RV.Net Open Roads Forum: Class C Motorhomes: E450 Gear Change ?
 > E450 Gear Change ?
ksmike
Kansas
Posted: 07/18/07 12:24am Link  |  Print  |  Notify Moderator
Has anyone done a gear change on their E450 with a V10 from a 4.56 to a 5.13 ratio? With these gas prices now I dont need to drive my 2003 31' Class C at 75 mph. Driving it at 60 or 65 puts it too low in the RPM range in OD to be comfortable. Anyone that has changed to a 5.13 let me know how you like it.
Mike
2003 31' Gulfstream
davemittan
North central Arkansas
Posted: 07/18/07 03:18am Link  |  Print  |  Notify Moderator
I'd like to piggyback on Mike's thread, if I may -
does anyone know if I can change the rear end ratio on my E350?
I wonder what ratios are available.
(For the same reasons as Mike's)
Dave
purplepossum
Virginia, USA
Posted: 07/18/07 05:54am Link  |  Print  |  Notify Moderator
Mike
2003 31' Gulfstream
2 Questions;
Wouldn't you be burning about the same amount of gas at 65 with a 5.13 as you would the 4.56 at 75? Is there a gear change option in between the two?
murffdog
Poughkeepsie, NY
Posted: 07/18/07 07:17am Link  |  Print  |  Notify Moderator
purplepossum wrote:
Mike
2003 31' Gulfstream
2 Questions;
Not to mention that there goes any warranty you may have.
79powerwagon
S.E. Wisconsin
Posted: 07/18/07 07:38am Link  |  Print  |  Notify Moderator
Hmmm, my C class has 4.10's, and you want in the 5's?
I'd bet the chassis is geared for maximum compromise between drivabilty and fuel economy from the factory. When you're spinning the engine faster, the tranny is working harder creating more heat, which is the death of all automatic trannys.
To really see if your engine is "uncomfortable" as it is currently set up, run a vacuum gauge for several miles. Do you have a tach as well? If so, note the rpm range where you're achieving the highest inches of mercury, and then check your speed. If you want to go faster, change to shorter gears. If you want to go slower, change to taller gears, all this to set up your pace with the comfort zone of the driveline.
Hope this helps! And yes, talk to a truck dealer about any warranty issues first.
BEVAR
Lake Worth, FL
Posted: 07/18/07 07:43am Link  |  Print  |  Notify Moderator
What kind of mileage do you get driving 75 MPH? I can't imagine driving my GR at 75...
Beave
ksmike
Kansas
Posted: 07/18/07 08:38am Link  |  Print  |  Notify Moderator
Warranty? Shouldnt the warranty be expired by now it being a 2003? I guess I dont expect it to get better mileage by doing the gear change. I expect it to get better mileage by driving 60 or so instead of 70 or so. With the current gear the ening seems to be to low in its power band at 60 in OD. It down shifts more on grades than if I drive 70. In 3rd gear its wound way out at 55. If the conditions are perfect it drives ok at 60, ie, no wind, no grade, no toad. Now it gets from 6.5 (poor conditions) to 8.5 (perfect conditions) mph. In a couple of weeks we are taking a long trip so I want to get the change done before that to see how it does. It has the 4.56 gears in it now.
bosspsd
Somewhere, Minnesota, USA
Posted: 07/18/07 12:14pm Link  |  Print  |  Notify Moderator
I have thought the smae thing about our gas powered Endura. Its happy place is is 2400 rpm which is around 68 mph. It would be nice if it ran 2400 rpm at about 62-63 mph. When we pull our 28' racecar trailer I always set the cruise at 68 mph because it does the least amount of shifting between gears there. I think the Endura has a 4.56 gear, wonder how a 4.88 would do. The new Super Nova has a 6.14, now thats low.
The week before last we drove home from the black hills SD back to MN and had the cruise set at between 73-76 mph for 15 hours. The rig ran flawlessly. Sucked some major gas but we're not retired and don't have all the time in the world to get to and from places.
2005 Gulfstream Endura 6340 8.1L
2006 F350 Lariat crew cab 6.0L powerstroke
2000 Excursion Limited 7.3L powerstroke
1997 Neil & Parks Super Comp Dragster
2 junior dragsters for our 10 & 12 year old boys
2005 28' Featherlite trailer
carringb
Corvallis, OR
Posted: 07/18/07 12:56pm Link  |  Print  |  Notify Moderator
Some E450s came with 5.13 gears from Ford. I found that out when looking for axles at junkyards. I'm assuming probably a special fleet order option or something. That big of a change may require a carrier change too, so that'll add some $. But, it'll lower MPGs probably.
davemittan - 4.56 can go in the E350 also.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, 230,000+ miles
Had: Weekend Warrior 41' FSW (still looking for its replacement)
davemittan
Posted: 07/18/07 01:17pm Link  |  Print  |  Notify Moderator
Thanks for the info! Wouldn't I also want the appropriate speedometer cable to go with it?
Dave
