CerOf
Dallas, TX
We have sway control on our fleetwood E3, weighs about 4,000lbs loaded. We pull it with a Montero SPort XLS 4WD.
Pulls nice and smooth, no sway at all with the sway control installed.
I also have a 2" lift with HD (stiffer) springs with a progressive rate coil that is designed to be loaded down. It only squats about 2" in the rear.
Sway control is very nice in windy conditions and when passing/being passed by 18-wheelers.
DRLDom
IL
We pull a 2003 Westlake with a Class 2 hitch. The previous owner included the sway bar, so we use it. This past weekend, as we moved 30 miles between CG's, I left it off to see how it handled. Frankly, I couldn't tell the difference - but it was a calm day on four lane highway. Don't know if I could say the same thing on a windy day going down a busy two lane - but with the sway bar, it's always rock solid.
As has been said here before, you should fix the reason you have sway before you mask the problem with a sway bar. I will continue to use ours simply because it it isn't much bother, and I like the insurance.
2003 Fleetwood Westlake
2000 VW Eurovan
gcandcc
Upstate NY
Sway bar here. The Hemlock beast tows like a dream.
Cynthia & Gary
Jeffrey 25
Angel 14
Aaron 6
99 Explorer EB
98 Expedition EB
93 Palomino Filly
04 Fleetwood Hemlock
http://community.webshots.com/user/cynthiacook777
34 Nights camping in 2008
37 Nights camping in 2007
26 Nights camping in 2006
Webwader
Portland, OR
No sway control here. I have towed the Sequoia almost 10,000 miles and never have had a sway issue. It tracks like an arrow. We did have one when we had the Coleman Mesa.
'06 Honda Ridgeline RTS
'07 Toyota RAV4 V6 FWD
'05 Fleetwood Sequoia
Garmin 2610 GPS
crosbygroup
california
WDH and sway control. The Avalon pulls great.
Crosbygroup 2008 Fleetwood Avalon Highlander
If you're not part of the solution, you're part of the precipitate. ~Henry J. Tillman
bud121156
Shelby, North Carolina
No sway control yet , but I am strongly considering it. I can tell the difference in sway by the way the trailer is loaded. My first few trips out, I was very conservative about putting anything in the trailer, and I had some sway at times, mostly going downhill , more going downhill into a curve. Now I put as much heavier supplies as I can in front of the axle, and the sway is much less.
Donnie and Cheryl
poptart2
Illinois
I have a 1998 Viking 2470ST and had some sway whenever I went over 60 mph. I don't have a sway bar. I heard they should not be used on the Vikings. Is this true. Has anyone else had this problem.
Poptart2
mike4947
N. Syracuse, NY
What is not recommended by Viking is a weight distribution hitch. A sway control is a different animal. BUT, first thing is to weight the trailer and tongue to make sure you've loaded the trailer correctly so at least 10% of the trailer's gross weight is on the tongue.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
My2500HDTruck
Contra Costa County
I used to have sway problems when towing with a mini-van. I now tow with a truck and the sway problems went away. Having a heavier TV and a longer wheel base make a BIG difference. I don't even have to try to balance the tongue percentage with this setup. Absolutely no sway with this combo.
2004 Silverado 2500HD: LT, Crew Cab, Duramax/Allison, 4x4
2000 Coleman Timberlake Popup
Nyssa
Colorado Springs
Use a sway-bar . . . you won't regret it. Cheap and works superbly. I do wonder about the discussion surrounding Class II receivers. Most tow vehicles with factory packages have Class III hitches. Occasionally I see smaller ones, especially on Explorers, but I think you would be wise to stick with Class III. Stronger, many accessories, etc. I recommend the DrawTite Friction Sway-bar. You will also need the adapter plate that goes on your hitch bar that holds the sway-bar's smaller ball. My trailer tows like it is attached to my Jeep.
