RV.Net Open Roads Forum: Class C Motorhomes: Brake light / ABS light on..
 > Brake light / ABS light on..
kaagee
Burlington Ontario
Posted: 07/16/07 09:30am Link  |  Print  |  Notify Moderator
I have a 1999 E450..ABS/disc on front and rear..
While driving yesterday the Brake/ABS light
on the dash came on...
Brake fluid level OK.. Brake Pads new..No change in braking behavior.
Anyone else have this problem.
Ken
* This post was edited 07/16/07 03:07pm by kaagee *
Johno02
Lexington, TN USA
Posted: 07/16/07 09:55am Link  |  Print  |  Notify Moderator
Same problem with my 99 Hurricane on a Ford chassis. My mechanic says that it is probably a sensor or a bad connection. It resets OK by turning ignition off(parked of course),and back on. Now that we will be off theroad for a few, I will have it checked. He also said to be aware that if the light is on, you have NO abs working. Be careful!
Noel and Betty Johnson
'99 Hurricane 1 wife, 2 1/2 dogs
Bumpyroad
Virginia
Posted: 07/16/07 02:33pm Link  |  Print  |  Notify Moderator
bad rear sensor
Sammy4_3
Jacksonville, Fl
Posted: 07/16/07 05:43pm Link  |  Print  |  Notify Moderator
The DTC (diagnostic trouble code) should be retrieved and it will give you an idea where to start. If the rear VSS (vehicle speed sensor) is bad it will have a C1230 code or similar. Check the wiring to the VSS which is on top of the rear differential. If that is ok, it's probably the sensor. Price range is around 15-20 bucks.
kaagee
Burlington Ontario
Posted: 07/16/07 06:41pm Link  |  Print  |  Notify Moderator
Thank you for your replys.
Johno02.
My light did not go out after turning ignition off and on again.
Bumpyroad.
Did you have this problem and the rear sensor fixed the problem?
Sammy4_3
I should of mentioned this..I have a Scan Gauge hooked up but it didn't show any trouble codes.
I'll get underneath tomorrow and check all the connections.
Thank you all for your help...Ken
rjstractor
Auburn, WA
Posted: 07/16/07 08:39pm Link  |  Print  |  Notify Moderator
As with any type of trouble/check light, the codes must be retreived by the correct type of reader. I don't think OBD-II scanners will retrieve ABS codes. Without knowing the trouble codes, any attempts at diagnosis/repair are just wild guesses.
1998 Gulfstream Ultra B/H Ford E450 V10
2005 Chevy 2500HD 6.0 w/ Maxidump insert
6x12 Interstate enclosed trailer
7x16 Bulldog flatbed hauling a 2006 Kioti CK20 TLB
2003 Ford Explorer Eddie Bauer
1998 Saturn SL2 toad
Johno02
Lexington, TN USA
Posted: 07/16/07 09:35pm Link  |  Print  |  Notify Moderator
My mechanic said that the code had to be checked when the light was on. Apparently it resets each time. For me, this is going to be a problem, as it never comes on when we are anywhere close.
Bumpyroad
Virginia
Posted: 07/17/07 05:57am Link  |  Print  |  Notify Moderator
yes, on a dakota PU, ABS and brake lights came on, stayed on. didn't try my code reader since my mechanic friend said that mine wouldn't pick up brake problems, only electrical??
same problem on a 99 ford class A chassis, check engine light would come on, speedometer quit, replaced VSS, happened at least twice. at $15 I would go ahead and replace it, heck I think they charged me $85 just to plug in their code reader.
Dakzuki
Carnation, Wa, USA
Posted: 07/17/07 12:59pm Link  |  Print  |  Notify Moderator
The speed sensor is a chronic problem on the Fords.
95 Chinook Premier
kaagee
Burlington Ontario
Posted: 07/19/07 12:41pm Link  |  Print  |  Notify Moderator
GREAT!! ....It was a bad rear sensor.. Thank you everyone....
Ken
