meters lowest reading is 50 db and at 20' the needle does not move off the stop unless I make a noise.
Jim
jauguston
Bellingham, WA
Posted: 07/17/07 01:16pm Link  |  Print  |  Notify Moderator
Kenneth,
You may be able to see it in some of the pictures but my plan was to isolate the incoming air from the heated exhaust cooling air and the engine exhaust. That way no additional air movers would be needed. The EU1000i has a single hot end outlet for hot cooling air and engine exhaust so it was not too hard to isolate the sides.
Jim
SCVJeff
Santa Clarita, CA.
Posted: 07/17/07 01:41pm Link  |  Print  |  Notify Moderator
VERY NICE!
This is a mini-version of the large 300-500A @ 220 show-biz generators I'm used to that you literally cannot hear run unless you lay your head on the housing. The interior design uses the same soundproofing as yours, along with fire and heat-proof Sonex. For cooling, those guys use really big electric squirrel fans (even the small ones are way more quiet than a comparable "muffin" in volume) to exhaust the air straight up. The also mix exhaust in this stream.
Anxious to see the finished pics!
PS- What's this weigh in at (-gen)?
Jeff - WA6EQU
chuck4788
West of the Middle
Posted: 07/17/07 03:58pm Link  |  Print  |  Notify Moderator
Good job and a similar choice of materials to what I used for an 8kw diesel generator enclosure. I used the generator fan to pull in outside air via a labyrinth passage, the enclosure air exit was at the other end, also via a labyrinth. Both labyrinths were lined with acoustical material. No exhaust issues because this was a marine genny and the exhaust system was water cooled.
I also used aluminum angle but used pan head sheet metal screws thru the aluminum into the wood.
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
jauguston
Bellingham, WA
Posted: 07/17/07 06:17pm Link  |  Print  |  Notify Moderator
Jeff,
The box weights 28 pounds.
PM me your e-mail address and I will send the pics to you.
Jim
jauguston
Bellingham, WA
Posted: 07/17/07 07:10pm Link  |  Print  |  Notify Moderator
I am trying again to post a link to the pictures of the box for the generator. Here is my try (-:Gen Box
Jim
Page of 6
