pulsar
Lewisville, NC
Good Sam RV Club
Chuckf1 wrote: I've been receiving 2kb email notifications with out the forum link.
The mail messages is blank.
Can you fix??
If yours is like mine, you will find that the top 24 lines are blank, which makes the page appear to be blank. When I scroll down, I find the ususal notification.
Tom
427435
Rochester, Mn
TCandDC wrote:
Another issue as of late seems to be the spell check feature, it comes up with a 404 file not found message when used.
Same here. Plus the preview of each post has been goofy for several weeks. Big square box that flickers on and off.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
pulsar
Lewisville, NC
Good Sam RV Club
I guess you are using the Woodalls portal; it is the only one that I know the has a preview problem. You can turn the preview box off in your forum preferences, or switch to one of the other portals.
At 11:30 pm (EDT) yesterday, the spell check was working on all portals and is this morning, also.
Tom
viajante
Sacramento, CA, USA
We're part of the Good Sam's Club - and I only get partial notifications - so I just sign on occasionally to see if I've gotten responses to my postings. I'm sure eventually things will go back to normal, just takes time!
BirdSongPlace
San Diego County, CA
Quote: At 11:30 pm (EDT) yesterday, the spell check was working on all portals and is this morning, also.
Tom
I have been having the same problem with spell check for a couple of weeks now! Apparently not all the portals are fixed. The message I receive is
Quote: 404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable
I'd be happy to tell you which portal I'm using if you will tell me how to determine which portal I am accessing rv.net with.
If it is any help in figuring out which portal here is a little more information. I have rv.net as an icon on my desk top. If I right click on the icon in properties it shows the path as: http://www.rv.net/forum/
2000 Ford F350
2004 Adventurer
pulsar
Lewisville, NC
Good Sam RV Club
The moderators have also noticed that spell check is intermittent on RV.Net and Woodalls. It has worked for me, every time I've tried it, including this post.
Here are links to all 8 portals. The part of the URL just after "WWW" will tell you what portal it is. Also, each portal has its own banner at the top.
http://www.woodalls.com/cforum/
http://www.trailerlife.com/forums/
http://www.tldirectory.com/cforum
http://www.openroadsforum.com/forum/
http://www.coastresorts.com/cforum/
http://www.goodsamclub.com/forums/default.aspx
http://www.motorhomemagazine.com/cforum/
Tom
edited 08/03/08 09:17am by pulsar *
wingrider6
Central Illinois
I, like TCandDC am consistently getting "Network Error" messages when I try to login using RV.net. However, I have not experienced any problem with logging in through Trailer Life.
Dave & Dee
2006 40' Open Road
2008 F-350 Dually V-10 4:30
2 yrs USA Big Red One Vietnam Retired USAF
Retired teacher after military
pulsar
Lewisville, NC
Good Sam RV Club
After several days of the RV.Net portal being stable, something happened early this morning, during the normal maintenance cycle. It seems as if the techs restored an old backup by mistake. We have reported the problem.
After having continuous problems with the portal earlier this morning, I haven't seen a problem over the last 5 minutes. Perhaps they have corrected the problem. In any event, I'm also keeping Trailer Life open.
Tom
Little Kopit
TheMaritimes.ca
Well, Trailer Life is nitpicking right now. More than one thing, but the one I can remember after a number of posts, ..... is that the reply frame drops down a good 3" on my screen.
Niddling, but an indication that TL is not perfectly smooth.
& I, I took the road less travelled by.
My Photo Album, featuring Labrador 2006
Rotton Rob
Pinehurst Id
I just tried to send a quick reply and the submit button did not even show... Also can't find the next or prev button..I think this new thing is not working....
Rotton Rob
2003 3500 4x4 Dodge long box 6 sp.SLT, CTD
2000 Carraige
1997 Chry. LHS (wifes)
1992 Jeep Cherokee
1969 Ford Tor. 428 CJ
2001 Sprinter 244rb
1992 Kit 18d
